Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 05-19-2014, 02:33 PM   #57
Virus
#551
Virus's Avatar
Drives: 2011 Camaro SS
Originally Posted by danvillekidd View Post
Does anyone have knowledge of HANS (or other brands) type safety devices? After several months and doctors visits I am learning about my neck problems. I want to continue to do AutoX and HPDE events, but I also want to protect my neck the best I can to minimize further damage. I have been using here and google to learn what I can, but I also want to turn to people with knowledge who can point me in the right direction.
Thanks
If you have harnesses in your car you should be wearing a hans. I have a professional series hans.
Virus is offline   Reply With Quote
Old 05-19-2014, 03:13 PM   #58
wakespeak
Drives: 2013 2SS LS3/NPP
Originally Posted by Balok View Post
Well, this is escalating rather quickly. I should have done this before I posted here so I'd know a little more about it. But I just spoke with my friend who is the GM of the dealership where I got my SS. We've been close friends for more than 20 years so I know I can trust him. I asked him about what they could do, and about all they can offer me is a set of higher performance Brembo pads for the front, and swap out the fluid. He also said that any mods I make like the stainless steel lines would probably void my warranty on the braking system. It is unclear however, whether that would void the warranty on let's say the master cylinder if it goes out though, so I don't know what to do, lol. This is getting a lot more involved that I imagined, but if it keeps me from doing something like this at 9:20, it's worth it.
Don't get overwhelmed with info. You will be fine with the stock brake lines and stock pads. The fluid is a good idea because boiled brake fluid is harder to cope with, but not a requirement in the novice groups. Drive as fast as you are comfortable; you don't have to be "on the gas" or "on the brakes" all the time as in racing.
SS brake lines improve pedal firmness/feel. Therefore your braking is more precise and can occur later, but we're splitting hairs here. The brake fluid upgrade will keep you safer, but I doubt anyone else had upgraded their brake lines or fluid in the green (novice) group I ran in. Just be aware of the possibility of fade later in each session after a high speed straight.
Edit: I looked at the video and that guy had a system brake failure, not overheated fluid or pads.
Basically brakes fail with pedal to floor: boiled fluid or brake fade (pedal normal but car not slowing down as well).
If you notice the brakes fading inform your instructor and slow down for a lap or 2. If your pedal goes to the floor - pump it a few times to build pressure!
Someone else with more track time than I may want to offer their opinion as well.
wakespeak is offline   Reply With Quote
Old 05-20-2014, 12:49 AM   #59
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Balok,
What you see in that video is indeed brake failure. Whether it is a malfunction, brake fluid boiling or brake pads fading they are ALL FAILURES!!! His car was setup for the track and he had a failure. If you want to avoid this type of thing then plan ahead. Do what is listed in the original posting and prepare your car. Could you possibly, maybe, kinda sorta get away with it using the stock brake pads and fluid, sure if you tenderfoot it. Do you really want to chance taking your brand new $45K car on to a RACETRACK and risk it? Do you like to play russian roulette?
Look, am I being harsh here, YES. The life or car I save just might be yours. There is no reset in real life. This is not iracing where you can hit reset when you crash. Prepare your car with the proper equipment from the jump and you will be a better and safer driver for it. Find a speed shop near you and build a report with them if you can't do the work yourself but get the work done the right way. The couple hundred you spend now could save you thousands later.
I mean you live in Nascar country FFS, there has got to be a shop around that can do this for you relatively cheap.
BTW, that crash you see at 9:20 probably cost that driver about $7-10K if the airbags went off because his insurance probably doesn't cover his car on a RACETRACK. Not to mention the CONCUSSION AND 1.5' GASH IN HIS HEAD.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 05-20-2014, 08:32 AM   #60
Balok
Balok's Avatar
Drives: people crazy
Do you really want to chance taking your brand new $45K car on to a RACETRACK and risk it? Do you like to play russian roulette? Look, am I being harsh here, YES. The life or car I save just might be yours. There is no reset in real life. This is not iracing...
Oh, make no mistake, I am not comparing this to iRacing in any way other than I know the layout of the track. Believe me, I know full well the seriousness this entails which is exactly why I'm talking to you fine folks. And you're absolutely right that a couple hundred bucks is nothing compared to totaling my new car so I intend to get these things done 100%. I'm just a complete noob and need guidance.
To that end, exactly what brand and model of pads, fluid and lines do you guys recommend? Unfortunately, I'm not a mechanic and I know absolutely nothing about high-performance stuff, so someone could sell and install something not even as good as the stock Brembo's for all I know. Also, if anyone knows a reputable and trustworthy high performance shop in the Greensboro/Winston-Salem area that would be greatly appreciated as well.
Balok is offline   Reply With Quote
Old 05-20-2014, 08:59 AM   #61
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
Brake fluid - Either Motul RBF600 or Brembo LCF600 (at $20 per 1/2L). ATE200 ($17/L) is maybe a step back in terms of dry boiling point but is certainly usable when you're first getting into open tracking. You'll probably want at least 1.5 liters.
Pad suggestions have already been made. OE, HP+, and XP8 that I know of, and I'd generally put the XP8 at the top of that list for track use.
Norm
Norm Peterson is offline   Reply With Quote
Old 05-20-2014, 02:21 PM   #62
Balok
Balok's Avatar
OK, here's the final verdict!
