Caryle Racing
Old 09-01-2009, 02:02 PM   #29
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
very niceee!
levi1922 is offline   Reply With Quote
Old 09-01-2009, 05:23 PM   #30
Zax
Drives: Rally Yellow 2010 2SS/RS
Nice tutorial.
I couldn't help myself. Went and picked up an Escort 9500ix today. Gonna get 'er all wired in this weekend.
Ordered: 12/20/08
2G1FT1EW2A9126297 - 7/17/09
Delivered to Dealer: 8/4/09
Zax is offline   Reply With Quote
Old 09-01-2009, 08:13 PM   #31
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 09-03-2009, 12:20 PM   #32
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Can the police detect these? Great job btw. I live in Canada and really want to do this but i heard that they can detect these. Is this true?
Old 09-03-2009, 05:55 PM   #33
Merc
In The Circle
Merc's Avatar
Radar detector Hard wire
My neighbor who installs car stereos and alarms for a living says it is a absolute no no to tap power from any air bag wiring. Opted for hard wire from fuse box up the pillar and across under head liner. way easier and safer.
Old 09-03-2009, 07:49 PM   #34
2L8IWON
2L8IWON's Avatar
Drives: 2010 Chevy Camaro 2SS RS SIM
Yes, police can detect that you have a radar detector. Just make sure it is legal to use in your area.
2010 Camaro 2SS RS 6M SIM - GFX, Sunroof, Carbon Fiber Dash Kit, ARH Headers, ADM Intake, ADM tune, NLP Dove Tail
2L8IWON is offline   Reply With Quote
Old 09-03-2009, 07:57 PM   #35
2L8IWON
2L8IWON's Avatar
+1 Gonna use a blade tap on the F17 fuse in the fuse box. Hopefully, sharing that fuse for the detector and the center console power doesn't blow it with both in use or I'll be researching another way to wire it in the fuse box.
I got this from DLS in another thread so I hope it works...
Yes, I put a piggyback fuse in the F17 spot which is the fuse that is for the power outlet in the center console.
Old 09-04-2009, 05:38 PM   #36
stirthepot
stirthepot's Avatar
Drives: 2010
I totally agree with you but this install doesnt tap into the airbag power supply, it is simply tapping into the light that indicates the airbag status. I havent checked the camaro yet, but i have never seen a car that has the airbags sharing power / circuit with anything, not even the indicator light.
Would like to confim that the Camaro is the same and that the power for the status light is isolated from the airbag circuitry itself. Anybody know for sure?
stirthepot is offline   Reply With Quote
Old 09-04-2009, 07:26 PM   #37
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
Spot on...
I would NEVER tap into an airbag power source...this is simply the power source for an indicator light. Keep in mind it's constant power too (with ignition on), so the ground for each indicator is the only thing that would tie back to the airbag system...not the 12V. And I tied back to the common ground...not the indicator grounds.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 09-08-2009, 12:39 PM   #38
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
Drives: Victory Red 2010 2SS/RS A6
Hey guys like I said, you can tap into the Onstar power right in the rear view mirror. I bought a "stealth" plug on ebay for my 8500 and it just plugs right into the rear view mirror Onstar power. Took me about 15-20 minutes to install. Very easy!
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected)
Icntdrv55 is offline   Reply With Quote
Old 09-08-2009, 08:22 PM   #39
2L8IWON
2L8IWON's Avatar
Please let me know after a couple weeks of use if it is problem free. I have bought a wiring kit with a blade tap and a mute button to mount, but would rather save the trailing of wires if at all possible.
Old 09-08-2009, 09:54 PM   #40
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
I've had it on since I got the car in June and havent had any problems at all. Works great. You just have to play around with the different wires to figure out which one is a switched one ! Doesnt take long at all!
Old 09-08-2009, 10:01 PM   #41
2L8IWON
2L8IWON's Avatar
Didn't you have to ground a wire too? And it would be nice to know which wire without tapping on all of them and having to electrical tape the punctures just to find the right one. Forgive me because I'm an analyst.
Old 09-08-2009, 10:25 PM   #42
themossman
themossman's Avatar
ahem...I showed you which wires...I've had it working flawlessly since install.
Current Summary:
My JL 12" and JL 250 amp install VIDEO AND PIX! TAG UR IT Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 02-12-2011 02:03 AM
DIY Rally Stripe Graphic Installation Tips (wet install) SUPERSPORTED Camaro DIY & HOW-TO instructions & discussions 26 10-11-2010 03:36 AM
Hardwire Radar Detector? mhennick Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-13-2009 11:27 PM
Radar detection systems? DGordon Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 68 04-02-2009 10:05 PM
radar and laser detector and jammers Az Sparky Off-topic Discussions 49 08-27-2007 11:03 PM
