Rick@Livernois
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 04-07-2011, 02:46 PM   #126
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
Originally Posted by Fata$$ View Post
can you put a phone dock the same way as the radar?
as long as that dock is looking for 12V...you should be good to go.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 04-07-2011, 02:47 PM   #127
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Drives: #22 Tom Henry Racing 2010 2SS/RS
Moss you got a recomendation on a good radar detctor???
I'm thinking I'll need one for the trip to the fest.
Old 04-07-2011, 04:25 PM   #128
Fata$$
Fata$$'s Avatar
Drives: 2010 2SS RS
Hey I can't see the pictures you had in the walkthough. I new to this forum stuff so I don't know if i'm doing this stuff right.
Fata$$ is offline   Reply With Quote
Old 04-07-2011, 07:20 PM   #129
themossman
themossman's Avatar
you're welcome to borrow mine...what day are you heading out?
Current Summary:
Old 04-08-2011, 09:59 PM   #130
angelicsowner
angelicsowner's Avatar
Drives: 2010 IBM 2SS/RS
Originally Posted by Icntdrv55 View Post
Hey guys like I said, you can tap into the Onstar power right in the rear view mirror. I bought a "stealth" plug on ebay for my 8500 and it just plugs right into the rear view mirror Onstar power. Took me about 15-20 minutes to install. Very easy!
I just did this, it is definitely better than running to the fuse box using a fuse tap, spade connector or any of that other stuff. 15 minutes tops. Pop the mirror off, stealth plug, match black to black, red to red/pink and you're good to go.
Camaro Club of the Rockies
http://www.ccotr.org
angelicsowner is offline   Reply With Quote
Old 04-09-2011, 11:22 AM   #131
themossman
themossman's Avatar
sorry I lost the pictures...I switched off comcast and forgot to download all my pictures... :(
Perhaps the next person that does this can take a few quick pics and we can update...
Current Summary:
Old 05-18-2011, 06:09 PM   #132
Camaro4Life2011
Camaro4Life2011's Avatar
Drives: Black Camaro 2LT RS with Sunroof
Hey guys I am having a little trouble. Attempting to hardwire the v1. Went to radioshack and they did not have any fuse taps. The v1 comes with a t tap. I was wondering if anyone went that route. Do you need to use invisicord? Thanks guys.
2011 Blk on Blk 2LT
[x] Perma-grin
[x]1000 Watt Dual 12'' Subs (Subthump Harness)
[x]Blacked out Bow-ties
[x]AACStyle Blue Footwell Lights.
[x]AACStyle Blue LED Dome Light.
[x]AACStyle Blue LED Trunk Light
[x]Knight Rider 54 Blue LED
[X]Valentine 1 Hard Wire
[X]Valentine 1 Concealed Display
[ ]20 %Tinted Windows
[ ]LED Underglow
[ ]Rear Footwell Lights
[ ]ABL Extension
[ ]Camaro RS Projection
[ ]Painted Calipers
[ ]Glove Box Light
[ ]Door Handle Lights
[ ]Cold Air Inductions CAI
[ ]AACStyle Plasma DRL
[ ]AACStyle License Plate LEDS
Camaro4Life2011 is offline   Reply With Quote
Old 06-09-2011, 10:03 AM   #133
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
Originally Posted by iFast View Post
Got my radar detector hard wired today. Went from the roof liner down the pillar to the fuse box and tapped into one of the 10A fuses using a fuse tap. Just wanna say thanks to all you guys adding your "HOW-TO". It really helped me decided how I wanted to do mine.
I did the same thing. I tapped it using a blade tap and just connected that to the 10A trunk release fuse at the top. Easy as pie.
V1 does get hot though. I've read that's normal but darn... Florida sun doesn't help I'm sure.
Camaroshark is offline   Reply With Quote
Old 12-24-2011, 04:57 PM   #134
Nightspore68
Nightspore68's Avatar
Drives: 2013 Camaro ZL-1, Victory Red
I'm going to try this for my V1 this week. Not sure if I will use power from the mirror, the light, or the fuse box, but I'll take photos for the next person. If only as a lesson in how not to do it, if it turns out poorly!
