ADM PERFORMANCE
Old 03-06-2014, 09:49 AM   #1
chuckclanton
Drives: 2016 Camaro 1/SS
Pedders lowering spring rates found!
As Pedders USA is gone, I went to a UK Pedders site and found their springs 220032 & 220035 listed. Requested spring rates from them via e-mail.(see attached). Rates are 130# front and 433# rear. Sorry about the quality of the attachment.
chuckclanton is offline   Reply With Quote
Old 03-06-2014, 10:00 AM   #2
chuckclanton
Fixed attachment.
Old 03-06-2014, 03:34 PM   #3
jgalewsk
Drives: 2013 Summit White Camaro 2SS RS 1LE
130 seems really low for the front. Never ridden on them but it just seems low compared to other manufacturers...
jgalewsk is offline   Reply With Quote
Old 03-06-2014, 04:46 PM   #4
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I remember they were stiffer then that, around 220+ for the fronts
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 03-06-2014, 08:20 PM   #5
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
130kg maybe. this is english pedders.
DietCoke is offline   Reply With Quote
Old 03-06-2014, 09:20 PM   #6
VR Baron
VR Baron's Avatar
7kg is 450 lb springs fyi
Old 03-06-2014, 09:59 PM   #7
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
To the OP can you please ask for clarification on the rates. 130 in/lb seems too low, 130 nm and or Kg is way too high.
Thanks,
Matt
Old 03-07-2014, 05:39 AM   #8
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
130# isn't that low... mine are less then that. They aren't road performance springs though.
Old 03-07-2014, 06:38 AM   #9
Dropspeed
Dropspeed's Avatar
I assume you have a car setup for drag racing?
Old 03-07-2014, 08:45 AM   #10
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
yep. its pretty light too. id expect a stiff road spring to be 200-250#
Old 03-07-2014, 10:56 AM   #11
EarlyApex
Drives: 2013 IOM 2SS 1LE
BMR lists their 1" lowering springs at 220 lbs front and 460 lbs rear. Maybe it's supposed to be 230, not 130 lbs. Could just be a typo.
EarlyApex is offline   Reply With Quote
Old 03-07-2014, 01:11 PM   #12
chuckclanton
Is what it is! lighter spring in front(but probably taller than other drop springs unloaded) and stiffer spring in the rear, equals much less understeer in a stock SS.
Old 03-07-2014, 01:29 PM   #13
VR Baron
VR Baron's Avatar
Doubt its right. Member near me had them after getting rid of the Pfadt springs. Said they were quite a bit more stiff
Old 03-07-2014, 01:34 PM   #14
Rob@WretchedMS
Drives: His Wife Crazy
The springs are progressive, you can't really rate a progressive spring like that.
Rob@WretchedMS is offline   Reply With Quote
