JDP Motorsports
Old 03-18-2014, 12:53 PM   #1
Btrbimmer
Drives: 2SS 1LE Silver w/Recaro NPP
OEM 1LE Springs vs after market springs
I'm interested in lowering my stock 2014 1LE using the 1" drop BMR (or other brand) aftermarket springs front and rear.
Something like this: http://www.bmrsuspension.com/?page=p...&productid=836
I saw the thread about the staggered approach, but I'm concerned about front spoiler clearance, so the 1.4" drop seems like too much.
I assume the 1LE has stiffer spring rates than the SS, but I have not seen specific data.
Does anyone know how the stock 1LE springs compare?
My main concern is ride quality and comfort. I'd like to lower the vehicle, but still maintain as much comfort as possible (for a Camaro 1LE) as this is a daily driver and I'm trying to avoid complaints from my spouse on the rare occasion when we take my car for a ride.
Progressive rate springs are supposed to still be comfortable, but I have my doubts.
Any insight or recommendations are appreciated.
Thanks!
-BtrBimmer
'14 2SS 1LE NPP Recaros
Btrbimmer is offline   Reply With Quote
Old 03-18-2014, 01:18 PM   #2
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
If you lower the car ,you will hate speed bumps and some driveways .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-18-2014, 06:43 PM   #3
MReno93
MReno93's Avatar
Drives: 2013 Summit White 1SS 1LE
I too am curious. Looking at doing this too. Thanks for posting.
MReno93 is offline   Reply With Quote
Old 03-18-2014, 06:48 PM   #4
BATMOB1LE
• HT •
BATMOB1LE's Avatar
Drives: 2013 2SS/RS 1LE
I have a set of BMR 1.4" springs ready to get installed on my 1LE as soon as the weather picks up. I'm SO excited to get them on.
I'm not concerned about clearance or anything. I'll adapt and drive carefully and take inclines on an angle. It's not my daily driver though.
2013 Camaro 2SS/RS/1LE - 402 of 451
"BATMOB1LE"
- Xpel Stealth Wrap - ZL1 Rockers - 18% Tint - Custom Badges - Heritage Grille - BMR 1.4" Springs - Solo Performance Axel-Back Exhaust - Recaro Sport Seats
BATMOB1LE is offline   Reply With Quote
Old 03-18-2014, 06:55 PM   #5
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
SS and SS/1LE use identical springs. They are linear from the factory.
Feel free to reed my long rant here
http://www.camaro5.com/forums/showthread.php?t=303171
And my Pedders install thread....
http://www.camaro5.com/forums/showthread.php?t=311205
-Matt
Old 03-19-2014, 08:37 AM   #6
Btrbimmer
Matt,
I read through your Pedders install thread, but I don't see your overall assessment AFTER going to the track.
What are your thoughts after having the springs installed for 7+ months?
Here is the litmus test: Would your wife notice the difference in ride comfort?
Also, did you look at the Eibach Pro-Kit and other manufacturers?
Thanks,
-Brett
Originally Posted by Dropspeed View Post
SS and SS/1LE use identical springs. They are progressive from the factory.
-Matt
-BtrBimmer
Old 03-19-2014, 09:04 AM   #7
Dropspeed
Dropspeed's Avatar
Originally Posted by Btrbimmer View Post
Matt,
Thanks,
-Brett
Hi Brett,
Didn't want to overwhelm you with posts....here is the on track thoughts. I have lots of threads about tracing the car stock as well.
http://www.camaro5.com/forums/showthread.php?t=316591
My wife and I have been toghther for 16 years and she has ridden in everything from all out race cars to lifted trucks....She thinks the Camaro is comfortable, but a firm ride. I have warped her perception of what is comfortable over the years. My 10 year old instantly asked why it was so much more bouncy in the back seat.
Overall I am happy as I got the desired results I wanted. a lower CG, a better look and no loss of on tack performance......However if I did it again I would most likely go with Pedders rear 220035 springs only and leave the front stock.
...forgot to add...I was only looking at linear rate springs because that is what the stock springs are. If you cant find Pedders I did consider the BMR as well, but I have never used them.
-Matt
Old 03-19-2014, 09:15 AM   #8
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
BMR lowering springs are actual a dual rate springs with a linear working rate. To make this kind of easier to understand they basically use a softer rate on the top couple coils to get the ride height where they want it but the actual part of the springs that does all the work is linear. I have a set of Bmr springs 1" ready to install soon as Install I'll report back
If you're reading this objects In side view mirrors are losing as I'm rowing the 3:91's
1Slow6.2 is offline   Reply With Quote
Old 03-19-2014, 12:03 PM   #9
Btrbimmer
I did a few searches for the Pedders springs, and many on-line sources do not have springs in stock or at least a very limited selection.
I don't want to drop the car more than 1", so the BMR 1" drop springs seem to be the most attractive for my purposes.
Here are a few that seem to be good candidates:
PFADT 1 to 1.25 inches of drop: $300 (seems to be discontinued by manufacturer)
http://store.pfadtracing.com/camaro-...ngs-2010-2014/
BMR 1" drop:$249
Eibach Pro-kit 1" drop F & R: $225
(Initial lowering length may be less than 1". Your vehicle will settle shortly into the 1" to 1½" lowered range. Exact length depends on the weight of vehicle components.)
http://performance-suspension-eibach...-4-springs-152
Hotchkis (claims 1" drop but it looks like more in the pictures up front) $357
http://www.hotchkis.net/2010_camaro_...l_springs.html
SLP claims 1" drop $249
http://www.slponline.com/product/700...g-Package.html
Summit Racing (1 to 1.5" drop) $116
http://www.summitracing.com/parts/su...t/model/camaro
ST Suspensions 1.4" drop F and R - $260 (I think this was Suspension Techniques years ago)
http://www.stsuspensions.com/product...g-kit-153.html
H&R Sport Springs 1.4" Front and 1.3" rear (Part number 50778) $265
http://www.hrsprings.com/application...ts/42/920/2011
B&G Suspension - S2 Sport Springs F: 1.4" R: 1.5" $210
http://b-gsuspension.com/springs.php
SPOHN SRE Springs - "These progressive rate springs will lower your vehicle 1.0" in the front and 1.0" in the rear"
http://www.spohn.net/shop/2010-Chevr...Camaro-V8.html
-BtrBimmer
Old 03-19-2014, 04:23 PM   #10
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
HOJO is offline   Reply With Quote
Old 03-20-2014, 10:28 AM   #11
Dropspeed
Dropspeed's Avatar
Do you plan on tracking or auto crossing the car?
Old 03-20-2014, 12:20 PM   #12
EarlyApex
Drives: 2013 IOM 2SS 1LE
I just finished installing BMR 1" drop springs along with my version of the Pedders Permagrin setup and my observations so far is the look is fantastic, the ride on smooth pavement is very good but med size bumps are harsher bordering on sharp. The ride is not bouncy but I do feel the bumps more than the stock springs. Hard to tell if the springs made the handling better or worse due to the other items added at the same time. This will be my setup for this summer with coilovers on the list for next year.
EarlyApex is offline   Reply With Quote
Old 03-20-2014, 03:37 PM   #13
Btrbimmer
I'm planning on attending a few track events each year.
Maybe I'll try autocrossing, but I have a '72 BMW 2002 tii already set up for autocrossing which would be more appropriate.
-BtrBimmer
Old 03-31-2014, 01:07 AM   #14
Btrbimmer
I meant to ask< what is your version "Pedders Permagrin setup"?
Did you install bushing inserts and a larger rear swaybar?
-BtrBimmer
1le springs, camaro 1le, comfort, springs
