Elite Engineering
Old 07-30-2009, 03:52 PM   #1
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
Analog Speedometer Not Working
I noticed this last weekend when driving the car home from Baton Rouge, the analog meter did not go around with all the other meters when I started up the car. It also did not move until I was going about 60mph, at that point it was showing I was going 12 MPH when the digital displayed 60. Then I stopped to get gas and it started to work like normal again. It did this again last night. Anyone know what is going on? Is it the computer or the servo motor could be going out? Here's a Pic
fieldgoal00 is offline   Reply With Quote
Old 07-30-2009, 03:56 PM   #2
fbodfather
fbodfather's Avatar
Most likely the vendor put the speedometer needle on and the end is just slightly bent and 'catching' on the face of the speedometer.
Stop by your dealership - they should be able to correct it for you.
I'm sorry that you had this inconvenience.
Old 07-30-2009, 04:04 PM   #3
fieldgoal00
It worked perfectly the first 2000 miles, why would it hang up now? How hard is it to replace? Now they are going to just replace the needle or the whole gauge assembly? My concern is if you remove the needle to replace a new one, you have no idea where "0" is when you put the new needle on, so my MPH will be off on the analog gauge.
Old 07-30-2009, 04:07 PM   #4
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Heat!
It's hot and the needles being pressed on too deep have caused the material to expand and hence...sticking.
Mine is the exact opposite...my speedo says I'm going 140 mph when doing 60! I've actually buried it a few times!
Mine is on order at the dealer already...and there is a service bulletin about this...jsut stop by your dealer and they'll get you another one ordered up.
Legend is offline   Reply With Quote
Old 07-30-2009, 04:08 PM   #5
fieldgoal00
they are replacing only the needle or the whole gauge assembly?
Old 07-30-2009, 04:09 PM   #6
fieldgoal00
Originally Posted by Legend View Post
Heat!
Do you understand my concern of them simply taking the old needle off and replacing it? There is no way for them to know how to set the needle back at "0"
Old 07-30-2009, 04:26 PM   #7
PolishMike
PolishMike's Avatar
Drives: 2010 2SS RS
Why not? I havent taken one apart but there is definitely a way to align it.
IOM w/ White Stripes 2SS RS M6 #17772
Now - Stainless Works 2" Headers, Intake, Cam, tune, ect
And shepherds we shall be, For thee my lord for thee. Power has descended forth from thy hand, that our feet may swiftly carry out thy commands. So we shall flow a river forth to thee, and teeming with souls shall it ever be.In nomine Patri, Et Fili, Spiritus Sancti
PolishMike is offline   Reply With Quote
Old 07-30-2009, 04:29 PM   #8
fieldgoal00
the other problem is we all know that once you open something up, it never seals properly again, it's going to eventually make noise or rattle sometime in the future.
Old 07-30-2009, 04:29 PM   #9
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
They replace the entire gauge, not just the needle.
Old 07-30-2009, 04:30 PM   #10
fieldgoal00
the mph gauge is a seprate unit than the rpm and the gas and temp gauge?
Old 07-30-2009, 04:32 PM   #11
PolishMike
PolishMike's Avatar
Drives: 2010 2SS RS
Yes.
Old 07-30-2009, 04:34 PM   #12
fieldgoal00
i thought they would all be on the same board like many other cars.
Old 07-30-2009, 04:34 PM   #13
Legend
Hello!
Legend's Avatar
Yeah they replace the entire cluster...even the bulletin says to order a new cluster...not just needles or to adjust the needles....
Old 07-30-2009, 04:35 PM   #14
fieldgoal00
Heat!
do you know if your dealer ordered another needle for you or an entire gauge?
Dash gauges not working and clicking noise Tigerrag24 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 26 02-26-2013 03:16 PM
Speedometer on LT vs SS Myssi Cosmetics and Lighting Modification Discussions 17 04-06-2011 05:48 PM
speedometer 25thanniversary 3rd Generation Camaros 12 10-03-2009 01:23 AM
KPH to MPH analog guage change out (HELP) khislop007 Cosmetics and Lighting Modification Discussions 16 07-07-2009 12:41 AM
V6 Analog Speedometer bond2 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 07-01-2009 08:08 AM
