Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Suspension / Brakes / Chassis
Old 03-25-2014, 09:47 PM   #1
rjames's Avatar
Drives: 2012 45th 2ss
Confused on tourque specs. BMR/PEDDERS??
Ok I did my 1" BMR spring kit last week and i am now confused on the specs. In the instructions it has all the specs for the bolts for when timing the bushings. But.... in doing this it seemed to me that the specs were way to light in spec. so i pulled out my pedders tourque spec sheet and they are both different. Pedders says to put an extra 120 deg after initial tq on some of the bolts. Now this seems better to me. as for example the tq spec from bmr for the lower control arm bushings is 32 ft lbs for both bushings, and pedders says it is 85 ft lbs for the inner and 30 ft lbs for the outer with an extra 120 deg. Makes me wonder who to believe?
Any thoughts?
Thanks Rob
2012 45th M6 Coupe, Stock internals,Cam/springs,ARH 1 7/8 cat delete,Flowmaster american thunder Cat back, 3:91 gears and K&N Cold air kit. 484 RWHP 454 TQ.Acs body kit,Bmr 1" springs,Vfn copo hood going on soon! Tuned by Speed Inc. Dss 3 1/2 aluminum shaft, Dss 1000hp level 4 shafts, Eaton True Track.
rjames is offline   Reply With Quote
Old 03-26-2014, 12:44 AM   #2
JCunningham's Avatar
Drives: 2017 2SS M6
the Peddlers specs are if you are using new GM bolts. these are torque to yield bolts. The BMR specs are for if you are using the old bolts. Its best to use new bolts. there cheap to buy. The GM bolts stretch on when you degree them.
real ZL1 wheels 285/305 Michelin Pilot Super Sports, Pray ported IM/TB, EFI Tuning Flex fuel kit, American Racing Headers 1 7/8" long system w/ cats H pipe to NPP. Full 1LE suspension package with BMR adjustable sway bars and links.
JCunningham is offline   Reply With Quote
