third_shift studios
Old 03-12-2014, 01:20 PM   #1
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
Rear Spindle/Knuckle Bushings
Who makes a improved or better than stock bushing that goes into the rear spindle/knuckle there are 3 of them toe rod, trailing arm, and LCA. There has got to be a better bushing to stabilize an prevent wheel hop in these locations.
Old 03-12-2014, 02:06 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Bmr does....that's who I bought mine from.
Lil' Nasty is offline   Reply With Quote
Old 03-12-2014, 02:53 PM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
BMR offers a low deflection polyurethane bushing (BK006) for the outer Trailing Arms. Depending on which BMR toe rods you buy, they include either polyurethane bushings or spherical rod ends. The outer lower control arm joint is a factory spherical bearing with a dust boot on it. It's a pretty good joint, and no real reason to replace it. If you're still having wheel hop issues after replacing trailing arms and toe rods, I would consider changing out the rear upper control arm bushings. I highly suggest our new BK039 that comes with a delrin bushing already mounted in the bracket. This is about 600% easier than trying to press out the old bushing out of the factory mount brackets!!!
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 03-12-2014, 07:59 PM   #4
Synner
Drives: not stock
BMR or whiteline for the trailing arm and toe rod. Leave the stock control arm bushing alone, it's good.
Old 03-12-2014, 09:04 PM   #5
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I have the tie rods, trailing arms, trailing arm bushings, upper control arm bushings and cradle bushings. 0 wheel hop, 600rwhp through a M6.
cylinder head and throttle body porting
Old 03-12-2014, 09:09 PM   #6
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
do you have to drop the rear cradle to replace the upper control arm bushings (BK039 that comes with a delrin bushing already mounted in the bracket)?
tw78911sc is offline   Reply With Quote
Old 03-12-2014, 09:38 PM   #7
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
No, you don't. I won't say that it's easy, but I was able to do it on my car. Just takes some "creative" use of some hand tools. It can be done. But don't expect to get a torque wrench up there to torque the bolts down. Not that I would ever advocate this…..but I just used some blue loctite and tightened the bolts down "good-n-tight".
blazzin1 is offline   Reply With Quote
Old 03-13-2014, 12:49 AM   #8
Bo White
Bo White's Avatar
You can do upper bushings without even loosening up the cradle?
I wouldn't even try to go through the trouble, just loosen the cradle and drop it down a couple of inches.
Old 03-13-2014, 09:07 AM   #9
Synner
Drives: not stock
Loosen and drop are 2 different things.
Old 03-13-2014, 09:36 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, it can be done without loosening or dropping the cradle....but like I said it's not exactly easy to get the tools up in there. You can loosen the cradle bolts up (liberally) and gain a little extra clearance up in there. Maybe even loosen the front cradle bolts and completely remove the rear. That should give you plenty of room. If doing it this way, I would suggest supporting the rear end or cradle with a floor jack at a minimum.
T.C. Davis
813-986-9302
Old 03-13-2014, 01:16 PM   #11
Bo White
Bo White's Avatar
Yes, understand that but I've heard of people doing it without even loosening before and just wanted to clarify.
Old 03-13-2014, 02:06 PM   #12
Rob@WretchedMS
Drives: His Wife Crazy
The only bushing in the rear knuckle is the rear of the trailing arm, the bushings at the lower arm and upper arm locations are actually spherical bearings and are better than upgraded bushings would be.
Upgrading the toe rod bushings there are a couple ways to go.
1. Upgraded Poly Bushings
2. Upgraded Arm with Poly Bushings
3. Upgrade to the ZL1 Toe Links that have Spherical Bearings in them from GM
Upgrading the Trailing arms you have options 1 and 2.
Those are the only items that have any relation to the knuckle.
Aside from those are the rear Upper arm bushings and the Cradle Bushings which come in 2 options.
1. Inserts that allow you to keep the OE bushings in the car.
2. Replacement Poly Bushings that replace the OE bushings.
The Full bushings provide better support, but are a bit harder to install.
If i can help with anything please let me know, i have a all of the bushings available in both Pedders and Whiteline options i believe.
Rob@WretchedMS is offline   Reply With Quote
Old 03-13-2014, 02:14 PM   #13
Synner
Drives: not stock
Your knuckles will love you a lot more taking the 4 minutes it takes to loosen 4 cradle bolts. You will struggle with access a lot longer than 4 minutes by not touching them.
Old 03-13-2014, 08:07 PM   #14
Bo White
Bo White's Avatar
That's why I said just loosen the bolts up, not worth the hassle not to.
