Centerforce Clutches
Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection Anything related to keeping your Camaro clean and in good cosmetic condition.
Old 07-29-2009, 06:06 PM   #1
JN-2SS-RS
JN-2SS-RS's Avatar
Drives: 2010 Chevy Camaro 2SS RS
Paint Issues
I am having an issue with my 2SS RS Red Jewel Tint paint. It seems that water spots and bird droippings are being "burned" into my clear coat / paint. Even when I remove it / dry it right away. Dealer says paint is still fresh and will take more time to cure. I picked it up on 7/13 and the serial # is in 18K. Any ideas?
JN-2SS-RS is offline   Reply With Quote
Old 07-29-2009, 06:18 PM   #2
jrmurphy33
CamaroTracking.com
jrmurphy33's Avatar
Drives: 2010 2SS/RS Black
Send a message via MSN to jrmurphy33
did you wax it ?
factory paint and clearcoat only does so much. you need to go buy some good wax apply it.
I paid for the dealer paint protection which cost me $300, its really nothing other then a real good wax job, but its warrantied for 5 years against this sort of thing.
CamaroTracking.com Administrator
Track your order at: http://camarotracking.com
2SS/RS M6 Black, Aluminum Polished
Order: NFTBZQ.
1100 = Order Placed at Dealership 14 OCT 2008 Order changed 11/25/2008 - Allocation 4/4.
DELIVERED 7/31/2009
jrmurphy33 is offline   Reply With Quote
Old 07-29-2009, 06:19 PM   #3
PQ
Drives a Maro
PQ's Avatar
Drives: Hybrid SS Camaro
Pics would help.
Old 07-29-2009, 06:21 PM   #4
JN-2SS-RS
JN-2SS-RS's Avatar
I did get it completey detailed and waxed. It still happened the day after.
Old 07-29-2009, 06:23 PM   #5
99SSragtop
99SSragtop's Avatar
Drives: SS
Meguiar's Yellow wax is great # 26
as far as bird turd get it off asap with running water and a soft sponge, be careful if there is dirt in the droppings try and use the hose to get it off the dirt will scratch your paint.
Florida heat as well as AZ heat will freakin do crazy stuff to your paint. I had to buff my paint to get some water spots out.
99SSragtop is offline   Reply With Quote
Old 07-29-2009, 06:29 PM   #6
gplus
gplus's Avatar
Drives: 2010 RY SSRS 2010 IBM LT2
You can use mquires number 9 swirl remover it will take out the water spots or bird droppings.It is not a rubbing compound its just made to take out small defects
gplus is offline   Reply With Quote
Old 07-29-2009, 06:32 PM   #7
99SSragtop
99SSragtop's Avatar
Drives: SS
Ya use the #9 then #26
Old 07-29-2009, 06:44 PM   #8
C5RocksC5
Banned
C5RocksC5's Avatar
Drives: 2010 Camaro 2SS/RS
Your dealer if feeding you
if your VIN is in the 18K, that paint is several weeks dried and not to mention that it should be 99% cured when it left the 300 - 400º oven. I never heard of a new car having this problem at all. Dealers run their new cars through several car washes until they are sold to keep em looking clean, and if curing is a problem, dealers would not be doing that.
Are you using hard water? Hard water, if let to dry/sun bake on the paint, it is huge pain to get off. Same for bird crap. But no way your paint is getting burned in marks when you wipe water off it right away. Not even cars that just got painted and baked in a regular paint shop's 110º oven will get that from water. There is more to this story, please share.
C5RocksC5 is offline   Reply With Quote
Old 07-29-2009, 07:08 PM   #9
PsyDoc
Drives: Soon-to-be 1st Gen
You are Florida so you better be careful as many of the birds in your area have particularly acidic poop due to their diet. Here's a few photos of what can happen if you do not get it off quickly.
[IMG]http://i18.photobucket.com/albums/b144/cuprabrown1/DS****46.jpg[/IMG]
As you can see, the "toxic" poop will actually leave craters in the clear coat and in some cases (e.g., seagull poop) the poop will eat down to the color.
