Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 03-31-2008, 01:37 AM   #1
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
tire width
Im trying to find out what size tires should be one buy if front and rear wheels have different widths???
lets use 20x8.5 and 20x10
any help?
TFord is offline   Reply With Quote
Old 03-31-2008, 07:49 AM   #2
Ottenbacher2
Ottenbacher2's Avatar
Drives: 2000 Camaro
Well the easiest way I found is to go to tirerack.com and select wheel and tire packages and select the size rim you have and it will give you a recommended tire size. 20x8.5 would use a 245/35/20 and 20x10 would use a 265/30/20. First # being width of tire, second # being height of tire, and third # being wheel size.
Ottenbacher2 is offline   Reply With Quote
Old 03-31-2008, 12:32 PM   #3
CaptianSam
Car Garage
CaptianSam's Avatar
Drives: 350z,A4,SRT8...see sig
lol... you want to maximize your width greater than that... you want the smallest possible rim witdh witht the greatest possibly tire width...for lightness... i had a 265 35 19 that was 8.5 and on a 9.5 19 i had 305 35 19
the wheels were WIDE and only 9.5 on the rear they were light... i would NEVER go bigger then 265 on the front... it completly changes the car's handlling and gives you more understeer... 245 is even a big front...
with a 20 8.5 you can use 265 35 20
and a 20 10 you can go as high as 325 35 20 but thats a tough size
to find your better off going 20 by 9.5 it gives you 265-305 30-35 20
2012 2SS RS Ordered
Black on Black 6 speed Coupe Artic Lid Stripes
Yes I Supercharge Everything
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Current Autos:68z28,03viperSRT10,04escalade,05RangeRoverSport SC
Project Autos:80corvette350-500hp 6speed,06charger S'C 6-speed posi,74Firebird400blue,69chevelle572 707
New Autos:2012CamaroSSRS,09ChallengerSRT8
Past Autos:....too many to list
"i told you it was gettin' an LS3"
Go down deep enough into anything and you will find mathematics. Dean Schlicter
B.Sc. Hons. Mathematics
CaptianSam is offline   Reply With Quote
Old 03-31-2008, 02:04 PM   #4
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
i would go wider than a 265 on the 10". and why are you telling him to put a smaller profile tire on the rear for the same size rim? lol
if anything go 265/35/20 and 285/35/20
these are for a car that is. if you switch to a truck or something, upgrade the side wall dimension
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 03-31-2008, 02:12 PM   #5
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
appreciate it a buddy of mine asked me this question cause Im a wannabe grease monkey...but tire sizes I usually do the tirerack thing also. But like spike I didnt agree with the tire sizes that they recommended
Old 03-31-2008, 03:28 PM   #6
CamaroSpike23
The Jalopy Jedi
well, it all depends on what you want.
for example, the 4th gen camaros and their 16" salad shooters with 245/55/16s. HUUUGE side wall height mixed with a thin width. now compare that to say...the corvette, with 17" wheels up front and 18s in the back with wide, low-pro tires for maximum grip.
you throw in a larger wheel like we will more than likely be getting with the new camaro. at least an 18" i would imagine, and your tires get smaller on the sides.
my Z06 rims on my Z are wrapped with 275/35/17s and 295/30/18s
i increased the sidewall height on the fronts to balance out the car a little more front to back. also my wheels are 8.5" and 11" wide respectively. i would have gone with 315s on the rear or even 305s, but i got one hell of a deal on the 295s so i took it. plus i dont drag race on those wheels, thats what the ET streets are for. lol
I piss excellence
Old 03-31-2008, 04:22 PM   #7
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
got cha...well now I know who to pm when ever Its time to get tires for rims!
Old 03-31-2008, 05:45 PM   #8
CamaroSpike23
The Jalopy Jedi
not tryin to brag, but im a knowledgable person about a lot of things. one of my major other sites www.z28.com ive got a thread called Ask Mr. Norris where people ask all sorts of questions ranging from how to change their shock struts to what cam they should run with what mods to what weapon would be best to use when being attacked to how to change a flux capacitor. lol ask away.
I piss excellence
Old 03-31-2008, 10:29 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The best look I've found, with my car, has been 275/10/17s on the front (17 X 9) and 335/35/17s (17 X 10.5) in the rear. The rear sidewall stuck out a little more than I would've usually likey, however, it offered some curb protection and I think it helped fill the haunches out a little more. It didn't require any more work than 315s did and I'm hoping GM will give is some room to work with...
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 03-31-2008, 11:00 PM   #10
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
Actually the second number (aspect ratio) is a percentage of the first number (width in mm from sidewall to sidewall)
In the first tire the width is 265 mm and hight of the sidewall is 35% of that which is 92.75mm
If you have a wider tire, the second number doesn't have to be as big to equal the same height of the sidewall.
