Gen5DIY
Old 03-17-2014, 07:11 PM   #15
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by Fred 6528 View Post
My Night Fury has 477 torque with stock heads
And what does it run in the 1/4?
62nalide is offline   Reply With Quote
Old 03-17-2014, 07:17 PM   #16
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
here TSP's best cam, not exactly the most tame, have to rev some to not surge in the low gears. 491 h.p. , 448 torque Stock ls3 with CAI induction and Stainless power headers with cats through dual mode exhaust...2013 Camaro with electric power steering. No under drive pulley, no ported heads or intakes, or throttle body just the basic three with a good tune, and pulls like a raging ape on steroids straight to the moon. it is the .639/ .623 cam with .675 springs 235/239 duration 112 lSA. Budget build and its just fine with me.
DID IT BEAT THE " NIGHT FURY" SIMILARLY EQUIPPED? That's for you to figure out.
Mines on a SAE Mustang dyno too. I am sure the dual mode helped and electric power steering?
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 03-17-2014, 07:22 PM   #17
62nalide
62nalide's Avatar
Drives: 2013 SS
So everyone is judging a cam by the DYNO numbers vs track numbers????
Old 03-17-2014, 07:24 PM   #18
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
I have no idea what it will run in the 1/4. I'm that older guy you read about with the car that never seen the track and never will. Sorry
Fred 6528 is offline   Reply With Quote
Old 03-17-2014, 07:29 PM   #19
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Originally Posted by Avenging Orange View Post
I agree what someone else said....do some research and choose what fits you best. Understand this...there are lots of cams that will increase hp/tq. The important thing is where in the rpm range this occures. For these heavy cars, you want your tq kicking in early in the rpms. My .02 would be keep the duration under 228 and lift under .600. Keep it tight with the lsa......112-108. You will get all the useable tq you need all under the curve.
I agree with this! My little cam I hand picked and does very well for what it is because the power it makes under the curve. Even once I go bigger I am keeping the duration around 220-235 ish on a 110 .580-600 max lift. That's just me, I want power to come in quick and I don't see the need for extreme lift! Dyno numbers don't mean to much, I want to see track times to back up claims. 10 peak HP does not mean its faster on the track!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-17-2014, 07:31 PM   #20
Bad70supreme
That's why there are so many slow 1/4 miles camaro's
Old 03-17-2014, 08:29 PM   #21
62nalide
62nalide's Avatar
Drives: 2013 SS
Yup, seems people go for the most talked about big dyno numbered cams and not the ones getting the quickest times.
Old 03-17-2014, 09:09 PM   #22
B-_-RAD
Banned
Drives: ...
http://www.camaro5.com/forums/showthread.php?t=346360
Note the trap speeds. The reason why this cam isn't judged by track numbers is because not everyone tracks their car. It's getting old seeing that comment in every thread. Also, most nf cars are m6, which require much more skill and seat time to get down the track properly.
B-_-RAD is offline   Reply With Quote
Old 03-17-2014, 09:11 PM   #23
SWAT
SWAT's Avatar
Drives: 2011 2SS RS L99
+1
SWAT is offline   Reply With Quote
Old 03-17-2014, 09:23 PM   #24
62nalide
62nalide's Avatar
Drives: 2013 SS
your point is? NF ain't the BEST out there thats for sure there is no "BEST"
Edit: I'm a drag racer so I look at numbers at the track I careless what a dyno sheet says.
Not turning this into a pissing match,
Old 03-17-2014, 09:39 PM   #25
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Our SS3 makes 490's 450's on stock heads.
SS2 is about 10 hp and tq less, with better power up to about 4k.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 03-17-2014, 09:44 PM   #26
Rhino79
Rhino79's Avatar
To the OP, I always ask a customer what is YOUR goal with the car.
Old 03-17-2014, 09:45 PM   #27
Bad70supreme
Getting sick of hearing the truth I guess. Not everyone races, but I would still pick parts based on what I see performing the best at the tracks. Prime example, my buddy picked a cam for his GTO based on it making huge dyno numbers. On the track he is struggling to run 11s... I think will go 11s but like I told him when he picked it, it was not right for his gearing and stall, to much cam no matter what it made on the dyno! Smaller cam and he would be faster with less.
Old 03-17-2014, 09:51 PM   #28
62nalide
62nalide's Avatar
Drives: 2013 SS
Very well said
I still stand by my 1st post
cam, dyno, shaft, spec, suggestion