PsyDoc is offline   Reply With Quote
Old 07-29-2009, 08:35 PM   #10
Vash
Drives: 00 Blazer
Well if it was mine I would try that Zanio. From what I have seen on members Camaro's it's uber.
http://www.zainostore.com/
Old 07-29-2009, 08:44 PM   #11
01pewterz28
Camaro Junkie
01pewterz28's Avatar
Drives: 2010 2LT/RS,Born 9/14/09 @ 11:50:57
Remember we have crappy hard water here in Florida if your car is near a sprinkler system and it get's wet you will have hard water marks from the water. A good wax job will help before you are hit with the hard water after that you have to keep up with it same thing if you wash the car and let it air dry a big no no in Florida.
Sean
Old 07-29-2009, 09:11 PM   #12
sharbaugh
Tampa Gulf Coast Family
sharbaugh's Avatar
Drives: IMB RS SS MANUAL LOADED
Got my car , have waxed it several times. Bird poop happened. Sprayed it off of the car within an hour. Left a permanent mark on the hood. I have tried mcGuires, all the products. Ordered Zaino and am going to try it, but I am being VERY carful not to buff out too much and do more damage than good. My IBM really shows EVERY defect, dirt, dropping, anything.
Seven defects from the factory in the paint, just leaving them, they are really little, like the size of a pinhead defect, two on hood, two on the back, two on one side, one on the other, so hard to get it to show in a picture.
sharbaugh is offline   Reply With Quote
Old 07-30-2009, 10:11 AM   #13
JN-2SS-RS
JN-2SS-RS's Avatar
I spoke with the dealer today and he confirmed there is an issue with certain paint colors and the time for curing. The florida sun is extremely hot and the paint needs more time to cure. They showed me that the paint gets over 145 degrees (via a thermal gun) and the paint becomes soft. They will fix it under warranty if any issues occur. They recommended I let it sit for 30-45 days and they will re-evaluate. If it is still an issue they will apply the paint protectant at no cost.
Old 08-03-2009, 04:05 PM   #14
camarossrs2150
gfx installed
camarossrs2150's Avatar
Drives: abm2ssrs
anybody have any luck with any product getting out the bird stains from the clearcoat
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 08-03-2009, 04:37 PM   #15
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
I had quite a few of those little pinhead spots on mine as well. They
buffed em out but I have recently found a few more so I geuss it's back
to the dealer when I get time.
NAHURRY is offline   Reply With Quote
Old 08-06-2009, 04:07 PM   #16
djm96z28
djm96z28's Avatar
Drives: 2012 Camaro 1SS LS3
I haven't tried yet, but a clay bar might help get rid of the bird poop stains.
djm96z28 is offline   Reply With Quote
Old 08-06-2009, 04:19 PM   #17
rmpackers
Ride this Chevy
rmpackers's Avatar
Drives: 2010 RJT RS Camaro
This is complete nonsense. There is no issue with paint curing. I waxed my RJT 2 days after I had it. PM 80Zedder on this site, he works in the paint shop in Oshawa. He can tell ya the facts.
NFL OWNR I love the smell of new car in the morning!
rmpackers is offline   Reply With Quote
Old 08-06-2009, 04:45 PM   #18
montej23
montej23's Avatar
Drives: 2011 VR Camaro
hmmm interesting why are people having issues with this?
montej23 is offline   Reply With Quote
Old 08-06-2009, 09:50 PM   #19
third1
speed freak
third1's Avatar
Drives: 2012 Cadillac Escalade,10 IOM 2ss
My wife didn't wash a huge bird s**t of the side of her car.It was there about 5 days.I worked for about an hour buffing that spot out.This was on a Lexus witch is known to have excelent quality paint. Birds are bad.
