JUICEDMOTORSPORTS
Old 07-30-2009, 10:17 PM   #1
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
No digital speedo readout
I got my car 2 days ago and my digital speedometer does not work. Does it have anything to do with onstar because I have not set up my onstar account yet.
rex113 is offline   Reply With Quote
Old 07-30-2009, 10:27 PM   #2
My new Camaro
Drives: 2500 hd
i read another thread where the speedo quit
My new Camaro is offline   Reply With Quote
Old 07-30-2009, 10:28 PM   #3
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Setup your OnStar. Doing that will tell you whether OnStar is at all the problem. I would argue that OnStar has nothing to do with reading your car's velocity, but only you can setup Onstar on your car. Try that. If it does not work, then go to the dealer and see what is wrong.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 07-30-2009, 11:34 PM   #4
fastball
White 'n Nerdy
Drives: 2017 Camaro 2SS 6MT
OnStar has absolutely nothing to do with it - your speed readouts are taken from the VSS (vehicle speed sensor) in the transmission, sent to the car's ECM computer, and sent from there to the instrument cluster. And this works for both the analog gauge (which isn't really analog, just looks like an old fashioned gauge) and the digital LCD graphic in the center of the instrument cluster.
However, if your analog gauge does in fact work, and your digital gauge doesn't it's not the VSS. You might need a software reflash or something like that to get the digital display working again. It is possible the display itself is bad, but when you cycle through your DIC and start the car you get all the other readings and info in the display, right?
If you do, it's most certainly a software issue or computer issue.
Either way, take it back to the dealer and they should take care of it.
fastball is offline   Reply With Quote
Old 07-31-2009, 12:38 AM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
All the other vehicle information displays in the DIC?
Old 07-31-2009, 01:14 AM   #6
Vash
Drives: 00 Blazer
Rex this may sound cold but.. did you read the manual? It shows how to configure it.
If still in doubt ask your local service dept.
Good luck.
Old 07-31-2009, 08:00 AM   #7
fastball
White 'n Nerdy
Yes. Everything from fuel economy to vehicle speed to door ajar to engine temperature. It's all in the DIC.
Old 07-31-2009, 12:57 PM   #8
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
Please don't take this the wrong way but there is no such thing as a VSS (Vehicle Speed Sensor). Cars are equipped with WSS (Wheel speed sensors) that are either active or passive and are mounted at the wheel itself. Those speeds are fed into the rest of the ECU's (Electronic control units - ECM, BCM, etc).
Some fancy cars may have GPS VSS type things though...
Also, I think what the guy was asking is does he know how to use the DIC? As in see all of the other options on there.
Embalmer is offline   Reply With Quote
Old 07-31-2009, 01:01 PM   #9
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M
so who should i see about my speed not showing as well the only time it shows is during cruise control
Santos is offline   Reply With Quote
Old 07-31-2009, 01:03 PM   #10
PolishMike
PolishMike's Avatar
Drives: 2010 2SS RS
Either your dealer or a plumber... choose carefully.
IOM w/ White Stripes 2SS RS M6 #17772
Now - Stainless Works 2" Headers, Intake, Cam, tune, ect
And shepherds we shall be, For thee my lord for thee. Power has descended forth from thy hand, that our feet may swiftly carry out thy commands. So we shall flow a river forth to thee, and teeming with souls shall it ever be.In nomine Patri, Et Fili, Spiritus Sancti
PolishMike is offline   Reply With Quote
Old 07-31-2009, 01:11 PM   #11
firstmate
firstmate's Avatar
Drives: 2010 Blk/Gry SS/RS M6
I had a similar issue within the first 1 - 2 days. Except it was the opposite. My DIC worked but the guage needle stayed at 0. Took it to the dealer and they did a reflash, didn't work. They couldn't fix it so they ordered a new Instrument Cluster, got it in 1 day and installed the same day they got it. Both displays have worked ever since... So yes, take it to the dealer and they should be able to fix it within a couple of days I would think... Hope this helps.
Ordered 10-13-08 2SS/RS M6 BLK/GRY
VIN #2386
Delivered 6-11-09 - Woo Hoo!!!
Hey Houston locals--------
Join the H-Town Camaro Club
www.H-TownCamaroClub.com
firstmate is offline   Reply With Quote
Old 07-31-2009, 02:21 PM   #12
fastball
White 'n Nerdy
http://www.obd-codes.com/p0500
Vehicle Speed Sensor diagnostic code on all OBD-II vehicles (1996 and later). Yes, while it can be located in the wheels, it can also be located in the transmission or drive axle. This is what displays vehicle speed.
Wheel Speed sensors are used for calculating ABS, traction control, and stability control. These are of course always at the wheel behind the brakes.
Of course when you skid and slide your wheel speeds are all different from your vehcle speed.
Besides, if a VSS was in fact faulty he would have a check engine light or service vehicle message on the DIC.
Which is why I suspect a software issue in the ECM or IP controller.
Old 07-31-2009, 03:31 PM   #13
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Are you sure you set it up in the DIC properly ?? I had some difficulty getting it to work initially but has been fine since.
flht99b is offline   Reply With Quote
Old 07-31-2009, 09:32 PM   #14
rex113
rex113's Avatar
Good luck.
Vash I did not read the manual but when I just looked at it now it explains how to turn on the DIC. I have been a truck mechanic for the past 30 years and told the dealer not to explain anything about the car to me because I already knew everything.If it works when I try it tomorrow I will feel like an idiot.