Nightspore68 is offline   Reply With Quote
Old 12-27-2011, 09:33 AM   #135
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Strange, can't see the OP's photos only the placeholders are visible.
calbert1999 is offline   Reply With Quote
Old 12-28-2011, 02:11 PM   #136
Nightspore68
Did it!
OK, I installed my V1 wiring in much the same way Macamaro did, from the fuse box through the trim to the driver's visor. It worked pretty well, but I'll point out a few problem areas with the following photos.
I don't know how to caption these photos, so I'll summarize by saying the first photo shows a clip that disappeared as I removed the fuse box door. I was off to a great start, huh?
The fourth photo shows the mysterious extra fuse that showed up (the clear one) as soon as I removed the one from F17. It's 2A and I have no idea where it came from. I'm assuming if it's not a spare I will soon find that something doesn't work!
Photo five shows the fuse tap in place. I had to Dremel the metal a bit to make it fit then I really had to wedge it into the hole along with the fuse. I was surprised the metal didn't bend and break.
Before I ran the wire through the headliner I made sure the V1 was working, photo 9.
In the last photo you can see all the extra wire I was left with. I know I should cut it and make it shorter, but I'll leave that for another day. Instead, I simply tie-wrapped it and stuck it next to the detector. As soon as I remove the detector the extra wire will fall down, which will probably be pretty annoying, so I'm thinking of leaving the detector on my visor from now on. The only thing is I don't want it to be stolen and I'm not sure we're allowed to have radar detectors on base (but I'll check). (I work at an Air Force base.)
Well, I hope this proves useful for someone. It was a little harder than I expected, but at least that damn wire is out of my hair (until I remove the detector from its holster).
Let me know if you have questions.
Old 01-04-2012, 06:30 PM   #137
kiteman
Drives: 2012 45th Camaro, 2SS/M6
i just did this on my 2012. this technique was way easier than tapping into the rear view mirror. the a-pillar gave me a little grief. i just pulled on it at the top and it came out about 1/4" so at that point i just used a wire hanger, taped the smart cord to it, and fed it down and it came out right at the fuse box.
also, no reason to use a connector on your fuse. just strip about 1/2" of wire and twist it around the top of one of the prongs on the fuse and stick it in. works like a charm.
kiteman is offline   Reply With Quote
Old 01-05-2012, 11:40 AM   #138
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
cool, but really, that doesn't sound any easier than tapping into the rear view mirror power.
2010 R6P-2SS/RS/LS3 - IBM w/ silver rally stripes / UNDER CONSTRUCTION.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 01-05-2012, 12:44 PM   #139
nyrfan
Lets go Rangers!!!
nyrfan's Avatar
Drives: 2013 AGM 2SS/RS L99
^This. It would have been much more simple to tap into the mirror. Purchased an inviscord and took about 5 minutes.
nyrfan is online now   Reply With Quote
Old 01-05-2012, 01:26 PM   #140
kiteman
guys, the 2012 currently has unknown rear view mirror wiring, so it would have been trial and error for me (and potentially only error), so it wasn't worth the hassle of trying. the pins have already been confirmed as different and currently only an always-on power pin has been established. this would not be convenient (unless you were okay with turning your unit on and off every time you got in/out of the car).
what i was trying to state is that i already owned the smartcord and that was my preference of wiring all along. however, as seamless as the a-pillar connects to the dash and roof of our cars, i was convinced that the smartcord installation would be difficult and the invisicord would be the way to go. in case anyone owns a smartcord already and/or has a 2012, i think hardwiring to the fusebox is superior to buying an invisicord and going through that install, which appears to be on the same level of difficulty.
besides, this is a DIY for hardwiring to the fuse box, not invisicord wiring.
Old 01-05-2012, 04:50 PM   #141
POWERFREAK
I.AM.
POWERFREAK's Avatar
K, glad it worked out for you. I find it hard to believe there's ONLY "always on" power going to the mirror....but hey, guess it could be.
NY5thgen.com
Old 01-05-2012, 08:18 PM   #142
L99
L99's Avatar
Drives: B On B L99/SS2 Ground effects
Not true I used the Stealth Mirror Cord from http://www.safe-n-sound1.com/ it's only 9 bucks comes with instructions, it's fused and was a slam dunk to install, no fileing down the connector prong like the invisicord. It took me about 10 min max. I spent 5 of those minutes looking for a screw I dropped, it bounced and rolled inside the seat track.
