Old 03-17-2014, 03:54 PM   #1
Sharp-ZL1
MSG,Retired US. ARMY
Sharp-ZL1's Avatar
Drives: 2012 ZL1, 11 XC 90, 15 BMW 328i SW
Looking for 200mph
Can a m6 reach 200mph with a gear ratio of 3.73:1?
I have reached 180mph before I backed off.
I am at 620 RWHP.
I just changed to 295. 315 tire setup MPSS. I was impressed with the smoother ride and less noise they made on the short drive home.
I did notice that the front tires do stick out a little past the front fenders.
I have lower the car one inch and have no rub issues.
I still have to install the peedders bushing in the subframe.
I also order a G92X. Cam from lg motor sports.
Comments?
My build site:
http://www.camaro5.com/forums/showthread.php?t=276256
2012 Camaro ZL1 #151, GCN, Dyno results 701 RWHP
Mods; 2.55 Pulley, CAI, LG Cam Package Ti Springs and 9G2X Cam, RX Can, KDI Heat exchanger, Hurst shifter, Orcale Ghosted marker lights, Kooks Long tube headers with Cats deletes and Tuned by Kraftwerks, Pedders 1 inch lowering Springs, Front and rear sway bars, Rear cradle bushing, BMR Trailing arms and toe rods.
Sharp-ZL1 is offline   Reply With Quote
Old 03-17-2014, 04:01 PM   #2
Emvici
Drives: 2014 ZL1 White Convertible
Sounds nice, were you able to notice what the rpms were at 18o mph? That will give you a clue to how much more the car has left in it for speed. So you now have 295's on the front and 395 on the rear. Is 395 a typo?. if not that sounds really extreme. The car I have seems to sit really nice straight from the factory, do you think it was worth it to lower your car?.
Emvici is offline   Reply With Quote
Old 03-17-2014, 04:06 PM   #3
Diode Dynamics
Diode Dynamics's Avatar
Drives: Camaro Lighting Experts
Shouldn't be a problem if you get the new "Flowtie badge"
In all seriousness, I think you'll need more HP to achieve that goal, but
Nick C.
Diode Dynamics is offline   Reply With Quote
Old 03-17-2014, 04:16 PM   #4
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
You need another 100 rwhp.
The Lingenfelter ZL1 that broke 200 mph had 720 rwhp.
2014CamaroZL1 is offline   Reply With Quote
Old 03-17-2014, 04:26 PM   #5
hognutz
hognutz's Avatar
Drives: 2013 ZL1
if you are really serious I would swap out 5th gear.
there are two approaches to 200mph live with the sixth gear gear ratio and 700rwhp+ proabably more like 800hp if you wanted to do it in a 2 miles span.
or make 200mph attainable in 5th gear and maybe 650-675whp would get your there in 2-3 miles.
also factor where you are going to try to do it if memory serves it took a while for that lingenfelter car to do it even at 720hp.
both lingenfelter and hennessy cars have done it on video though it is possible for sure.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-17-2014, 04:37 PM   #6
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
The Hennessey ZL1 broke 200 mph with their HPE700 package. That 700 is supposed to mean 700 crank hp. I believe that dyno-ed around 650 RWHP. It hit 203.9 mph.
Blackdevil77 is offline   Reply With Quote
Old 03-18-2014, 02:18 PM   #7
Sharp-ZL1
Sharp-ZL1's Avatar
That was a typo. Corrected to 315. Should I run smaller width tires up front?
After the cam up date I should be around 670-700hp. At least I am hoping for that.
I didn't notice my rpm at 180 I was focused mainly on the road.
I love the German autobahn at 4 am. They are empty.
My build site:
Old 03-18-2014, 02:34 PM   #8
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Wait... So you did this awesome feet and failed to capture it on video?!?! How dare you sir, LoL
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-18-2014, 02:44 PM   #9
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Fahrvergnügen!
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 03-18-2014, 03:56 PM   #10
Sharp-ZL1
Sharp-ZL1's Avatar
I got the go pro now and plan on data logging my next run.
My build site:
Old 03-18-2014, 04:12 PM   #11
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
im pretty much in the same boat.
i'm also sitting at 620rwhp and had it up to about 290kmh/180mph! Theres ample of gear left but it starts to run out of steam! You need more power or a different gear ratio...
P.S. it might go a bit faster but i had to back off as it started to drizzle
P.P.S. whipers work at 170+mph lol
MrDew is offline   Reply With Quote
Old 03-18-2014, 04:31 PM   #12
MrDew
MrDew's Avatar
you're sitting at roughly 5100 rpm if i remember correctly
swap in the automatic rear end and you'd be at 6250 in 5th @ 200mph
But probably not worth it, just get more power and call it a day!!! lol
Old 03-18-2014, 04:36 PM   #13
Blackdevil77
It "starts" to run out of steam? I bet it has a little more then that in it. 620 rwhp and you should be knocking at the door of the 200 club! Shelby does it with about 590-600 rwhp and it's not any more aerodynamic then the ZL1. ZR1 does it with about 550 rwhp but yes, it is aerodynamically superior.
In the video posted of the Hennessey HPE700 ZL1, that dyno-ed at about 650 rwhp and it hit 203.9 pretty damn quickly to!
Video was awesome! I hate to request things like this of people but if you ever happen to do something like that again, is it possible to mount the camera by the speedo or so the heads up display is visible or something?
Old 03-18-2014, 04:37 PM   #14
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
It always helps to have more power. I think it will do it with 650 whp if you have enough road. Hennessey took like 3+ miles, did it in the early morning with cool still air. I'm going to try to do it in just 1 mile in 3 days......
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
