BeckyD @ James Martin Chevy
Old 03-18-2014, 08:19 PM   #1
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Tube replacement?
Hi all- I was working on my car tonight and I broke the tube in the picture below. It connects to the cold air intake tube and the vacuum line next to the throttle body. Does anyone know what this part is called and if it's easy to find a replacement? I was thinking it's part of the PCV system because there is some oil in it, but the picture of this piece doesn't show in the parts catalog.
Any help is appreciated!
Deke736 is offline   Reply With Quote
Old 03-18-2014, 09:48 PM   #2
DrkPhx
DrkPhx's Avatar
That's actually the clean side oil separator. It connects to the driver side intake tract. Should be available from the local dealer. Wasn't it connected?
Old 03-18-2014, 10:01 PM   #3
Deke736
COTW 12/3/12
Deke736's Avatar
Yes, I found out it's the breather cannister and it's $100 to replace because it can't be bought separately. Gonna try to plastic weld it. I had to remove the intake elbow and this was attached and when I removed it it snapped apart.
Old 03-18-2014, 11:01 PM   #4
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
JB Weld for plastic to the rescue! $7 at Oreillys brother! I did the exact same thing then spray painted it black? You'll never notice the difference!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 03-19-2014, 01:08 AM   #5
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Yep....same thing here!!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 03-19-2014, 08:26 AM   #6
Deke736
COTW 12/3/12
Deke736's Avatar
Glad to hear I'm not alone in this! I was really surprised when the piece pretty much came apart in my hand with very little pressure. I'll be picking up some JB Weld today!
