Emblempros
Old 02-28-2014, 09:29 AM   #1
AZ5G
AZ5G
AZ5G's Avatar
Drives: 2010 Transformer Ed. 1SS M6
Bump Steer
Getting ready to install BC's and drop the Bee...Anyone had issues with bump steer/Tie rod end issues? I was going to be safe and pickup the rod ends from LSR...Thanks...AZ5G
AZ5G is offline   Reply With Quote
Old 03-01-2014, 09:19 PM   #2
AZ5G
AZ5G
AZ5G's Avatar
Hmmm....Looking at the geometry in the rear I wouldn't have considered that there'd be an issue with the rear...I'm guessing that I'll end up about 1.75F and 1.5R drop. I've searched the forum but haven't found many posts related to Tie rod/axel issues from lowering the car. ..Time and tools are not an issue.....Thanks for the input...AZ5G
Old 03-02-2014, 12:51 PM   #3
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
When lowering the rear over an inch, the hard OEM CV boots can fail.It happened to me!
rockrau is offline   Reply With Quote
Old 03-02-2014, 03:27 PM   #4
AZ5G
AZ5G
AZ5G's Avatar
Are there any aftermarket boots or just OEM replacements??? Guess all that time I spent in Afganistan left me a bit out of the G5 loop....Anyone else have any other "Need to Know" things I should consider prior to diving in??? I really, really, appreciate all the feed back...Thanks guys...AZ5G
Old 03-02-2014, 07:52 PM   #5
rockrau
rockrau's Avatar
The Drive Shaft Shop(a vendor here) does a road course upgrade. I highly recommend it!
Old 03-02-2014, 10:20 PM   #6
AZ5G
AZ5G
AZ5G's Avatar
AZ to PA....Could be a long trip...Any ideas as to what their upgrading??? I've found a couple of leads here on the forum for a few shops around the Phoenix area...I'll do some more searching here on the forum for some more "Precautionary Measures"...Thanks for your input....AZ5G
Old 03-03-2014, 04:15 PM   #7
rockrau
rockrau's Avatar
Going back to the opening post, why are you asking about "bump steer"?
Old 03-04-2014, 11:44 AM   #8
AZ5G
AZ5G
AZ5G's Avatar
I've been trying to find out if anyone has had any issues with tie rod ends after lowering the car. I do intend to go lower that 1". I went ahead and ordered the tie rod ends from LSR...Just to be safe.... I will make sure that I get the axels redone prior to putting things back together....Thanks for the Drive Shop advice....AZ5G
Old 03-04-2014, 05:59 PM   #9
rockrau
rockrau's Avatar
What does tie rod ends have to do with "bump steer"?
Old 03-05-2014, 09:24 AM   #10
AZ5G
AZ5G
AZ5G's Avatar
Under sever load, hard braking, the toe angle changes...Puts extraordinary stress on the tie rod ends...Front end does some interesting things. I've had issues prior to lowering the car. That will not be an issue with the new LSR tie rod ends as I can set the toe angle with the suspension loaded.
Old 03-05-2014, 03:36 PM   #11
Rob@WretchedMS
Drives: His Wife Crazy
Does your alignment shop have the ability to measure bump steer?
Rob@WretchedMS is offline   Reply With Quote
