Cold Air Inductions
Old 07-30-2009, 08:08 PM   #1
usmcjlp
Drives: 2SS/RS LS3 RJT
Effects of Cam Switch on Engine Life
What will the effect of changing a cam be on engine life?
I spoke with Mast Motorsports about their stage 1 (least Aggressive) cam which is designed to be used in conjunction with a supercharger. They told me any cam switch requires replacing the valve springs for proper engine wear. I also spoke with Ron at Vengeance Racing and he recommends changing the springs at 30,000 mile intervals to maximize life.
I intend to supercharge this engine. I am tempted for the price/performance gain to start by first replacing the cam. I don't want to lose the bottom or mid-range acceleration. I also don't want to damage the engine. I've read everything I can find, but don't understand it well enough yet. I have been following pharmMD's build, which is along the lines of what I intend to do.
I am by no means an expert and all vendors I mentioned here have been extremely helpful. If something is inaccurate please let me know.
Also, while the engine is taken apart would it be a good idea to replace any other internals? I do have a budget and will be forced to do this in stages. I intend to keep the car so I can take my time and do it right.
Any recommendations?
usmcjlp is offline   Reply With Quote
Old 07-30-2009, 08:48 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
lets pull this apart shall we...
just about any cam swap will require new springs. reason being is that GM designed the springs on this motor to work with this cam. if you swap in another cam with a higher lift value, then you are pushing the stock springs further than they were intended to go.
as for the 30k, ive heard of it, but never done it. and dont know any one else who has, with the exception of guys who are thrashing their cars at the track all the time and pushing every bit of their motors to the brink.
if you know for an absolute fact that you are going to supercharge the motor, then you will want a cam that will maximize the supercharger's added power. that being said, some blower cams without the blower can drive/feel like @$$ as they are made to work in conjunction with a s/c.
and since you are going to be pulling the top of the motor apart anyway, id hold off on the cam swap until you are ready to do the s/c install. as you need a tune 99% of the time with a cam swap. (the other 1% is for hot cams and such that are just a bump over stock and while you still need a tune with them, you can function without)
we've already seen that the LS3 can take quite a pounding without the need to upgrade the internals. if you have the budget for it, look into getting your heads ported and polished. also if you havent done it already, a CAI and headers should be on your to-do list.
give Mast another call and talk to them with your plans in detail on your overall goal with the car.
I piss excellence
and fart awesomeness
Old 07-30-2009, 10:09 PM   #3
O2BQIK
Drives: 1991 Camaro RS
I tend to agree w/ the above post...if you're definitely going to supercharge it, I'd do the cam at the same time. I have a friend who built a Cobra engine to supercharge but hasn't supercharged it, and I wouldn't want to live with those cams.
And yes, you should upgrade the valvesprings with a cam.
2010 Camaro SS in black/beige: Sold. | '91 Camaro RS: Still the dream car!
'98 Camaro SS: Incon twin turbo. Sold | '99 Camaro SS: Heads/cam/bolt-ons. Sold.
O2BQIK is offline   Reply With Quote
Old 09-23-2009, 09:52 PM   #4
fuffl
Drives: #3124!!!
I'm doing a similar swap with a slightly more aggressive cam. The local speed shop I ordered from said I'd be fine with stock lifters/pushrods since the car is brand new. I'm skeptical. Anyone know the limits of LS3 pushrods?
fuffl is offline   Reply With Quote
Old 09-24-2009, 08:30 AM   #5
Jason@RPM-Motorsports
Jason@RPM-Motorsports's Avatar
Drives: 98 WS6
For $100-$110.00 I would go ahead and replace the factory pushrods As far as the changing the valvesprings every 30K miles that's always a good safe idea to tell all your customers. The lobes on the camshafts these days are pretty aggresive and harder on the valvetrain than the stuff that was built years ago.
Jason@RPM-Motorsports is offline   Reply With Quote
Old 09-24-2009, 09:03 AM   #6
Pope Designs
Drives: 2013 ZL1 Rally Yellow
I would personally replace the springs every 20K miles. It is a cheap investment in the long run.
Bryan
Pope Designs is offline   Reply With Quote
Old 09-24-2009, 09:03 AM   #7
bdg
bdg's Avatar
Drives: 2010 camaro
I would be skeptical of them also. The pushrods may be good enough but the valvetrain geomety will most likely change with the new cam. You would most likely need diff. length pushrods to get it right.
bdg is offline   Reply With Quote
Old 09-24-2009, 10:25 AM   #8
Ron@Vengeance
Ron@Vengeance's Avatar
Drives: 2013 Artic White GrandSport
The pushrods are a VERY smart investment when doing a camshaft upgrade. The more aggressive lobes will cause flex/distortion in the OEM pushrods.
As mentioned above, the smaller base circle of some of the aftermarket camshafts will require different length pushrods from time to time.
Changing spings, while alot of people dont do it, is an EXCELLENT investment in the longevity of your engine.. I have seen people push their aftermarket springs to 50,000 miles and come in with valve sticking thru their pistons... Not often, but it does happen.
Ron@Vengeance is offline   Reply With Quote
Old 09-24-2009, 10:43 AM   #9
JJ2010
Drives: 2010 Camaro SS
I sure am glad RPM is doing all my work on my Car......
They know there stuff and look after there Customers.....
JJ2010 is offline   Reply With Quote
Old 09-24-2009, 11:55 AM   #10
Drives: 98 WS6
Thank you
Old 09-24-2009, 12:17 PM   #11
duder4thgen
Drives: Bird
Go with dual valvesprings, worth the money.
duder4thgen is offline   Reply With Quote
Old 09-24-2009, 12:19 PM   #12
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Right on Ron!
Add a nice set of lifters and you are golden, for absolute performance and longevity.
Regards
IPS Brandon is offline   Reply With Quote
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
To break in or not to break in? Emu the Foo 5th Gen Camaro SS LS LT General Discussions 68 03-15-2008 08:12 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
Making Modern Horsepower the Old-Fashioned Way KILLER74Z28 General Automotive + Other Cars Discussion 14 02-02-2007 02:50 PM
