Caryle Racing
Old 03-08-2014, 10:51 PM   #1
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
Eibach springs question, help!!
Ok, so I have a set of pro-kit lowering springs and they were installed correctly and everything seems fine...except..well, you'll see in the pictures. So whats going on here? The front of the car is higher than stock and the rear is slammed. These are suppose to be 1" lowering springs. part # 38144.140
Do they need time to settle? It just seems so drastic. First picture is the front of the car, 2nd picture is the back. This is on a 2010 camaro with 2013 springs, part numbers are a exact match so it shouldn't matter.
mcdoogle6969 is offline   Reply With Quote
Old 03-09-2014, 11:45 AM   #2
mcdoogle6969
81 views and not a single response? lol...
Old 03-09-2014, 12:07 PM   #3
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
It's hard to tell because the first picture is dark, but the coils look closer together on the front than mine (like the back coils are on the front?). Are the coils seated properly back into the cradle on each end? Is the 24MM nut screwed down all the way? I watched this video before doing mine and kept me on the right track. If you are confident on all the above, then it is entirely possible you have been given the wrong springs, or the wrong springs are in the right box. No doubt it is incorrect though.
I can't go look at mine right now because it is getting some upgrades - sorry!
Turbocharged with Huron Speed & Cammed with Cam Motion from Spartan Performance, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock, Turbosmart controller, MSD 2-Step, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, CAI, Cherry Bomb, blackouts, Lowered, Custom badges, VDI lambo doors, Hines vents,RPI fender vents, BlackVue 1080P Dashcam, Technostalgia Tail Lights, KW 500W on 10", Metra Kit, Pioneer AVH 4600BT, Morimoto RGB Halos, Tuned by Pat G
SeaCompiler is offline   Reply With Quote
Old 03-09-2014, 12:49 PM   #4
littlebuffalo
Drives: 2013 Camaro 1LE
Go drive around should settle out.
littlebuffalo is offline   Reply With Quote
Old 03-09-2014, 12:59 PM   #5
mcdoogle6969
They're definitely where they're suppose to be. Everything looks seated properly too, It's just odd how the fronts are higher than stock, and the rears are MUCH lower than 1". it would suck to find out that they're the wrong springs, but they look like the ones they picture.
Old 03-09-2014, 03:50 PM   #6
Go big or Go home
Go big or Go home's Avatar
Drives: 2010 Camaro 2LT RS
Assuming you moved it off the rack before taking this picture... I'd call Eibach and verify the part number that is directly on the springs themselves. It may be different then the part number on the box. Doing that will verify that the correct springs were in the box. As long as you moved it before taking the pictures, it's not just going to settle evenly.
Go big or Go home is offline   Reply With Quote
Old 03-09-2014, 04:46 PM   #7
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
Ya that really doesn't look right when I lowered my car with the same eibach pro kit. It was much lower. Both in the front and in the back. I would call eibach about this
SoFlo Muscle Car Group
Miami/Broward
954camaro is offline   Reply With Quote
Old 03-09-2014, 07:50 PM   #8
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
Looks way high, are they installed correctly? That looks higher than stock.
IMPERIALBLUE2SS is offline   Reply With Quote
Old 03-09-2014, 09:20 PM   #9
NC-V
NC-V's Avatar
Drives: cts-v
That is definitely too high, something is not right. I'm kinda with SeaCompiler on this one. It is hard to tell from that first pic, but it looks like those are either incorrect springs or the rear springs. The front springs should be beehive like in shape, just like the ones in that phastek video shot. The rear springs would be small at the bottom and larger at the top, with 3-4 same size coils very close to each other at the top.
NC-V is offline   Reply With Quote
Old 03-09-2014, 09:50 PM   #10
mcdoogle6969
unfortunately I'm not at the shop right now and can't get you guys a better picture, I'm going to give them a call tomorrow and see whats going on. Thanks guys
Old 03-09-2014, 10:31 PM   #11
MonsterV6
MonsterV6's Avatar
Drives: Chevrolet Camaro
These are installed incorrectly, switch the springs front to back.
I did this when I installed my stocks back on. The front was high AF! And the rear was slammed. Never again while drinking beer lol
MonsterV6 is offline   Reply With Quote
Old 03-27-2014, 12:40 PM   #12
Landito86
Drives: 2014 SS/Summit white
Was this ever resolved? What was the outcome? I am having same issues at my shop.
Landito86 is offline   Reply With Quote
