sjm autoprod
Old 03-25-2014, 07:58 AM   #1
juandavr
Drives: BMW M235i
So it's happening again...strong vibration during braking
Hi guys.
As some of you may remember, several months ago i Had a problem when braking from high speeds (say about 60mph), basically was a strong vibration and due to that all my rotors were changed under warranty and It was solved...not.
Lately It appeared again strong vibration BUT this time it came with a high pitch noise when accelerating AND (this is what i'm worried about) an intermitent braking, you can feel that the car brakes for ons second, let go, then start braking again, all this until the car stops.
Any guess about it? I am worried that it might be the ABS the one causing the problem, because as I said my rotors are new and pads were changed 4000km ago. I'll take the car to the dealer tomorrow
Please help! And thank you!
juandavr is offline   Reply With Quote
Old 03-25-2014, 10:14 AM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
If your rotors aren't warped then could possibly be StabiliTrak. Dealer should be able to see ST in ecu log
jeremywes is offline   Reply With Quote
Old 03-25-2014, 10:20 AM   #3
Ret Fuzz
Ret Fuzz's Avatar
Drives: 2010 Camaro
warped rotors for sure.
Ret Fuzz is offline   Reply With Quote
Old 03-25-2014, 10:55 AM   #4
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
To me, this sounds like either an electronic thing (stabilitrak or ABS) or a problem with your brake fluid.
Air in the brake lines? How are your brake fluid levels? You may have a small hole in a brake line.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-25-2014, 11:00 AM   #5
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Describe the problem again please..
Are you decribing very hard braking from a high rate of speed and the the car kind of vibrates violently during deceleration? That could just be the way the ABS feels..
Or are you describing something different?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-25-2014, 11:50 AM   #6
juandavr
Drives: BMW M235i
Kind of, sorry about the lack of information. It's basically: strong vibration when deccelerating from high speeds, intermitent braking (1 second braking, 1 not, 1 braking, 1not etc) from all speeds all the way down until the car stops, and high pitch squealing noise when accelerating from a standing point.
I think (im not sure) that the vibration might be caused by the intermitent braking, such braking at high speeds may feel that way.
Thank you all
Old 03-25-2014, 12:02 PM   #7
SPCBA
Drives: pleather and Chiclets
Buddy had a similar problem. Something was bent in suspension and it freaked out his abs...went through a long ordeal to figure that out.
SPCBA is offline   Reply With Quote
Old 03-25-2014, 12:04 PM   #8
juandavr
Drives: BMW M235i
Last time I checked them were good (last saturday) and there was no sign if leaks in the garage floor, will check again later and will also check the lines. I will tell you if i find anything.
Old 03-25-2014, 03:59 PM   #9
Colt
Colt's Avatar
Drives: 2010 Camaro 1LT/RS Victory Red
I've read somewhere about the v6 brakes having similar problems before, and I think it turned out to be the rotors. I'll see if I can find the thread.
Colt is offline   Reply With Quote
Old 03-25-2014, 08:28 PM   #10
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
the on/off on/off ... sounds like ABS engaging. You can test this any time by braking hard when it's wet. If you are braking hard at any time, ABS can/should be engaging to prevent wheel lockups.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 03-25-2014, 11:50 PM   #11
Chevrolet Customer Svc
Drives: GM Vehicles
Originally Posted by juandavr View Post
Hi guys.
Oh no juandavr!
I apologize for the vibration concerns you're experiencing and definitely understand the displeasure. By all means, please feel free to message us privately if you'd like to proceed with possible assistance, or to discuss this situation further.
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is online now   Reply With Quote
Old 03-26-2014, 12:15 AM   #12
juandavr
Drives: BMW M235i
Originally Posted by Chevrolet Customer Svc View Post
Oh no juandavr!
William R.
Thank you so much guys for your support, it says a lot about how much you care about your customer, Altough I dont know if you can help me because I live in Colombia. Ill be in contact with you if anything shows up
Old 03-26-2014, 12:23 AM   #13
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Oh no juandavr!
William R.
no offence but all you do is kindly tell someone to basically "take it to the dealer" 4 thousand postings of " were sorry and apologize and understand yadda yadda yadda"
cant you guys get a out of work tech on this forum lol....hey its ok i understand
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-26-2014, 06:18 PM   #14
juandavr
Drives: BMW M235i
Hi guys, took it to the dealer, same diagnostic as before, waarped rotors, the rotors will arrive by monday and will be replaced under warranty
