JDP Motorsports
Old 03-26-2014, 10:34 AM   #1
Casper954
Casper954's Avatar
Drives: 2010 Camaro 2SS
Knocking coming from passenger side of the car?
Hey guys so I just recently installed lowering springs about 1000 miles ago and a couple days ago my car started to make almost like a bang when I go over speed bumps. Now when I drive it's starting to make the same noise when I turn the wheel quickly. I have a feeling the bolt on top of the strut tower is a little loose but when I went to check if I could move the strut from under the hood, there was no play or movement. Has anyone experienced this problem before or know what could be the issue?
Appearance: Blacked out tail lights, Oracle Plasma fogs, SLP Carbon Fiber splitter, Carbon Fiber Hash Marks, Carbon Fiber ZL1 hood, 20" Giovanna Kilis rims, Eibach lowering springs
Performance: Straight-piped magnaflow exhaust, K&N intake
Casper954 is offline   Reply With Quote
Old 03-26-2014, 11:11 AM   #2
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
Check to see if spring is seated correctly? If its turned on the perch where it isnt lined up it can move and cause noises
13blackLS is offline   Reply With Quote
Old 03-26-2014, 12:01 PM   #3
midlifeSS
You can't take it with u
midlifeSS's Avatar
Drives: 2010 camaro ss/rs,2014 sonic rs
May want to check to make sure all hardware is tight and that nothing has loosened up like end links,shock mounts,trailing arms,control arms,toe arms,ect.
midlifeSS is offline   Reply With Quote
Old 03-27-2014, 12:07 AM   #4
Casper954
Casper954's Avatar
Ok thank you guys I will take a look but when I checked before everything was tight
