Solo Performance
Old 07-28-2009, 09:31 PM   #1
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
Suggested mounting point for AEM UEGO sensor on ARH headers and exhaust
Without being able to go under the car with these headers installed I can't tell where is the best location to mount this to keep out of the way of other parts. Anyone got a suggestion? One side over another?
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 07-29-2009, 10:45 AM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I'm sure someone will chime in, I'm just wondering .. where in the car are you going to mount the gauge?
thanks,
Crowley
Crowley is offline   Reply With Quote
Old 07-29-2009, 12:06 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I bet you'll have to have an exhaust shop weld in a bung off of one of the collectors.
JMO.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-29-2009, 12:08 PM   #4
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
JMO.
I agree....that would be the most durable and cleanest way to go!
ZZcamaro is offline   Reply With Quote
Old 07-29-2009, 03:03 PM   #5
SoloSK71
SoloSK71's Avatar
thanks,
Crowley
Without having the vehicle right in front of me to measure I am not completely sure, but I am hoping it can be mounted to the left of the wheel and will sit above or below the dashdaq. Since I will more interested in logging than watching, the location is not as important.
- SK
- 2G1FT1EW9A9132212
Old 07-29-2009, 08:48 PM   #6
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
solo, disable the bank 2 sensors, and tune to one side, then switch sides to verify AFR.
youll prolly throw cat codes.
will it be 0420 code on this car too?
i always LAUGHED when i got that code. catalyst.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 07-29-2009, 11:56 PM   #7
SoloSK71
SoloSK71's Avatar
I would like to keep all the factory sensors though, especially since I invested ina high end data logger for tuning.
I am guessing t will go somewhere 90° offset at the same point at the existing ones on the collector pipe.
- SK
- 2G1FT1EW9A9132212
Old 07-30-2009, 02:31 PM   #8
Tankrust
Tankrust's Avatar
Drives: 2010 Camaro 2SS/RS/6MT
The AEM UEGO sensor needs to be installed so that the sensor body is at an angle above horizontal relative to the ground. This is to prevent accumulation of condensation on the O2 sensor tip. The sensor has a heating element that burns off the condensation, but if it accumulates excessively it can ruin the sensor.
Keep in mind if you have not used a UEGO before, the gauge is very bright and busy. There is no way to dim the lighting. Also, you must keep the gauge powered if you are going to keep the WBO2 sensor installed in the exhaust. It provides the power to the heating element in the sensor itself. In other vehicles I have installed the gauge in a pod in the glove compartment. That way, if I want to look at it I can, but I keep it shut otherwise. I usually just use the UEGO RS-232 output for AFR logging with a laptop.
HotSS has a good idea if you only need to use the gauge when tuning. If you want to log all of the time, you will need to get a bung for the sensor welded on one side or the other. The spot where the existing front bung is located looks good, 90 degrees out like you said.
Tankrust is offline   Reply With Quote
Old 07-31-2009, 12:07 AM   #9
hot ss
hot ss's Avatar
- SK
what you get??, i just use HPT pro. i have a nice little egt guage that puts out 0-5v as well. now where can i hide it all so the wife doesnt see it. i also use an innovate lm-1 with tail sniffer and a aem uego, and i use stereo jacks to quick connect to egt, and afr.
Old 07-31-2009, 08:21 AM   #10
SoloSK71
SoloSK71's Avatar
So far just an AEM UEGO and the DashDAQ.
Got the DashDAQ for PC and CarDAQ-Plus cable to be able to program.
I may add a 3-axis accelerometer from Phidgets. Trying to find a 10Hz or 20Hz GPS sensor for recording track positions.
- SK
- 2G1FT1EW9A9132212
Old 08-18-2009, 07:59 PM   #11
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
- SK
like hot SS said, tune one side then the other.
or... another way I was pondering...
might be a little tricky to do, but have the bung installed at the X pipe
I piss excellence
and fart awesomeness
Old 08-21-2009, 07:42 PM   #12
SoloSK71
SoloSK71's Avatar
Except installing there is after the cats and will not read correctly, I think?
- SK
- 2G1FT1EW9A9132212
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
RATING HEADERS??? SAUCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-02-2011 09:21 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 07:39 AM
