JUICEDMOTORSPORTS
Old 03-16-2014, 10:24 PM   #15
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Originally Posted by Todd in Vancouver View Post
I did the GM because there are 3 different listings for diff fluid and mine specifically called for the LS fluid. Also, I was not able to find a cross reference for the fluids we stock at our shop so I thought for warranty purposes I'd stick with the recommended GM spec stuff.
I'm not giving GM any out if mine goes BOOM!
use the gm stuff in the pic or you will complain of noise...the others don't have the correct additive package GM requires
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-16-2014, 11:24 PM   #16
mxkx250
mxkx250's Avatar
Drives: 12 ZL1, 98 Camaro SS, 67 RS/SS
Send a message via Yahoo to mxkx250
Good advice. I will take it.
2017 LS Camaro Hyper Blue,Turbo, M6.
2012 ZL1, VR, M6, ECF, Polished 5 spokes.
1998 Camaro SS, Red, M6.
1973 Camaro Motion Tribute, Blue, 454, M4
1967 Camaro RS/SS, Black, 350/295, A2,
2008 Avalanche LTZ, Black, A4
mxkx250 is offline   Reply With Quote
Old 03-17-2014, 07:45 AM   #17
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Any procedures need to be done after changing other than maybe a few figure 8s in both directions?
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 03-17-2014, 08:40 AM   #18
GenF-GTS
Drives: none
Originally Posted by Tyler360 View Post
I personally went with Royal Purple
Any issues using RP?
How hard to do this yourself?
GenF-GTS is offline   Reply With Quote
Old 03-17-2014, 09:30 AM   #19
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
Did mine at 800 mi and will do it again at 1500 mi if I ever get that many
Kevlar382 is offline   Reply With Quote
Old 03-17-2014, 09:43 AM   #20
Stephen12ZL1
Drives: '17 ZL1 A10
I put royal purple in mine and it made noise until I went back with the correct GM fluid as per the pic above.
Old 03-17-2014, 09:51 AM   #21
GenF-GTS
Drives: none
Has anyone used the redline heavy shockproof I had it in a previous car it was pretty good, also had a diff service center put it in for me and they were very impressed with the visual stickyness etc of the oil.
Old 03-17-2014, 10:03 AM   #22
GenF-GTS
Drives: none
Just doing some searching there is a acdelco dexron LS gear oil PN# 88862624 and a
acdelco dexron LS gear oil PN# 88862625 how did you find out which was the correct one?
Old 03-17-2014, 11:25 AM   #23
HDRDTD
Did a search on those part nos, and the 88862624 shows up in the GMPartsDirect web site
http://www.gmpartsdirect.com/results...umber=88862624
, but not the 88862625 part number.
Interestingly, I did find this while doing a search on the second part number.
Question: When I take off from a stop in my '02 Corvette, I hear a popping noise. I was at a Corvette show and ran into a guy who had the same problem. He said that the dealer had installed a new type of rear-axle fluid in his C6. Can I use this fluid in my C5, and will it help with the popping noise?
Mark
Via the Internet
Answer: General Motors did release a new rear-axle fluid in early 2008. The new fluid is called Dexron LS Gear Oil 75W90, and it carries part number 88862624 in the U.S. (PN 88862625 in Canada). This fluid can be used in all Corvettes from '97 through current production. You'll need approximately three quarts to perform the change.
Read more: http://www.vetteweb.com/tech/vemp_09...#ixzz2wEYpztpt
So, is one a US part number and the other a Canadian part number??
Old 03-17-2014, 12:47 PM   #24
ZED SLED
ZED SLED's Avatar
Mark
Via the Internet
That's what it states in the owner's manual under recommended fluids and the pic above is in liters. Manual also states 2.0L or 2.1 quarts. The Canadian bottle would give a more accurate fill, lol.
Rotofab cai
Old 03-17-2014, 01:26 PM   #25
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
I believe there are two part numbers, one for Canada and one for the USA. First dealer I contacted was useless and didn't know what oil to use and asked why I was doing it as it wasn't in the FSM yet. It's easy to do and GM made it nice with two plugs in the diff, one to fill and one to drain.
This is a cheap and easy thing to do and as far as using other brands besides GM I was not able to find a cross reference for the oil we stock at my shops so I just stayed with GM and it has been quiet and smooth since.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 03-17-2014, 03:23 PM   #26
ZED SLED
ZED SLED's Avatar
See Section 11-13 of your owner's manual.
Rotofab cai
Old 03-18-2014, 11:34 AM   #27
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Have you drained the trans fluid yet to see how it looks?
2017 C7 GS - WGG, A8. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 03-18-2014, 11:49 AM   #28
Stephen12ZL1
Drives: '17 ZL1 A10
I have drained my transmission and even with the countless 1/4 mile runs and road course action, it was still cherry red and had no burnt odor. If you aren't racing the car, the transmission fluid will be fine for a while. Nice thing is that our transmission pans have a drain plug. To refill the thing you must use a long tube or pump system as the fill hole is not in the easiest location to access. It takes 6.3 qts to fill it. Make sure the new fluid is Dexron 6 approved. Not all fluids are Dexron 6 approved. Mobil has its own fluid for Dexron 6 vehicles as Mobil 1 is not approved.
