GM Parts House
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 04-06-2014, 04:21 PM   #113
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Originally Posted by Fraxum View Post
Beautiful, did they have to take the calipers apart to do that?
No, they just taped off the parts.
Originally Posted by EarlyApex View Post
The calipers are a one piece design unlike the rears which are 2 piece with O-ring seals between the 2 half's. You can see some blue overspray on the pistons in the picture so it looks like they were just masked off and painted. I wonder how that paint will hold up to the heat as it looks like auto paint rather than rattle can like VHT high temp paint. I've used car paint on engine blocks with mixed results, sometimes having the paint lift off in the higher heat areas. I am going to paint my calipers using VHT caliper paint. I plan on stripping the silver paint off by blasting with glass beads. I used duct tape to mask off the pistons and bleed screws which I hope will stand up to the blasting.
I've had good luck with them so far. Haven't installed these ones, but my SS calipers (pic below) were painted using the same paint by the same shop. He uses this paint on engine blocks and brakes all the time and says he never has issues, so I'm confident they will be fine. It's very high quality as well (Glasurit), not regular car paint.
Originally Posted by camaro500 View Post
Powhusku, those calipers looks fu*&ing awesome! I have the yellow Vs from amazon and they look sweet on my cyber grey. Will post photos shortly.
You should post once on your car! Are they the same blue as the ZR1 caliper?
Thanks, I will when they go on in the coming weeks. Originally I started with wanting the Jet Stream Blue (ZR1), but my painter showed me a motorcycle tank he had done in this color and I decided thats what I wanted. We put a very light tint over it to give the proper candy look before clear coating. The Chevrolet And Brembo logos are decals, not paint just in case anyone was wondering.
Powhusku is offline   Reply With Quote
Old 04-06-2014, 06:48 PM   #114
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I started bead blasting the calipers in prep for painting. Based on bead blasting the factory finish is powder coated not painted. Powder tends to move around under blasting (more flexible than paint) so most of the surface I just knocked off the shine rather than completely stripping down to bare metal. Blast material more aggressive than glass bead would do a better job getting the old powder coat off.
All Brembo GM calipers are painted. The yellow actually have 3 coats. The reason they turn gold or brown with heat is the clear coat used in Europe changes color with heat. Apparently EU has more stringent environmentally laws that govern the paint and clear used. That may be why it appears to react different to the bead blasting, but it is paint.
Matt
Old 04-07-2014, 01:21 PM   #115
Dropspeed
Dropspeed's Avatar
Originally Posted by td195f View Post
Thanks for validating the pad info. I was basically going by my gut on the appearance of the two different pads and drew the same conclusion and you are correct the photos I took don't show how different the pads really are.
I had the same reaction when I opened the Brembo box and had my hand covered with brake dust.
In talking to a source at GM I was told that the stock pads for the 6 Pistons are good to about 1292 F without fade and they will still work beyond that with fade.
I shelved the $45 pads as a spare/emergency set only at this point.
Matt
Old 04-07-2014, 04:26 PM   #116
black.
Drives: IBM 2SS
Do we need new banjo bolts?
black. is offline   Reply With Quote
Old 04-07-2014, 07:42 PM   #117
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged V6
Thanks for the Pif OP... for the caliper bolts, how many do we need? Looking at the caliper, is it just two for each caliper?
Bump for the question above.
Lil' Nasty is offline   Reply With Quote
Old 04-07-2014, 07:54 PM   #118
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
2 for each side.
Best regards,
Tyler
888-308-6007
Old 04-07-2014, 07:56 PM   #119
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Originally Posted by JDP Tyler View Post
No.
2 for each side.
Best regards,
Tyler
888-308-6007
Thanks Tyler, ordering the zl1 SS lines from you guys
hope its not a problem with ss rear calipers, wouldn't think so.
Old 04-08-2014, 03:41 AM   #120
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Originally Posted by Firefighter View Post
I just measured them from the disc surface of the rotor it's 56mm for a CTS-V caliper.
I know proper measurement would be from the face of the hub but I don't feel like pulling a wheel today. Sorry, that should give you something to reference though.
Sent from my DROID RAZR HD using Tapatalk
Thanks for the info. If you can please get the proper measurements. Just hate to buy these then can't do the install until I get new wheels.
CHMSC is offline   Reply With Quote
Old 04-08-2014, 09:49 AM   #121
Dropspeed
Dropspeed's Avatar
Depending on the brand the lines should come with new banjo bolts and crush washers. (The Goodridge do)
Matt
Old 04-08-2014, 11:08 AM   #122
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I ran the Goodridge ZL1/SS lines with mine and there were no issues outback. They came with the Banjo's too.
If it hasn't been mentioned when you get CTS-V calipers the crossover tubes need to be swapped for use on a Camaro.
Firefighter is offline   Reply With Quote
Old 04-08-2014, 12:49 PM   #123
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
So, is it not for sure they (front calipers) fit with the RS wheels?
Matt
I plan to get the Goodridge lines Thanks again.
Old 04-08-2014, 01:13 PM   #124
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
I am using 20x9 rear wheels on all four corners which sit closer to the caliper than the 20x8 so I am trying to find out if there is a difference and what that difference is.
Old 04-08-2014, 02:22 PM   #125
Firefighter
I'm at the station today and don't even have my car with me.
IIRC JDP has the measurements on their site with the front brake kit.
Old 04-08-2014, 02:28 PM   #126
Firefighter
Look here... http://www.jdpmotorsports.com/jdp-ct...ro-ss-jdpb1002
