Jason 98 TA
Old 03-04-2014, 03:29 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
wanting sway bars ASAP!
So everyone is outta stock of the hotchkis Competition sway bar kits. They are much stiffer come with end links. Does any venders have this kit in stock or have a kit comparable?
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-04-2014, 04:00 PM   #2
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
I just ordered a rear bar from LSR. They appear to be a quality product and currently on sale.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 03-04-2014, 05:01 PM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
LSR fronts and rears here, they are great quality.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan coil overs, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Dynamat, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 03-04-2014, 07:43 PM   #4
Dubscamaro
Living Life in MPH.
Dubscamaro's Avatar
Drives: 15 Summit White 2SS 1LE
http://www.lsrperformance.com/2012-u...-endlinks.html CHEAP
Dubscamaro is offline   Reply With Quote
