Gen5DIY
Old 03-03-2014, 07:40 PM   #1
Laudi G
Drives: 2010 chevy camaro 2ss Black w/gray
The circle things on top of the brake pads
Just recently put some new brake pads on my 2010 camaro and the dealership said I need to install factory brake pads because of the circular weights that are on top of the pads. Just curious as to what those are and what there purpose is, and do I need to use factory pads for the rear as well or is aftermarket the exact same thing
Laudi G is offline   Reply With Quote
Old 03-03-2014, 07:42 PM   #2
SPCBA
Drives: pleather and Chiclets
Noise reduction. Affectionatly called rollar skates
SPCBA is offline   Reply With Quote
Old 03-03-2014, 07:46 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Dealership just wants you to spend money with them!!! Lot's of people buy aftermarket pads without the rollerskates with no issues at all. It's up to you.
blazzin1 is offline   Reply With Quote
Old 03-03-2014, 07:57 PM   #4
Laudi G
O ok well i bought the factory ones cause i was told by the dealership that pads with those circle things would only work for the brembo braking system but i guess ill chalk this up as a lesson learned
Old 03-04-2014, 12:15 AM   #5
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
For my driving habits, when I replace my factory pads they will be with factory pads, will I be able to reuse those roller skates, or will I need to replace them? Do they come with the new set of OEM pads? The OEM pads are more than efficient for my braking needs.
Dimitrim is offline   Reply With Quote
Old 03-04-2014, 04:39 AM   #6
SPCBA
Oem is a great pad....
The weights come on pad.