Here is a link that explains all the numbers: Understanding tire sizes
Sterling is offline   Reply With Quote
Old 04-01-2008, 01:24 PM   #11
CamaroSpike23
The Jalopy Jedi
thats good to know. hmmm, i always thought it was the size in mm of the sidewall height.
makes sense enough
I piss excellence
Old 02-23-2009, 07:19 PM   #12
danrc28
danrc28's Avatar
Drives: 2010 Camaro 2LT Black on Black
I was wondering why different sizes are being offered on the V6 and V8 models- V6 only offers 8.5" width while V8 offers 9.5"width in the rear tires. If I bought the V6 would it still be possible to buy thicker tires for the rear? I saw some nice ones on a new BMW maybe 9.5"-10" not sure. Really thought that thick rear tires would look nice on my 2lt.
danrc28 is offline   Reply With Quote
Old 02-23-2009, 07:26 PM   #13
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
and that's section width, not tread width... just in case anybody was thinking otherwise
i say go for it.
Old 02-23-2009, 07:27 PM   #14
mmarcum
mmarcum's Avatar
Drives: 2010 Rally Yellow Camaro SS
This approaches epic levels of necro!
mmarcum is offline   Reply With Quote
Old 02-23-2009, 07:39 PM   #15
zebra
zebra's Avatar
i didn't even notice that!
Old 02-23-2009, 07:58 PM   #16
CamaroSpike23
The Jalopy Jedi
it approaches epic failure... damn zebra.... I thought you had recovered from the necro-posting.
I piss excellence
Old 02-24-2009, 04:25 PM   #17
2010_5thgen
2010_5thgen's Avatar
Drives: 2013 Acadia Denali
wow someone revived this thread from the dead. almost a year......
Too much to list.......
2010_5thgen is offline   Reply With Quote
Old 02-24-2009, 05:34 PM   #18
zebra
zebra's Avatar
i was answering the necro...
Old 02-25-2009, 08:59 AM   #19
CamaroSpike23
The Jalopy Jedi
you coulda sent him a pm with his post quoted....
I piss excellence
Old 02-25-2009, 10:16 AM   #20
Xanthos
Almost-Original Postwhore
Xanthos's Avatar
Drives: Stick
WHOOO!!! TIRE SIZES!
On a related note, you can get a 9.7 inch section width pretty easily on the stock V6 rims - and they're only 7.5 inches wide.
- Xanthos
Xanthos is offline   Reply With Quote
Old 02-25-2009, 01:26 PM   #21
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
Hmmm... 315/35/20's on 10" wheels? Nitto says you need at least 10.5" to run their INVO's (which is what I plan on getting). Problem is unless I widen my rears and powder coat them, the only affordable wheels I can find (>$400 each) max out at 10". Will that tire fit on a 10" wheel... safely and without issue?
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 02-25-2009, 10:26 PM   #22
Xlr8torZ28
aka: The Evil Joker
Xlr8torZ28's Avatar
Drives: 1991 Z28 (murdered out)
http://www.bonspeedwheels.com/
pick your diameter, your width, and your offset... expensive though
I am currently running 18x9 with 265/35-18 and 18x10 with 295/35-18...
You can get a 305 or 315 on a 10" rim, but most people usually have to run a lower psi to get a flat footprint with the tire. I had a 285 on a 9" rim and had to run the tires at 32psi. I used the chalk trick on the tire.
1991 Z28 305H.O. TPI T56 six speed w/ B&M ripper shifter, ROH Drift-Rs 18x9 w/265/35-18s & 18x10 w/295/35-18s, 4.10s, K&Ns, Holley 52mm, ADS Superchip, Hedman headers & Y-pipe, custom Flowmaster, MSD, SLP posi unit, Koni yellows, Eibach Pros, Lakewood boxed rear control arms, TDS wonderbar, Hotchkis dbl adj panhard bar
Xlr8torZ28 is offline   Reply With Quote
Old 02-25-2009, 10:50 PM   #23
zebra
zebra's Avatar
i'm running 265s on my 16x6.5 wheels with room to go to a 285... oh but wait... i've got sidewall!
Old 02-26-2009, 09:16 AM   #24
CamaroSpike23
The Jalopy Jedi
lol sidewall ftw
I piss excellence
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
Length and width of new Camaro? odie23 5th Gen Camaro SS LS LT General Discussions 20 02-14-2008 05:22 PM
Spare tire 2001ragtop Off-topic Discussions 9 02-08-2008 03:10 AM
Car Law- i.e. tire size, exhaust noise Kyle.Gilmour General Automotive + Other Cars Discussion 11 08-06-2007 11:09 AM
Interior Space / Width & Height of Seat markhoran 5th Gen Camaro SS LS LT General Discussions 8 12-05-2006 01:22 AM
