Old 03-13-2014, 11:25 PM   #1
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Diff service because of C5
Just wanted to share that after reading so many great threads here on C5 I decided to take my ZL into one of my shops to get the rear diff serviced. I did talk to a GM dealership and they advised me it wasn't needed as I have only 12K KM's or about 7K miles on it.
Anyway, the guys ordered in the proper GM diff fluid for my car and I was shocked how dirty the fluid was. It was full of fine metallic fluid and there was a ton of filings on the magnet. I did snap a picture of a sample of how dark the fluid was on a rag. Sorry for the poor picture but there's no flash with an iPad.
I'm going to do it again in a bit and keep doing it until the pattern is set on the ring and pinion and it stops getting dirty so quick. Thanks again for to all the guys who posted and convinced me that this was a good idea. And it was.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 03-14-2014, 05:19 AM   #2
southview
Drives: 08 tahoe, 50 merc
WOW that's scary!
southview is offline   Reply With Quote
Old 03-14-2014, 05:46 AM   #3
jayb53guy
Drives: 2013 ZL1
This is exactly why I just had mine changed after my first 1500 miles, racing or not. Good call keeping an eye on it.
jayb53guy is offline   Reply With Quote
Old 03-14-2014, 08:08 AM   #4
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Yep,
exact same thing happened to me.
Thanks C5ers!
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-14-2014, 08:25 AM   #5
sengli
sengli's Avatar
Drives: 2015 M6 Red Hot ZL1
Did the gears have a good solid pattern on them? Dont think I have eve had a diff open, where I didnt see metallic dust on the magnet. Is it, or was it noisy?
2014 2SS RS NPP 1LE...gone
2015 M6 Red Hot ZL1, Recaros,NPP production #853
sengli is offline   Reply With Quote
Old 03-14-2014, 08:47 AM   #6
Paladinjc
AC Pickles!
Paladinjc's Avatar
Drives: 2014 Camaro ZL1
Curious, Are you guys saying I should not only do the 1000 mile Break In oil change, but I should also do a 1000 mile Diff service as well?
Paladinjc is offline   Reply With Quote
Old 03-14-2014, 08:51 AM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
1500 mile service on the differential by changing the fluid is a must. I have done it on mine and Smitty's and they looked identical when the fluid was drained...disgusting. Must be lots of break in from the posi clutch material or just the marking compound...whatever it is, it can't be good and a fluid change is simple to perform. I have changed mine a second time as well and it looked great in comparison.
'15 Z/28 #325 black a/c & stereo. 2:10.9 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-14-2014, 09:04 AM   #8
Tyler H
XLR8TNG
Drives: 2013 Camaro ZL1
Smile
Relax! What you are seeing is normal. There always is a bit of crap on the magnet. That's what it's for. The fluid darkening over time is also what is supposed to happen from heat cycles. That is why you change it. Just need to make sure the drain plug was wiped off before being reinstalled. Everything you are seeing is normal. Only concern yourself if there are chunks of metal.
Tyler H is offline   Reply With Quote
Old 03-14-2014, 09:54 AM   #9
Octaneman
Octaneman's Avatar
Drives: Camaro ZL1
What he says!
That is not unusual, we see this quite often when changing fluids, and further investigation inside the diff does not show any damage. ENJOY
Octaneman is online now   Reply With Quote
Old 03-14-2014, 11:52 AM   #10
Todd in Vancouver
Drives: 2014 ZL1
I know it's normal but I am a bit anal about servicing my car. The cost on these maintenance items is low so why not just change it. There is no down side to keeping fluids clean so I just do it often.
No I didn't have any noise but with snow tires on it is a bit hard to tell. It may just be my imagination but it does seem to drive better or roll easier after the diff service was done. A little prevention never hurt anyone so why wouldn't anyone do this?
Todd in Vancouver
'14 ZL1 Camaro
Old 03-14-2014, 05:21 PM   #11
Front Runner
Front Runner's Avatar
Drives: 2016 Nightfall Gray Metallic SS
Originally Posted by Octaneman View Post
What he says!
Completely agree.
2016 Nightfall Gray Camaro SS
Front Runner is offline   Reply With Quote
Old 03-16-2014, 08:05 PM   #12
mxkx250
mxkx250's Avatar
Drives: 12 ZL1, 98 Camaro SS, 67 RS/SS
Send a message via Yahoo to mxkx250
Is it best to go with the GM fluids, or is there a synthetic (Mobil 1, Redline, Royal Purple) that would be better?
2012 ZL1, VR, M6, ECF, Polished 5 spokes.
1998 Camaro SS, Red, M6.
1973 Camaro Motion Tribute, Blue, 454, M4
1967 Camaro RS/SS, Black, 350/295, A2
2008 Cobalt SS, Turbocharged, Black, M5
2008 Avalanche LTZ, Black, A4
mxkx250 is offline   Reply With Quote
Old 03-16-2014, 08:14 PM   #13
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
I personally went with Royal Purple
Tyler360 is offline   Reply With Quote
Old 03-16-2014, 09:13 PM   #14
Todd in Vancouver
Drives: 2014 ZL1
I did the GM because there are 3 different listings for diff fluid and mine specifically called for the LS fluid. Also, I was not able to find a cross reference for the fluids we stock at our shop so I thought for warranty purposes I'd stick with the recommended GM spec stuff.
I'm not giving GM any out if mine goes BOOM!
Todd in Vancouver
'14 ZL1 Camaro
