Old 03-19-2014, 11:19 AM   #1
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
3rd set of rotos/pads and still issues
I have squeal and it's not your typical slow stop squeal most of you experience. This is, straight up horrible squeal that makes you want to put a screw into your ears to stop hearing, squeal.
I don't think the rotors are supposed to look like this.
Dfault is offline   Reply With Quote
Old 03-19-2014, 12:37 PM   #2
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
You can have a squeal from the surface of the rotor itself, the pads or the hardware or a mixture of those. New hardware that is lubed, quality pads that are beveled, rotors with a nondirectional finish is about all you can do. The rotors do look a little slick but do still have a touch of nondirectional still left in the close up.
Old 03-19-2014, 12:43 PM   #3
Dfault
Dfault's Avatar
Should I go ahead and have the rotors turned?
Old 03-19-2014, 04:11 PM   #4
Bo White
Bo White's Avatar
No, machining rotors is only needed if they are out of spec on run out. The surface texture is what is in question once the run out has been measured and is within tolerance. What I do is use a diegrinder and put a 3M wheel on it and buff the rotor surface area and make a nondirectional surface into the rotor. Problem about that is it will eventually buff slick by the pad but hopefully you bed enough pad material into the rotor that it doesn't create unwanted harmonics.
Old 03-19-2014, 04:18 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
sounds like there not bedding them properly...have they told you that they do that?
cuz they need to if they havent
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-21-2014, 07:48 PM   #6
Dfault
Dfault's Avatar
I had a shop tell me that they believe it's the calipers since my rotors have heat streaks where they are constantly heating up unevenly. What do yall think? How would I go about finding out if my calipers need replacing without throwing unnecessary money at my car?
Old 03-21-2014, 08:02 PM   #7
Bo White
Bo White's Avatar
Jack the car up and roll test each wheel and see how much drag each has. If there is a drag one one then you need to see if its the caliper or the hose or something on up stream.
Old 03-21-2014, 09:47 PM   #8
Dfault
Dfault's Avatar
I'll give that a shot. But wouldn't calipers be under warranty as hardware failure before 5 years and 100k?
Old 03-22-2014, 10:12 AM   #9
Bo White
Bo White's Avatar
Not sure. Doubt it unless you have extended warranty.
Old 03-22-2014, 10:52 PM   #10
Dfault
Dfault's Avatar
I just really want a sure answer on what the problem is. I just hope that the dealer won't charge me too much just to see what's wrong with the car. I don't want to get rid of my 2010 because of a few things that it doesn't have that make me want to keep it longer.
If it comes down to it being too expensive to fix the brake issues, I'll just put new rotors and pads and trade her in and get a new 2014 and put the 2010 steering wheel on it.
Old 03-25-2014, 08:56 AM   #11
Romeloc
Romeloc's Avatar
Drives: 2010 Black 2SS RS A6 Inferno
im going thru the ish my barkes sounds like bus. loud as hell
[SIGPIC][/SIGPIC]2010 Camaro Black 2SS/RS A6 Inferno Interior Polished Rims, Sunroof
Born 11/19/09
mods:
20% tints
Borla Atak cat-bak
Roto-Fab intake
amber footwell, dome, and trunk lighting(AAC)
Decepticon Gas door
Led Taillights (technostalgia)
Romeloc is offline   Reply With Quote
Old 03-25-2014, 10:21 AM   #12
Ret Fuzz
Ret Fuzz's Avatar
Drives: 2010 Camaro
Good advice from Bo
Ret Fuzz is offline   Reply With Quote