Current:2012 Cadilac Escalade.2011 CVO StreetGlide cammed,tuned&loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779Del 7/10/09 Former Camaros 72 LT1 Z28, 86 z28
third1 is offline   Reply With Quote
Old 12-20-2009, 07:02 PM   #20
cdeacon
Deacon SS
Drives: 2SS Red Jewel
Red Jewel pinhead spots
Ordered my Red Jewel SS Manual at the end of June 2009. It came in on Sept. 19, 2009. I love it but it does have several paint blemishes like pinhead size on hood and trunk lid. You have to really look for them but I am a fanatic so i see them all the time. I really don't think I want the delaer messing with them though. Fix could be worse than problem. I recently had the dealer note them on the record in case they get worse with time. Its funny, the only Red Jewel SS I saw before ordering mine had the same type of problem but worse than mine. I thought it was just an anomaly with that one only. I think there may be an ongoing problem with this color only. But I don't have any proof.
cdeacon is offline   Reply With Quote
Old 12-20-2009, 07:17 PM   #21
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
First, I believe by the time your car arrived at your dealer, the paint was fully cured.
Second, I've dealt with marks similar to yours and used 3M's Finesse-It to address the spots. It may take several attempts, but they can be removed. You'll want something with a mild abrasive. Once they are removed, you'll want to finish with a good wax/polish on the area affected.
Ed
Moose is offline   Reply With Quote
Old 02-28-2010, 11:33 AM   #22
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
I know how you feel. My yellow shows everything.. And I found defects in my clear and under my yellow paint also.. I'm trying to get over it..
2010 Bumblebee is offline   Reply With Quote
Old 02-28-2010, 08:17 PM   #23
gofast908z
gofast908z's Avatar
Drives: Camaro
If they are bad, you'll need a compound or polish to remove them. A wax or a sealant like Zaino won't really do anything. Bird droppings etch the clear just like you can use acid to etch glass. You have to remove a small about of clear to remove it, sometimes resorting to wetsanding. And sometimes its too deep and you're just screwed.
Oh and don't believe the the dealer "paint protection" will prevent this. If they warranty it, great. But double check. I believe the waranty is only if you come in when they say for the 2nd treatment. In the end though, its a complete rip-off (price-wise).
Jeff
1998 Camaro Z28 - LS3 427 - 543 RWHP / 505 RWTQ - For Sale
2005 Sierra STL ext cab -5.3L, Daily/Detail Rig
gofast908z is offline   Reply With Quote
Old 03-01-2010, 07:42 PM   #24
Mike2ss
Airborne Pathfinder
Mike2ss's Avatar
Drives: IO SLP/2SS/RS
bird poop very bad, I had a couple of drops on my paint and even though I cleaned it fast it stained. I used a clear coat compund and water, worked it ever so slightly, waxing in between and finally got it out.
Pain in the a@#
ZL575 Inferno Orange/White Stripes, IOM interior, M6, Brembo Sport Rotors, 6 piston front calipers, drilled rotors, adjustable sway bars, 1"drop, tune, Powerflow axle back exhaust
Other cars are- 95 BMW 325 sedan- AA exhaust, AA CAI, AA Strut bar, AA chip, M3 rotors and calipers, racing clutch, oversized injectors, upgraded M3 interior
Mike2ss is offline   Reply With Quote
Old 03-02-2010, 10:13 PM   #25
cardsfan09
cardsfan09's Avatar
Drives: SS/RS 6M, '98 Z71 p/u
Last nite I read through everyone's suggestions for improvements and problems they are encountering, it seems as though almost a third of the responses were related to paint chipping and pitting issues. I contacted Chevy directly and they said they hadn't heard of any complaints, but set up an appointment for me tomorrow to see the dealer for an inspection. I strongly urge anyone with such issues to document them through their dealer. Mayhaps if enough problems are reported something may be done to remedy our problems of chipping and paint imperfections.
cardsfan09 is offline   Reply With Quote
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 100 02-24-2013 06:24 PM
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 09:22 AM
Another Bad Paint Issues Car From First 2000 Held In Michigan Jason 98 TA Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 07-09-2009 07:22 PM
How Bumpers are made, Paint Matched and Questions for FbodFather rays Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 43 06-15-2009 01:01 PM
