JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 07-30-2009, 02:09 PM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
New! Retractable Front License Plate Frame/Holder! Hide your front license plate!
2010 Camaro Retractable Front License Frame
Are you in one of those states where you are required to run a front license plate? If so, this is one accessory you cannot be without.
2010 Camaro retractable front license plate holder. With this retractable plate holder you can hide your ugly front plate within seconds, simply fold it down and stow away. If your on the road just pull it out and flip it up, no more tickets and no more hassle from the authorities. Installation requires just two small holes to be drilled under the front bumper or double sided tape. Adjust up or down in less than 3 seconds!
We currently do not have any other pictures on the Camaro except for the one below.
Available here: http://rpidesigns.com/shop/item.asp?itemid=1672
Here is what the frame looks like while folded down, mounted on a Corvette.
RPI Designs is offline   Reply With Quote
Old 07-30-2009, 03:06 PM   #2
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Will this work with the ground effects front lip?
Old 07-30-2009, 03:16 PM   #3
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
See other posts for issues with this on the LS/LT trim.
http://www.camaro5.com/forums/showth...d=1#post739582
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 08-24-2009, 01:05 PM   #4
nickruta
Drives: 2010 black camaro
I need one with a motor!!! Anyone out there can post a link!!
nickruta is offline   Reply With Quote
Old 08-24-2009, 02:44 PM   #5
Red Hot SS
Red Hot SS's Avatar
Drives: 2010 Victory Red 2SS/RS M6
This is dumb...that Helljumper guy did it with a motor. YOU CAN STILL SEE IT when its retracted. 100% waste of time and money.
Not sure how much you can see this one when its down, but on his it looks awful
Virginians Join Group: Virginia is for (Camaro) Lovers!
VIN: 2G1FT1EW8A9118043
Finally Home! (6/16)
Red Hot SS is offline   Reply With Quote
Old 08-24-2009, 04:16 PM   #6
tjd24
tjd24's Avatar
Here's the link to Altec Products - http://www.altecproducts.com/
Just be mindful of the other posts on this product - if you have a LS/LT the bumper fascia has an angle that doesn't allow the "Show N Go" frame (manual or powered) to lay horizontal. I bought the manual and didn't install it for this reason. I have been working with another member on a bracket but that doesn't look like a solution either.
So far I've been running sans front plate with no issues...
Old 03-14-2010, 10:13 PM   #7
Matrix
Matrix's Avatar
Drives: '10 Camaro 2SS/RS & Magnum R/T
No it will not I am told.
here is mine on youtube!
SIM Camaro 2010 V8-2SS/RS-A6!!+
Matrix is offline   Reply With Quote
Old 03-15-2010, 07:37 PM   #8
Zalirid
Drives: CGM 1LT RS
Does it have to be on the front of the car, I got some suction cups from wal-mart, ones with hooks for bathroom use or whatever, I pulled the hooks out and the suction cups have a small round bit on the non suction side, stuck em through the holes in the plate and suctioned them inside the front windshield on the bottom part, passenger side when I went down to Texas. I am from Texas and it is registered there, although I live in Arkansas, which does not require front ones. I never got hassled with that. Not quite sure what the law states though
Zalirid is offline   Reply With Quote
Old 03-24-2010, 05:25 PM   #9
pkauf
pkauf's Avatar
Drives: 2013 Crystal Red Convertible RS
just got my retractable front plate holder from you - I have a 2LT - I don't get how I'm supposed to get the thing to work properly with the angle of the bottom of the front bumper (I don't have a problem drilling underneath, but the angle doesn't work). Your instructions (which have mustang on them GRRRRRR ) - talk about washers, but there are none included, and I think I'd have to put like 6 normal washers to get it right - then the SS screws you sent wouldn't be long enough (at least it appears that way). Give me an idea on how to get this to work please . . .
Thanks
pkauf is offline   Reply With Quote
Old 01-05-2016, 10:38 AM   #10
RPI Designs
Old 01-05-2016, 11:06 AM   #11
FoxSS
Drives: 2014 Camaro 2SS RS
Just ordered. Thx
FoxSS is offline   Reply With Quote
Old 05-16-2016, 09:03 AM   #12
RPI Designs
Old 10-01-2017, 04:58 PM   #13
RPI Designs
Use coupon code LANA5 to receive 5% off your order!
FOUND PETITION TO GET RID OF FRONT PLATES The_Beast_ USA - California 90 03-29-2012 01:54 AM
Not having front license plate attached by dealer New2010CamaroLover 5th Gen Camaro SS LS LT General Discussions 154 10-07-2010 05:01 PM
Front License Plate Bracket blackZbandit 5th Gen Camaro SS LS LT General Discussions 76 08-17-2009 06:51 PM
Front license plate SSCamaro2010 Cosmetics and Lighting Modification Discussions 21 04-25-2009 05:07 PM
front license plate myold88 5th Gen Camaro SS LS LT General Discussions 26 02-16-2009 08:09 AM
