Caryle Racing
Old 03-26-2014, 12:02 PM   #1
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Lower control arm bushings
I am looking to further upgrade my suspension (see current mods in signature). On my to do list are toe rods, trailing arms, and solid subframe bushings, but I was curious as to the lower control arm bushings.
I still have the FE3 style suspension, and since I've already upgraded the sways I really don't want to replace the LCA's because it would mean a new sway too.
That being said, would it be worth my time to go ahead and upgrade the LCA bushings? Or would I be better served waiting for the toe/trailing package and subframe bushing upgrade?
Obviously I'd like to eventually get it all done, but I'm just trying to better utilize my piece-wise upgrade bang for the buck.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-26-2014, 12:24 PM   #2
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
bang for the buck: toe rods and trailing arms + outer trailing arm bushing
In your sig you list Pedders subframe inserts, so there will be a "bang" if going to solids or full, but less than coming straight out of stock.
IMO, work toward affording the best toe/trailing arm _ outer trailing arm bushing combo you can and if there is any left over solidify the subframe, and if there is any more left over do the LCA bushing.
If you don't think new LCAs are in the budget, don't forget about getting the sway bar endlink support plate for the stock LCA. It will help keep those Pfadt endlinks from ripping out the LCA mounting bracket.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 03-26-2014, 12:31 PM   #3
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I should have mentioned that I would do the outer trailing arm bushing with the toe rods & trailing arms. To me, it's a given.
I installed the reinforcing tab when I did the sways/endlinks. I just didnt think it was signature worthy.
Old 03-26-2014, 12:35 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The factory LCA bushing is actually pretty good. Your money is better spent on the trailing arms, toe rods, upper CAB's and solid subframe mounts.
Best regards,
Tyler
888-308-6007
Old 03-26-2014, 01:00 PM   #5
ClawSS
High-tech Redneck
ClawSS's Avatar
No worries, I wanted to be thorough. Your ending with "piece-wise bang for the buck" lead me into an assumption. I am just happy that Tyler backed up my wordy response. Upper CAB's would be an upgrade I did not do when the cradle was down just due to my lack of power mods. I really have no opinion and might have done it if Chase @ Apex hadn't talked me out of it...at that time.
Old 03-26-2014, 01:08 PM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Agreed, I wouldn't worry about the inner LCA bushing right now, not until you're ready to upgrade to aftermarket LCA's. Until then, Trailing Arms, Outer T/A Bushings, and Toe Rods are your best bet right now. And don't forget about those rear upper control arm bushings. It's a good idea to do those while the cradle is lowered down a bit when you're changing out the cradle bushings. I highly recommend the BK039, simply because it is so much easier to swap out the entire bracket rather than trying to press the OEM bushings out of the factory brackets. Just my .02 cents!!!
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 03-26-2014, 05:20 PM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Playing around on the JDP website, I'm looking at something like this:
JDPS1001 - Rear Upper Control Arms bushings w/brackets
7-142 - Prothane Rear subframe bushing kit
C10-201 - Spohn Rear trailing arms
C10-601 - Spohn rear toe links
BK006 - BMR Outer trailing arm bushings
This would pretty much cover it, right?
