JUICEDMOTORSPORTS
Old 03-06-2014, 11:07 PM   #15
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Great job, both with the end product, and how you shared the details!
AG1LE is offline   Reply With Quote
Old 03-06-2014, 11:20 PM   #16
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
Looks good, but time to get some new pads and ditch those skates!
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 03-17-2014, 04:25 PM   #17
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
I'm in the middle of this job right now. I'm done with the front two calipers. Wow! Thanks thkfast!
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 03-17-2014, 06:04 PM   #18
Jerry7297
Jerry7297's Avatar
Drives: 2016 3LT Stingray RIP-2010 CamaroSS
Looks good man, Adds 10hp Color looks great. This should be added to the DIY sticky. There is currently not a caliper painting one on there.....
Jerry7297 is offline   Reply With Quote
Old 03-18-2014, 05:25 PM   #19
ssfox
ssfox's Avatar
Drives: 2011 2SS/RS Vert
Looks fantastic!
Definitely doing this shortly.
2011 2SS/RS VERT
Moroso Catch Can,K&N CAI,Apex Air Scoop & Washer Relocate,ZL1 Grille,GTO Clutch Rez, Frameless 2013 mirror.
Tuned by MGS Performance
ssfox is offline   Reply With Quote
Old 03-18-2014, 06:35 PM   #20
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Looks great!! I am trying to decide weather to paint mine yellow with VHT or have them powder coated. Thanks for the write up
CamaroLS is offline   Reply With Quote
Old 03-19-2014, 04:21 AM   #21
thkfast
thkfast's Avatar
Drives: '14 Red 2SS/RS/LS3
I'm glad this DIY has helped some people tackle this time consuming, but relatively safe and easy appearance mod. The beauty of it is, you pick the color and what decals (if any) you want to apply. The key was unbolting the brake line mount which is about 16" away from the caliper, this allows you to pull that caliper out into the open, paint both the front/back of the caliper and protect the car from overspray. I do recommend doing 2 calipers at once because it allows you to alternate painting one caliper while the other is drying.
It would be nice if Chevrolet would offer painted brake calipers as an option like they do on the new Corvette. Oh well.
thkfast is offline   Reply With Quote
Old 03-19-2014, 10:48 PM   #22
MikeInAZ
MikeInAZ's Avatar
Drives: 2014 Camaro 2SS/RS 1LE, AGM
Excellent job, looks amazing!!! ...And a stellar write-up!!!
Roto-Fab CAI, #8 Fuse Pull, 1LE Emblems, misc cosmetic changes, and a mod list that is a mile long.
MikeInAZ is offline   Reply With Quote
Old 04-02-2014, 07:27 PM   #23
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Do you remember who did you bought the decals from? i searched ebay and there are plenty for the Brembo decals but only a few will do the correct Chevrolet pattern.
christianmotox is offline   Reply With Quote
Old 04-03-2014, 01:54 AM   #24
thkfast
thkfast's Avatar
Here ya go. They're kind of hard to spot at first because the photo the seller uses is of a stock SS Brembo caliper, not the STICKERS! You can order any color combo you want. I wanted as close to 1LE look as possible, so I specified White CHEVROLET and black BREMBO (make sure you specify what color you want). If you look real close, you'll notice the font isn't "exactly" the same as the 1LE calipers, they balloon out in the center - meaning the middle letters are phyically larger than the first and last, but it's so close, no one has called me out on it. $16 and he makes the front stickers larger than the rears too.
http://www.ebay.com/itm/CHEVROLET-BR...r#ht_601wt_916
Old 04-03-2014, 01:58 AM   #25
christianmotox
Drives: ( . )( . )
Awesome, thanks men.
Old 04-03-2014, 12:12 PM   #26
caverman
caverman's Avatar
Drives: '69 SS Convertible
Very Nice!
This needs to be posted over in the DIY section.
Build Journal
Old 05-11-2014, 06:55 PM   #27
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
is the gray engine enamel primer completely necessary? will it still look the same even if i didn't use it? thank you
Tmick5jr is offline   Reply With Quote
Old 05-21-2014, 02:31 PM   #28
CamaroBlue
CamaroBlue's Avatar
Drives: IBM 2010 Camaro SS
Thanks for this DIY. I did it over the weekend and the job came out great. My decals... not so much. Like you said you need to be sure to place them EXACTLY where you want them because they are not coming off. I would suggest trimming down the paper to align them better. Despite my mistake I am very satisfied with the results.
CamaroBlue is offline   Reply With Quote