Goodridge SS/Braided brake lines: from the cost he quoted me, it looks like the standard set, not the super duper set, but should be better than the stock rubber lines nonetheless, right? $175.00
Hawk HP+ pads: $330.00 for the set
Motul fluid
Not sure what he'll hit me with labor, but I know it won't be cheep in "Race City" (Mooresville, NC) lol. I was referred to this shop by a neighbor I met this weekend who also has a 5th Gen Camaro. He said this guy does most of the custom work for many people in the NC 5th Gen Camaro Club. I've seen some pics of his work and from the looks of it, he's very good. (crosses fingers)
And it also turns out that my neighbor is restoration manager at a restoration shop called "Classic Muscle" in Winston-Salem. He has his wife's silver SS parked in front of the house as I went by Saturday, and I stopped and introduced myself. I'm sure they thought I was a psycho or something, lol. They seem to be pretty cool folks.
Anyway, I'm rambling, lol. Thanks again everybody, and any final thoughts on the parts?
Old 05-20-2014, 05:01 PM   #63
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
Motul fluid
I tried a set of Hawk HP+ pads on my 1LE. The first day out with these pads, (they were bedded and on the car for the two hour drive to the track) I got the meatball flag (Mechanical problem - pit now) because the flag stations were seeing sparks off the front wheels of my car on the first session of the first day. The mechanic that the school had on hand and I inspected the front suspension, brakes and steering and found absolutely no evidence of rubbing or any other reason for sparks. Missed one session doing this. Ran the two afternoon sessions, no problem. The next morning, same thing, meatball flag for sparks. Inspected again, no reason. Took off the Hawk HP+ pads and reinstalled the Stock Brembo pads. Three track days later no meatball flag for any issue.
I am using SS Braided lines and Motul RB600 brake fluid and the stock Brembo pads.
Watch my video from my last track day at Watkins Glen in the Road Course/Track and Autocross - Official Road Track Videos Post #40 and you can see I am not taking it easy on my brakes. I have experienced absolutely no brake issues with the stock Brembo pads. I am not the fastest car on the track or the best driver, but I am in the High Intermediate / Advanced run group and am not running slow.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
Old 05-21-2014, 11:41 AM   #64
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
OK T. I'm running out of time before my track event (practice) on Sunday.
My car is stuck at the dealer with service air bag issues and I have new tires going on Friday.
My issue is brake fluid and flushing the lines. Can I get a way with just sucking out the reservoir fluid and replacing that until I get time to replace it all? Basically some better than nothing. Hopefully I'll have time to do it right, but it's getting close now.
Old 05-21-2014, 11:48 AM   #65
Norm Peterson
Then fluid that you most want to get flushed out is the stuff that's sitting in the wheel cylinders and the flexible hoses that attach to them.
You don't need much more than a warm body who can follow directions when to press the brake pedal, when to hold it, and when to release it.
Norm
Old 05-21-2014, 11:57 AM   #66
mlee
www.CamaroFest7.com
mlee's Avatar
Norm
Thanks Norm... I hope to do this on Saturday
Old 05-21-2014, 10:55 PM   #67
TBone
TBone's Avatar
Balok,
Goodridge are a good set. Decent price. I would never run Hawk pads on my car at the track, JMHO. Try Carbotech XP-10 or 12 front and XP-8 Rear. These are good pads and they are gently on the rotors. Good pads to learn on. You have to order them so I do not know when your event is but CTbrakes.com is direct. Motul 600 is good stuff, priced right @ $15ish
(If, and it is a BIG IF, I were to put Hawk pads on my car they would be the DCT-70/DCT30's or DCT30/hp+ combo but I would have to look at the track and check the speeds to decide which ones would be appropriate.)
Mike,
Yes, squeegee, or slurp, out what you can but you still need to bleed out the lines and calipers. The best way to do it is put your pads on and bleed, then go bed your brakes, getting into your ABS, and come back in and bleed again to get the most out of them the first time. Might need 4 bottles. You can never have extra brake fluid. You won't get it all and you will have some weepage at your bleeder screws on track the first time but don't sweat it.
Next time it will be easier and you will not have to bleed the second time because most of what you have in there will be DOT4 and you will just have to get the old stuff out. You really do not want old fluid when tracking so the safe bet is to bleed before every event.
T.
Track fix.
Old 05-22-2014, 08:55 AM   #68
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Norm
It certainly helps to have a warm body that knows how to bleed brakes haha! I did the first round with my wife working the pedal off of verbal commands. The 2nd round I had a buddy that knew what was up by pedal feel. It took proabably 1/10th the time to make it through all 8 bleeders with him on the pedal.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-22-2014, 12:07 PM   #69
Balok
Balok's Avatar
Originally Posted by TBone View Post
Balok,
Goodridge are a good set. Decent price. I would never run Hawk pads on my car at the track, JMHO. Try Carbotech...
Unfortunately, the parts have been ordered already so it is what is at this point. I'm going to use them for this track day, then swap them out with the stock Brembo pads after the event. If I enjoy this enough, I'll look into a different pad if I do this again. If it rains, I won't be on the track at all so no harm-no foul other than the money I lose. I'm not driving my car in the rain with the windows down, period. Thanks for the advice Tbone, and everyone else!
Old 05-22-2014, 12:15 PM   #70
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
A lot of times they will allow windows up when it's raining.
LMS Engineering
White_SS/RS is offline   Reply With Quote
brakes, hpde, road course
