SDTW Custom Wheels & Tires
Old 03-25-2014, 07:27 AM   #1
Brazensol
Brazensol's Avatar
Drives: 2011 2SS/RS 2010 Silverado WT+
Lowering Springs
I have a 2011 2SS/RS with the dealer installed 21" wheels/tires (245 front and 275 rear). I want to lower the car about 1" front and 1.5" rear to get the car to sit level. Anyone see any issues with this combo? Thanks!
Brazensol is offline   Reply With Quote
Old 03-25-2014, 09:21 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The only issue would be finding a set of springs with those specs. The closest thing I am aware of would be to buy a set of BMR 1 inch front springs and their 1.4 inch rear springs separately. I think that might over shoot leveling it off though, especially if you ever have rear seat passengers or anything in your trunk.
Old 03-25-2014, 09:25 AM   #3
jrhagen
Banned
Drives: Camaro
Forget the springs, get coilovers.
jrhagen is offline   Reply With Quote
Old 03-25-2014, 09:31 AM   #4
Brazensol
Brazensol's Avatar
Right now I measure 4.5" from the tire rim to the fenderwell on the front and 5.0" on the back so if the springs are accurate as stated it will still be ever so slightly higher in the back. Won't often be anyone in the back so that is not too much of a concern to me. More concerned whether the 21"s will cause rubbing issues... Seems like the guys with the 20's don't have much, if any, problem with rubbing.
Old 03-25-2014, 09:32 AM   #5
Brazensol
Brazensol's Avatar
That would certainly be the best way to go!
Old 03-25-2014, 09:34 AM   #6
Apex Motorsports
That would be the best way to handle it.
They shouldn't. We have customers running lowered cars on 22s with no issues.
Old 03-25-2014, 12:26 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
You will not have any problems on factory wheels. It's only when you go with aggressive offsets and/or wide wheels and tires that you will run into issues when lowering. I suggest going with the BMR split drop 1" F 1.4" R for what you are trying to do, or coilovers; that way you can set the height exactly where you want it.
Best regards,
Tyler
888-308-6007
Old 03-25-2014, 02:22 PM   #8
tj@LSRPerformance
tj@LSRPerformance's Avatar
Drives: 2011 Camaro
You can check out our springs here:
http://www.lsrperformance.com/lsr-co...g-springs.html
LSR's Competition Lowering Springs will lower your Camaro 1 inch in the front and 1 1/4 inches in the rear for a more level ride height and better weight distribution. These springs are a direct replacement for the factory springs.
Improved shocks and struts are recommended to maximize performance and ride quality.
As long as the wheels are the correct offset, there should not be an issue.
Best Regards,
TJ
tj@LSRPerformance is offline   Reply With Quote
Old 03-25-2014, 04:30 PM   #9
Brazensol
Brazensol's Avatar
Thank you Gentlemen! Now I just need to decide on springs or coilovers...
