BeckyD @ James Martin Chevy
Old 03-06-2014, 01:29 PM   #1
apexslider
Drives: 2014 AGM 1SS/1LE
Steering Ratio
I'm new to electric powere steering, and have a 14 1SS 1LE. After puting a couple thousand miles on it, I want a lower steering ratio. My last car was a very built STi that had a 11.5:1 steering ratio (oem was 14:1), it was one of the best mods I've done to any car. Is there anything available for the electric units like that?
I know sways, bushings, caster, and set up will change the steering feel to make it feel quicker, but I'm looking for something more drastic than that.
apexslider is offline   Reply With Quote
Old 04-03-2014, 11:24 AM   #2
Arubberbaby
141LE
Arubberbaby's Avatar
Drives: 14 AGM 1LE
I know if you put the traction control in comp mode or turn it off. It tighten's steering feel a good bit.
Arubberbaby is offline   Reply With Quote
Old 04-03-2014, 01:13 PM   #3
EarlyApex
Drives: 2013 IOM 2SS 1LE
Changing the front radius arm bushings to Whiteline steel jacketed urethane will make the steering feel quicker and more responsive. One of the best suspension mods you can do.
EarlyApex is offline   Reply With Quote
Old 04-03-2014, 05:22 PM   #4
Arubberbaby
141LE
Drives: 14 AGM 1LE
I have the radius rod bushes in my room, I need to put them in.
