HeadlightArmor
Old 03-04-2014, 08:43 PM   #1
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Need advice on where to go next on suspension.
I've got an extra $600 from tax return to put into the car, pretty sure it needs to go towards suspension but don't know which direction to go in with the budget.
Was leaning towards lowering springs (either 1inch or 1.2inch not sure which) and something else. Any advice would be appreciated.
2012 SS L99 Currently equipped with:
Magnaflow 16483 exhaust
SP long tube headers 1 7/8th
Magnaflow HF cats
Adm race CAI w scoop
Ls3 conversion
Gt 11 cam
Adm tune
MM ported TB
3.45 gears
Strut Tower brace
Solid Subframe Brushings
Scuzz is offline   Reply With Quote
Old 03-04-2014, 10:06 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I would suggest a full set of BMR Sways (SB037), and front end link kit (ELK005). And don't forget about this….
http://www.camaro5.com/forums/showthread.php?t=344278
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 03-04-2014, 11:16 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
Depends on what you want. In my book lowering springs would be (and was) one of the first things I would do. That'll eat up about $400 with and alignment. Don't forget to have your bushings timed.
Then look at swaybars if you like cornering or cradle bushing inserts if want your car too feel more firmly planted. You'll want both eventually. Check out Whiteline for cradle bushing inserts since Pedders is out of the picture for now.
EDIT: just noticed you have the solid bushings and from all your stuff I'm guessing all done by ADM. That will narrow it back down to sway bars or lowering springs. I suggest springs because these cars look like 4x4 stock IMO. I'm also assuming you live fairly close to ADM and we don't have much for cornering around here unless you run some Auto-X events. Again, you'll eventually want both but it's just a matter of which one first.
Build Journal
Old 03-05-2014, 12:34 AM   #4
Scuzz
Scuzz's Avatar
Thank you for the advice.
If I may ask a side question, I was wondering if you could explain to me why you offer adjustable and non adjustable trailer arms and toe rods. Why would I pick adjustable over non adjustable or visa verse?
Many thanks for your answer in advance.
Old 03-05-2014, 10:16 AM   #5
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Hotchkis 1 inch springs and adjustable sway bars.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 03-05-2014, 10:59 AM   #6
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Springs and Sway Bars!
BMR, Hotchkis and Eibach are all good choices!
PM or Call me with any questions.
Thanks
JT
Team STILLEN is offline   Reply With Quote
Old 03-05-2014, 11:43 AM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I've seen too many people regret getting springs simply because within a year or two they want more, here's the next step without getting crazy expensive:
For an extra $300 (although I'm sure if you PM'd them, you could get a camaro5 discount):
http://ohio-speed.com/p-4179-2010-20...cdk-cca10.aspx
Adjustible height, adjustible dampening. Better performance and more control over springs alone.
Multiple birds with one stone.
Link to the classifieds post:
http://www.camaro5.com/forums/showth...ighlight=megan
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-05-2014, 12:14 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
In many cases, lowered cars need more adjustment capability to obtain the correct toe and camber settings. The adjustable trailing arms and toe rods help to provide that capability over and above the range of the factory settings. Also, for racing applications, sometimes it is necessary to adjust those setting for that particular scenario, whether it be drag racing or autocross. Again, the adjustable trailing arms and toe rods work together to provide that capability without disturbing the factory connection settings. Ultimately, a full set of adjustable trailing arms, toe rods, and lower control arms provide all the alignment adjustment needed in just about any situation.
T.C. Davis
813-986-9302
Old 03-05-2014, 01:09 PM   #9
Scuzz
Scuzz's Avatar
If I was planning only to lower the car 1 inch using lowering springs, and i didn't plan on doing constant adjustments, more like a set it and forget about it kind of mentality, would i be ok with non adjustable? or would you recommend adjustable?
Old 03-05-2014, 01:23 PM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
You should be okay with just a 1" drop. In all but the most unusual cases, you can obtain the correct alignment specs with the factory adjustments with the 1" drop springs.
T.C. Davis
813-986-9302
Old 03-05-2014, 03:20 PM   #11
Rob@WretchedMS
Drives: His Wife Crazy
If you have a budget of 600, how long would it take to raise that to a $1000 budget?
Coilovers are the way to go on the camaro, when you do just the lowering springs (especially on the V6) I hear a lot of complaints about ride quality, but not so many with coilovers complain.
If i can help let me know, even if you want advice on parts i don't sell, i'll do what i can to help
Rob@WretchedMS is offline   Reply With Quote
Old 03-05-2014, 09:49 PM   #12
Scuzz
Scuzz's Avatar
I want to thank everyone for their advice. It was very helpful.
I decided to go with the following: couldn't pass up 20% off.
BMR Fabrication Driveshaft Tunnel Brace,
BMR Fabrication Springs - Red, Set of 4, 1.0" Drop,
BMR Fabrication Sub-frame Connectors,
BMR Fabrication Toe Rods,
BMR Fabrication Trailing Arms,
BMR Fabrication Rear Trailing Arm Bushing
Old 03-06-2014, 10:52 AM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Awesome list of parts!!! You won't be disappointed. For your next upgrade, I would suggest our new rear upper control arm bushings (BK039) to complete the rear suspension.
T.C. Davis
813-986-9302
Old 03-06-2014, 12:51 PM   #14
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
I would say bushings
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
