Old 03-04-2014, 06:09 PM   #1
sac130e
Drives: 2014 Camaro SS/RS BRM
One Person Brake Bleeding
Weighing option of painting calipers myself or removing as sending to Mike for powdercoating. My biggest concern would be reinstalling the caliper and bleeding the system.
I would be doing this alone, and need advise on best approach to doing this. Have seen the threads, and they use 2 people, so would picking up a vacuum pump locally be best method?
And guessing from reading, there are 2 valves on each caliper?
Thx
sac130e is offline   Reply With Quote
Old 03-04-2014, 06:57 PM   #2
sac130e
Originally Posted by 130R View Post
I bleed mine myself with a pressure bleeder. I made my own, but these work well.
Yes, 2 bleeders per caliper..
Thx, but way more than I am looking to spend for bleeding tool.
Old 03-04-2014, 07:16 PM   #3
jvoisel
Drives: 2010 2SS/RS M6
Harbor Freight sells a pressure bleeder I believe.
You can't find anyone to pump the brakes for you?
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 03-04-2014, 10:24 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Have Mike do them. They look fantastic afterwards.
Why can't you get someone to pump the brakes for you? Hell, last time I did mine I had my 72 yr old mother pump the brakes for me. Surely you know someone that can sit in the car and pump the brakes for you.
Build Journal
Old 03-05-2014, 07:50 AM   #5
sac130e
All solved, thx for the help and info
Old 03-06-2014, 09:12 AM   #6
h018871
Geoff
h018871's Avatar
Drives: 2013 1LE Blue
Mitivac and put grease around the bleed nipple threads. $30
Standard mods: cam, headers, cai..........etc
modifications: http://www.camaro5.com/forums/showthread.php?t=332717
h018871 is offline   Reply With Quote
Old 03-06-2014, 01:15 PM   #7
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I worked for Midas for years, gravity bleed first and then just a few pumps on each caliper and push the piston back in usually does it for me.
