BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 07-30-2009, 11:55 AM   #1
DSworo9
Original Polish Memeber
DSworo9's Avatar
Drives: 2002 WS6 Trans Am
Converting Auto to Manual?
Does anyone have any knowledge on swapping out a auto trans for a manual? Difficulties? Is it expensive? Options? Thanks.
"Start living or start dying."
“I am a soldier, I fight where I am told, and I win where I fight.”
DSworo9 is offline   Reply With Quote
Old 07-30-2009, 02:14 PM   #2
Vash
Drives: 00 Blazer
If you could find the components at salvage or new parts. Unless you have a garage with a proper lift and tranny jack or tranny lift best to let a tranny shop do it.
Can cost from 1000 on up depending on what components you can scrounge up.
Have you considered a nice automatic upgrade?
http://www.transmissioncenter.net/35...erformance.htm
Old 08-02-2009, 09:50 PM   #3
camaro1185
Drives: 1988 Iroc 350, G92, 3.45's
Send a message via AIM to camaro1185
Lots of info in the trans section of thirdgen.org.
Heres some info to get you started:
http://www.thirdgen.org/manualswap
2004 Civic Ex
1994 Honda Magna 750
1988 Iroc-z
- 350 TPI
- T56
- 3.45 9bolt
- UMI EVERYTHING!
- Eibach Pro-Kit
- Tokico Illumina Shocks
- LS1 Brakes
camaro1185 is offline   Reply With Quote
Old 08-26-2009, 02:52 PM   #4
Zacko
Drives: 84 Z28
Best bet is to find a wrecked donor car and get all of the brackets, crossmembers and driveline.
It's a big job.
Why not just invest in a built tranny? The 700R4 like you probably have has a lot of aftermarket kits available and can be built to be pretty solid.
Zacko is offline   Reply With Quote
Old 08-26-2009, 02:58 PM   #5
rodimus prime
Drives: Cargo van.
I swapped a t5 into my 91z in my driveway. The only hard (and by hard I mean annoying) part was changing out the pedal bracket to allow a clutch pedal. Plus when you drill your holes for the clutch hydraulics be sure to add an extra peice of sheet metal to that spot. Mine eventually ripped my firewall. I didn know that on stock manuals that it was double walled there.
Seriously though sit back and plan it out. I did it when I was 19 with little mechanical knowledge. I could probably do that 80% drunk today and still do it better or faster than I did back then.
Oh and cut a nice hole for the shifter. Mine looked like Jaws took a bite out of my car.
rodimus prime is offline   Reply With Quote
Did you go with Manual or Auto? Age? Mayhem V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 493 07-16-2015 09:10 PM
2006 TRAVERSE CITY AUTO CONFERENCE KILLER74Z28 Off-topic Discussions 2 09-18-2010 10:45 AM
Remote Auto Start on Manual transmission? Treadstone 5th Gen Camaro SS LS LT General Discussions 35 06-22-2009 09:30 PM
Auto Or Manual (2010) SilverCamaroSS 5th Gen Camaro SS LS LT General Discussions 39 03-02-2009 08:14 AM
Auto vs Manual V6 Camaro Evilangel Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 02-11-2009 01:53 PM