Easy install, Remove one screw holding the mirror using a #20 torx driver, slide mirror upwards to remove, disconnect the plug, slide the red wire into the pink wire slot and the black wire in the black wire slot and you have switched power. The confusion is, there is a pink wire on both sides of the plug, if you plug into the wrong side it will not be switched. To identify the correct side, one side has an empty wire slot. That is the wrong side, use the pink wire on the opposite side of plug.
Not to worry the Stealth mirror cord comes with pictured instructions.
L99 is offline   Reply With Quote
Old 01-05-2012, 09:24 PM   #143
POWERFREAK
I.AM.
POWERFREAK's Avatar
Do you have a 2012? The previous comments were about the mirror wiring being different than the 2010-11s.
I have an invisacord in my 2010...easy install. I didn't have to file anything down.
NY5thgen.com
Old 01-06-2012, 08:38 AM   #144
ncbob
ncbob's Avatar
Drives: 2012 2SS Camaro 45th Anniv Convert.
I have a 2012 convert. Tried several times to find switched power in the mirror with no success. Finally routed the power to the fuse compartment on the left side of the dash. I now have switched power.
However, the LEDs on the V-1 do not appear to be as bright as before. Wondering if I need to switch the fuses in the add-a-circuit or I'm not getting enough power to the V-1.
I do not have a multi-meter.
2012 2SS, RS 45th Anniversary Convertible
K&N CAI
Flowmaster Axel Back
Hurst Short Shifter
ThePowderPros Ported TB
JL XD700/5 Amp, Focal sub, Polk Speakers and Subthump stuff.
2011 Mercedes C-300 (Wife's car)
http://s115.photobucket.com/home/ncbob
ncbob is offline   Reply With Quote
Old 01-22-2012, 08:44 AM   #145
AKA-22
AKA-22's Avatar
Drives: Ellie-1
which spare fuse is hot??
AKA-22 is offline   Reply With Quote
Old 01-22-2012, 02:32 PM   #146
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '10' Camaro 2LT/RS,'08' Caddy STS
This is where most of us have tapped into.....this way when you turn on your car, and if you leave your radar detector or whatever on.....it will come on when you start it, and go off when you turn it off. on the fuse panel on the left side of the dash.....their are two fuses labled as POWER OUTLET #1 (Fuse F17) and POWER OUTLET #2 (Fuse F18)....this is for 2010 and 2011's....the 2012's could be different. both are 20 amp fuses.
Old 02-07-2012, 05:02 PM   #147
2011*Camaro*SS
16 Years Young!
2011*Camaro*SS's Avatar
Drives: 2011 Camaro 2SS/RS Vert
When I went to hard wire mine into the fuse panel the fuse that says display apprears to turn off when the car turns off but it doesnt. Anyone know any of the fuses that will turn OFFF when the car does?
2011*Camaro*SS is offline   Reply With Quote
Old 02-07-2012, 05:09 PM   #148
2011*Camaro*SS
16 Years Young!
The add-a-circut i bought is only rated for 10A can i use this fuse or not?
Old 02-07-2012, 07:03 PM   #149
cuffnstuff1
cuffnstuff1's Avatar
Drives: 2012 Camaro 2SS RS
i just now completed mine hooked the power up to th pink wire located on the airbag/pasenger seat notification light. only on when key is on checked everything works great.
ground i just scraped paint off under bezel with self drilling screw but use caution pick the right spot so you wont go through the roof
cuffnstuff1 is offline   Reply With Quote
Old 02-07-2012, 10:47 PM   #150
Sir Nuke
Sir Nuke's Avatar
yes you can.......but I would replace it with a 3 or 5 amp.......actually about all you need is a 2 amp.
My JL 12" and JL 250 amp install VIDEO AND PIX! TAG UR IT Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 02-12-2011 01:03 AM
DIY Rally Stripe Graphic Installation Tips (wet install) SUPERSPORTED Camaro DIY & HOW-TO instructions & discussions 26 10-11-2010 02:36 AM
Hardwire Radar Detector? mhennick Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-13-2009 10:27 PM
Radar detection systems? DGordon Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 68 04-02-2009 09:05 PM
radar and laser detector and jammers Az Sparky Off-topic Discussions 49 08-27-2007 10:03 PM
