Jason 98 TA
Old 03-22-2014, 09:32 PM   #1
chuckclanton
Drives: 2016 Camaro 1/SS
Does a ZL1 "push" likea SS?
So.....I got my SS all sorted out and then traded it in on a ZL1! Don't like the tires for a start. However am I going to have the same understeer issues with the ZL1?
chuckclanton is offline   Reply With Quote
Old 03-23-2014, 10:18 AM   #2
L99CAMA2011
L99CAMA2011's Avatar
When the temps are cold yes, when pushed hard on corners, yes. Normal driving and legal speeds on turns not as much. If I had a ZL-1 I would run square and call it a day, issue will be reduced big time.
Old 03-23-2014, 10:56 AM   #3
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
Temps 70 plus the tires stick like glue. Temps 40s or less forget about it. Its a Slip n Slide and just a touch of throttle in a turn will swing her ass like a Vegas callgirl! Here in Mass the hiway on/off ramps are U shaped and really fun to put the throttle down. Speed limit is usually posted around 35/40 and I usually enter the turn at 75! At Low temps even the body(s) in the trunk will piss themselves. Be careful!
Normagene is offline   Reply With Quote
Old 03-23-2014, 03:12 PM   #4
chuckclanton
SOUNDS LIKE 285'S FRONT AND 295'S REAR MICHELIN SUPER SPORTS.
Old 03-23-2014, 03:28 PM   #5
L99CAMA2011
No sounds like you get some real wheels on there at least 10.5" at front or get the Z28 setup and run 295s all round. If I had a ZL-1 I know they would stick out but I would get the 20x10.5" all round with 295s and have a nice day. That setup you mentioned is going to put you in the same boat as stock. 285 Michelins aren't that wide, you need wide like I said in the past when you hit 11" threadwidth the magic box opens up for these cars handling wise .
