JDP Motorsports
Old 03-24-2014, 09:43 PM   #1
DragRacerX
DragRacerX's Avatar
Drives: 2017 ZL1 A10 HBM & 2012 2SS M6 IBM
SLP 25005 Brake-Control Kit Warning
A few days ago I had this professionally installed by MTI Racing on my 2012 Camaro 2SS/RS. Functionally it appears to work fine. HOWEVER, be forewarned: EVERY time you use it your dashboard will be lit up like a Christmas tree with warnings & error icons. The DIC will display "Service Stabilitrak"; the ABS, TCS, & TC amber warning lights will be lit up, too. According to SLP's description of the unit it says "This kit is custom fitted for the Camaro chassis and is fully compatible with the factory anti-lock braking and traction-control systems." Lighting up my dashboard is not my definition of fully compatible! SLP Technical Support confirmed what I have stated above as normal. How do you reset it? GOOD question, they only had suggestions. A reset tool or after awhile the computer will see everything is OK and reset itself.
2017 ZL1 Hyper Blue Metallic, A10 Trans, Carbon Fiber Hood, Navigation, Performance Data Recorder, Sunroof (Daily Driver)
2012 2SS/RS IBM / Gray Leather Interior, Technostalgia LED taillights, Magnuson TVS2300 SuperCharger with 3.40 Pulley,
Vengeance Racing VRPD-2 Cam Kit, ZL1 Fuel Pump, Injector Dynamics ID850 Injectors, Forced Induction Interchiller,
Cold Air Inductions Inc CAI, BBK 40210 LT Headers With Free Flow Cats, MBRP S7022409 T409-Stainless Steel
3" Dual Cat Back Exhaust System, Lingenfelter ZR1 Dual Disc Clutch Kit, ZL1 Brake Kit Rotors & Calipers
628 RWHP/596 RWTQ / A.C.E.5
DragRacerX is offline   Reply With Quote
Old 03-24-2014, 09:52 PM   #2
sycraft
COTW 5/06/2013
sycraft's Avatar
Should be normal, just like you have your have your car on a dyno. If it sees the rear wheels spinning and the fronts not it will light those up. Any Line lock will do that. It will clear once you start to drive.
Old 03-25-2014, 10:01 AM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I agree with Sycraft. It just means all those systems are functioning properly. Although, you should disable your "nannies" though when using this. It will still illuminate your lights, but at least the ABS and traction control won't be fighting to try and correct the loss of traction. Once you turn off the car and turn it back on the system will reset itself, or like mentioned after you drive it a few miles, the systems should reset.
BMR Sales is online now   Reply With Quote
