JUICEDMOTORSPORTS
Old 03-05-2014, 08:49 PM   #1
Shift_Rejected
2010 2SS RS
Shift_Rejected's Avatar
Drives: 2010 2SS RS (L99)
Thumbs down A Video that Will Make Your Ears Bleed
Attempts to date:
  • -Replaced Brake Pads (semi-metallic) = Unbearable Squeal
  • -Replace Brake Pads Again (ceramic) = Unbearable Squeal
  • -Pulled everything apart covered all appropriate parts in a bunch of brake grease = Still Squeals
  • -Pulled Off Rotors and Resurfaced = Still Squeals
  • -Covered rotors in spray on anti-squeak / resurface = Still Squeals
  • -10-20 pulls in a parking lot 40mph - 20mph to bed = Stopped squealing for 1 week / Only Squealed when hot
  • -Tonight drove down a highway for 1/2 hour stopping and going from 60mph 80mph 40mph until I went partially deaf = After they cooled down, the squeal was quiet or non existent.. Will see how long it lasts
Am I missing anything to fix this embarrassing noise?? When bad, it's easily heard from 1/4 mile away over longtubes and muffler delete..
Now on to the feature presentation...
~ Build Thread | 371HP & 390 TQ
Performance Mods: K&N Cold Air Intake | Pypes Cat-Back Exhaust | Aluminum Paddle Shifters | VaraRam Wedge | Cross Drilled/Slotted Rotors | Hawk HPC Pads | M.M. Ported Throttle Body | Kooks 1 7/8 Headers w/ High Flow Cats | Dyno Tune @ RPM
Cosmetic Mods: Rally Stripes (style1, style2, style2.2) | Splitter | Painted Calipers | Door Projector Lights | Front-Emblem Delete | Cup Holder Lighting | Quarter Window Covers | Phantom Grille | Ghosted Side Markers | Tinted Fog Lights | ZL1 Rockers | Tail Light Bezels
Shift_Rejected is offline   Reply With Quote
Old 03-05-2014, 09:08 PM   #2
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
Sounds like a bus. I know it would drive me crazy also.
Do you have stock or drilled/slotted rotors? They can be a little noisy.
Long time ago GM switched Camaro to organic brake pads due to customers complaining. That was before ceramic brakes. A top quality ceramic brake should fix it. Or get the OEM
maddoggyusa is offline   Reply With Quote
Old 03-05-2014, 09:08 PM   #3
maddoggyusa
pad.
Old 03-05-2014, 09:14 PM   #4
Shift_Rejected
2010 2SS RS
Stock rotors with Wagner Quiet Stop Ceramics (ironic).. OEMs might be my next stop, I know they had those roller blades on them to help.
Also, I see your from Jersey, if you face the river and listen on a quiet night you may just hear them..
Old 03-05-2014, 09:24 PM   #5
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Which wheels are squealing? I noticed you have a 2010. Do you still have the wheel weights on the calipers or did yours come equipped with the roller skates? Some people have experienced a squealing after removing the weights and not really knowing what there for.
IMO your pad bedding is not aggressive enough. I suspect this might be your problem since you state the sequel got better after bedding.
I just saw your previous post. Those roller skates are there for noise reduction. Get some OE pads and that will help.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-05-2014, 09:41 PM   #6
nitto85
Caffeine Injected
Drives: Chevrolets!!
Are the pads wearing evenly?
nitto85 is offline   Reply With Quote
Old 03-05-2014, 09:44 PM   #7
Shift_Rejected
2010 2SS RS
Wheel weights are still on there but perhaps some serious agressive bedding is needed..
I'm not sure, they ahve only been on for about 1k miles
Old 03-05-2014, 09:49 PM   #8
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
That sucks, maybe the stock pads with the skates will help.
christianmotox is offline   Reply With Quote
