Old 03-04-2014, 06:14 PM   #1
firedrop
Drives: 2012 2ss/l99 a6, victory red
wtf happened?!
28º out and i took a turn a bit too fast- drifted sideways through the turn going 20-30mph and had to counter-steer like crazy to get back in a straight line.. after that, the steering wheel was shaking violently and the car felt really wobbly. it went away after 20-30 seconds, but now i notice when i drive 50+mph the steering wheel is shaking a bit and it's a tad wobbly. wtf happened? this all happened an hour ago. i did NOT hit anything. just drifted sideways while counter-steering.
2012 2ss l99/a6
CAI, custom catback with flowmaster series 10s
firedrop is offline   Reply With Quote
Old 03-04-2014, 06:35 PM   #2
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Not an expert, but here's what I'd do:
Check all lug nuts for proper torque, check front strut mounting bolts top & bottom.
Did you have a recent alignment? Maybe they didn't tighten all the bolts and it's way, way out of adjustment now.
Meh
My 5th is offline   Reply With Quote
Old 03-04-2014, 06:40 PM   #3
firedrop
nope no alignment on the car, only 10,000 miles on it
2012 2ss l99/a6
Old 03-04-2014, 07:16 PM   #4
firedrop
I fixed it.. there was ice in the wheel
2012 2ss l99/a6
Old 03-04-2014, 07:23 PM   #5
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
I got in on film ->
Glad you were able to save it!
45thAnniversary2SS is offline   Reply With Quote
Old 03-04-2014, 11:26 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Not only that but if you have the OEM Perelli tires they suck at that temp.
Build Journal
Old 03-05-2014, 12:38 AM   #7
My 5th
My 5th's Avatar
That would have been my third guess. I have water accumulate in the inner barrels of my Forgeline wheels when it rains and it makes them go out of balance. They make a thing called a water diverter that mounts to the inner barrel that pushes the water out to prevent that. It would be pretty severe if that water froze when the car was parked. 3 or 4 ounces of ice would make a big shimmy.
Meh
