Old 03-17-2014, 01:02 AM   #1
SoBeGirl
Be the Change
SoBeGirl's Avatar
Drives: bad ass 2010 ss
Break Pad replacment Help Please
To those long term memebers.. I did search and found some useful info. ONe is that I will not go to the dealer ship for this service. I will do it myself. However, do I only need to get the break pads? Are that any other parts I need to get / replace. All I need to buy are just the pad to change them? Thanks in advance for your advice. I have a 2010 ss
SoBeGirl is offline   Reply With Quote
Old 03-17-2014, 01:16 AM   #2
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
how many miles do you have? I'm guessing you need just front pads. Normally you mic the rotors and/or inspect them. For my 1st service, I normally do a pad only (called a pad slap) service and leave the rotors alone.
the dealership often has a deal for $100 per axle which isn't too bad. If I didn't do the work myself, I'd rec'd getting it done at the delearship when you receive those $100 deals.
looks like $99 is their normal price per axle (most cars)
http://www.mycertifiedservice.com/co...ake_Pads-1.pdf
maddoggyusa is offline   Reply With Quote
Old 03-17-2014, 01:30 AM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
with Brembos i like to at least turn the rotors if there low millage and replace them if they warp...turning them if there warped wont make it go away it will come back in less than 5k miles regardless of what anybody tells you.... both front and rear pads at the same time .... thats just me ....some dont do that. its my personal preferace from changing porsche big reds for a long time we always do both rotors and pads...but yours are not slotted or drilled so you can get away with turning them
if it were me and your not wanting to "upgrade" your pads or rotors, slap a set of pads on them and get your rotors turned.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-17-2014, 01:37 AM   #4
1KillerSS
1KillerSS's Avatar
i forgot to mention i always bleed the brakes when i install new ones...gets fresh fluid to the calipers...if you have a lot of miles then i would flush the lines but i am sure you'll get some differing opinions on this
Build thread
Old 03-17-2014, 01:46 AM   #5
Kawirocket674
Drives: 2013 Camaro SS
You might want to check the rotor thickness 1st before slapping on new pads. The rotors are soft and wear fast. I have seen a lot of people on their 1st pad change need rotors as well. Probably depends on the way you drive but I would check 1st.
Kawirocket674 is offline   Reply With Quote
Old 03-17-2014, 05:02 AM   #6
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
I've heard a lot of good things about Hawk HPS pads and will be trying them on my first pad replacement.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 03-17-2014, 12:18 PM   #7
htoniv
Drives: Camaro
What does per Axle mean exactly? does it mean 2 wheels?
htoniv is offline   Reply With Quote
Old 03-17-2014, 12:19 PM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
What are break pads?
FSP tuned: 377/389
Old 03-17-2014, 12:24 PM   #9
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Per axle means two wheels: The two front wheels equal one axle, the two rear wheels equal one axle.
But about the break pads, I can't answer that one... besides, I'm on brake.
Scalded Dog is offline   Reply With Quote
Old 03-17-2014, 12:24 PM   #10
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2012 Silverado LTZ
I replaced my Brembo brake pads after 9 months because of all the brake dust. I have the original pads I'd sell for $50 if anybody wants them.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is online now   Reply With Quote
Old 03-17-2014, 12:25 PM   #11
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Interesting.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 03-17-2014, 12:28 PM   #12
carfansince73
carfansince73's Avatar
Drives: Carefully
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! I wonder if the state would allow this vanity plate---> KISSMYSS
carfansince73 is offline   Reply With Quote
Old 03-17-2014, 12:55 PM   #13
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Where are you and do you daily drive it, how many miles, is it garaged, guessing you bought it used where was it before if you know. Are you planing on trakeing the car.
My self I live in New England when I do my daily drivers brakes I change the rotors every time. I find up here with all the salt that the hat and edges are rusted badly and the vent vanes are usually rusted closed which is the reason the over heat and warp in the first place. So even if you have room to turn them down they warp almost immediately from the inability to vent the heat.
trashmanssd is offline   Reply With Quote
Old 03-17-2014, 01:12 PM   #14
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Here is a good DIY.
DIY: change Brake Pads/ rotors
Typically, I do not turn rotors. As long as they are within thickness spec and do not have any deep grooves, I just clean them up real well with some sand paper and brake cleaner and bed in the new pads. I'll usually go through 2 pad sets on 1 set of rotors.
Let me know if I can answer any questions.
Best regards,
Tyler
888-308-6007
