JUICEDMOTORSPORTS
Old 03-15-2014, 04:37 PM   #1
tanur420
Drives: 2011 Camaro SS
subframe bushings
Im in the middle of installing the subframe bushings and im running into an issue maybe someone can help me with. What holds the bushings in? After putting the bushings in and with the bolt screwed in I can simply pull off the bottom portion of bushing?maybe I missed something any help would be appreciated
tanur420 is offline   Reply With Quote
Old 03-15-2014, 05:35 PM   #2
Lio Martinez
SoCal HT5!!!!
Lio Martinez's Avatar
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
Hope this helps
http://youtu.be/k8oq3eix66w part 1
http://youtu.be/tYqisrPAbNs part 2
2013 CAMARO 2SSRS 1LE Metallic Inferno Orange. Turbonetics T76 Kit, Granatellis Spark Plug Wires and Performance MAF Sensor, Wilwood Big Brake 6 Piston Kit. Eibach 1 1/2 drop lowering springs. ZL1 conversion of rear diffuser with heat shields, Side skirts and rear spoiler matter black. Original GM Transformers edition AuTobot fender logo and autobot wheel caps and autobot stiched ARM rest . Inferno Orange interior seats and dash trim panels, red billet racing pedals , Black CAMARO fuel door with lock. Chevy logo speaker covers, and Camaro logo chromed door kick panels . GM MTX subwoofer box.
Lio Martinez is offline   Reply With Quote
Old 03-15-2014, 05:44 PM   #3
tanur420
Do I reuse any part of the old bushings? Like the metal cap the original bolt was threaded through?
Old 03-15-2014, 05:53 PM   #4
Synner
Drives: not stock
With poly you reuse it, with aluminum you don't.
Old 03-15-2014, 06:03 PM   #5
tanur420
Easiest way to get them off?
Old 03-15-2014, 06:15 PM   #6
tanur420
Nvm. Torch. Hammer
Old 03-15-2014, 08:57 PM   #7
tanur420
For anyone else having issues easiest way I found after trying for over an hour. Was put it in a vice, heat the hat while putting a socket extension inside the original bushing on the edge of the hat and rubber malleting it
Old 03-15-2014, 10:22 PM   #8
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Yes, you need to re-use the metal retainer plates with the poly bushings.
blazzin1 is offline   Reply With Quote
Old 03-16-2014, 06:21 AM   #9
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Hope this helps.
rtcat600man is online now   Reply With Quote
Old 03-16-2014, 07:05 AM   #10
tanur420
Wish I had that sooner. My bmr instructions failed to mention using the retainers.
Old 03-16-2014, 05:49 PM   #11
blazzin1
blazzin1's Avatar
I will see if I can get that fixed!!!
Old 03-16-2014, 07:10 PM   #12
tanur420
There were also instructions that said.to reference pictures that werent there. I already tossed em all in trash cause I finished earlier or ide reference which ones. Took me two pretty fully days but got trailing arms, toe rods, end links, sway bars, springs, full bushings except diff, and new shortened lca in the rear
Old 03-16-2014, 07:40 PM   #13
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Me too, tanur..this weekend...fun wasn't it.?. I pretty much just used the inst. for the torque settings.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 03-16-2014, 08:23 PM   #14
tanur420
Yea it was a blast. Lol. Springs especially the front, front sway bar on front, radius rod bushing and rear uca bushings were what made me swear the most
