Flowmaster Exhaust
Old 03-07-2014, 02:28 PM   #15
chuckclanton
Drives: 2016 Camaro 1/SS
Originally Posted by Rob@WretchedMS View Post
The springs are progressive, you can't really rate a progressive spring like that.
Lots of speculation here. Seems the dealer who sales them in the UK might just have an inside tract on them. Any why wouldn't Pedders USA ever give out the info? Maybe due to the out of sync rates compared to other vendors! Their website is http://www.pedders.co.uk/
chuckclanton is offline   Reply With Quote
Old 03-07-2014, 02:29 PM   #16
Rob@WretchedMS
Drives: His Wife Crazy
or maybe he's just wrong.
Rob@WretchedMS is offline   Reply With Quote
Old 03-07-2014, 02:37 PM   #17
chuckclanton
I'm sure you mean half wrong as there seems no opinion regarding the rear springs.
Old 03-07-2014, 02:47 PM   #18
chuckclanton
I sent a response back to:
Pedders UK with a request to double check the 220032 spring rate as my peers find it hard to believe. If I get a response I will post it.
Old 03-07-2014, 02:49 PM   #19
Rob@WretchedMS
It's a progressive spring, the rate changes with compression, so to give you a rate will depend upon the compression.
Old 03-07-2014, 05:51 PM   #20
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I think most here are gauging by what the mfg's all state they are 220/440 etc. just to compare. We all know they are progressive and it will vary,I cant recall what I saw as Pedders rates, on a thread here somewhere but were advertized as being close to the others
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 03-07-2014, 06:43 PM   #21
chuckclanton
The rates have never been advertised by Pedders USA . However one would think that Hotchkis or BMR evaluated them and know but have not
given out the info. Mute point as I have installed Hotchkis springs as the Pedders rates were unknown per anything found on the forum or google.
Old 03-07-2014, 07:21 PM   #22
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Pedders have always been advertised as being linear not progressive.
Old 03-07-2014, 07:30 PM   #23
VR Baron
VR Baron's Avatar
I thought so but has been awhile so couldnt remember
Old 03-07-2014, 07:32 PM   #24
VR Baron
VR Baron's Avatar
I saw it here somewhere. might have been a post from Pete, cant remember but seems they were similar to the others, however being linear they felt stiffer from what a freind said vs pfadt Preffered my Hotchkis to them
Old 03-07-2014, 08:38 PM   #25
sting808
Drives: 2010 SS RS
Last year, Pete mentioned the stock front rates were a progressive something to the order of 140lbs/ft > 150 > 160 based on spring compression. I needed a softer 2.5" coil on my XAs to pass local reconstruction permit for a stupid bounce test and OE reference to prove my case.
Most front drop springs are in the mid 200s. Rears are typically double that # or higher. 130lbs/ft sounds a little low.
It's hard to find archived posts using subject since they may not appear in the advanced search. If you search by member name, you may find the Pedders spring rate post that way. XAs come with 8kg/10kg. 448/560 lbs/ft
sting808 is offline   Reply With Quote
Old 03-08-2014, 05:33 AM   #26
Dropspeed
Dropspeed's Avatar
Above it looks like you are talkin about coil overs. The OP have parts numbers for the sport Ryder which is just the spring on the stock strut.
Matt
Old 03-08-2014, 08:04 AM   #27
sting808
Drives: 2010 SS RS
There was an older posting with the drop spring rates. Pretty much everyone's front drop spring rates were in the 200s. Similar to the front coilover rates of most brands. Only Pedders/BC shipped with stiffer 448lbs/ft(8kg) front coilovers. Pedders front drop springs were much softer, but firmer than the stock 150s. I looked at them back in 2009 before going with the coilover option.
Old 03-08-2014, 10:03 AM   #28
chuckclanton
Attached are all e-mails with Pedders UK. remember read bottom up as it is a continuing e-mail. Bottom line, Roger says the same, 130#. Anymore interest I gave this e-mail address. However I did respond with the concern of banging into the stops and questioning if the springs may be progressive and the 130# was the initial rate.
