| 5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums. |
Thread Tools |
Just Lovin' My Camaro!
Drives: CGM 2LT/RS/AUTO Join Date: Apr 2009
What kind of gas are you filling up with in your '10 Camaro?
I'm thinking I won't be going to use regular unleaded in my 2LT/RS/AUTO(order status at 3300, yay!!) eventhough it is a v6 and only requires 87 octane, I will use 89 octane supreme. Or do you guys think there isn't much difference in the two and I might as well go Premium 91 octane, or just stick to regular 87 octane, and fill up 91 from time to time just to keep the engine clean? I know you guys who car about your Camaros are using Premium I hope.
Recommended Fuel If the vehicle has the 3.6L V6 engine reduced, and you might notice a(VIN Code V), use regular unleaded gasoline with a posted octane rating of 87 or higher. If the octane rating is less than 87, you might notice an audible knocking noise when you drive, commonly referred to as spark knock. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, the engine needs service. If the vehicle has the 6.2L V8 engine (VIN Code W) or the 6.2L V8 engine (VIN Code J), use premium unleaded gasoline with a posted octane rating of 91 or higher. For best performance, use premium unleaded gasoline with a posted octane rating of 93. You can also use regular unleaded gasoline rated at 87 octane or higher, but the vehicle’s acceleration could be slightly slight audible knocking noise, needs service.commonly referred to as a spark knock. If the octane is less than 87, you might notice a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine. If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, the engine
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT 50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!? ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!! GOT MY CAR!!!! AND I LOVE IT!!!! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
Don't use super in the LLT V6. The plus should be fine it just mixes both tanks 50/50.
But you don't even need to use that it's designed and tested with just pump unleaded. |
![]() Drives: SS for Super Sexy! Join Date: May 2009
using a higher octane will put slightly less stress on your engine due to the slightly higher potential compression rate of the increased octane... but GM has engineered the LTs to run on regular and says so in the manual i believe... if i had an LT i would just use regular like the manual says and save a few bucks per fill up...
the SS however is designed for premium gas
- Life is to short to let it pass you by
Master of All Things
Drives: '10' Camaro 2LT/RS,'08' Caddy STS Join Date: Jul 2009
I am and will be using regular, just likes designed for, anything more is a waste. I have another GM, and it sports the same engine, the 3.6 DI V6, it runs GREAT. putting plus or superme in will only drain you wallet faster, not give you better performaqnce.
I will be filling up with 94 octane once I have the car
- SK
- 2G1FT1EW9A9132212
![]() - Life is hard when destiny believes in you. - As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket. - Good money, bad girls. How can life be any better? - God saves. The devil invests. - This may be the ultimate guide to problem solving. |
#6 |
My baby is here
Drives: SIM 2LT Join Date: May 2009
94 octane. Purrs like a kitten.
#7 |
"El Dictator"
Drives: 08 HHR SS, 2010 Camaro SS/RS #16429 Join Date: Sep 2006
What I don't get is the owners manual for my HHR SS states to only use 91 octane or higher on it's 2.0L Eco-Tec. So why do they not require it in the 3.6L, 44 more horse power V6 that's in the LT Camaro? Is it because the HHR SS is turbo?
I use 91 in the HHR SS & my SS/RS Camaro!
#8 |
Just follow the owners manual.
#9 |
Running 93 down here in Alabama. 2SS of coarse though.
#10 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
I found the car tends always seems to pull a few more degrees and pulling timing more often when I'm using 87 vs 93... So while I can see the difference in the spark advance I think it's so small a difference you really can't feel it...
#11 | |
#12 |
My camaro hasn´t seen anything but Shell Optimax
Ordered:
2SS Imperial Blue Delivered: 02.07.09 |
#13 |
TEXAS FIGHT!
Drives: Awesome Join Date: Apr 2009
93 Octane
#14 |
Would rather be riding
Drives: 2012 SS LS3 Join Date: Jul 2009
Ive been using 87 octane Shell fuel and feel quite safe in doing so.
The V6 has a knock sensor on each cylinder. Direct injection makes it possible to use 87 octane fuel in the engine in spite of it's 11:1 compression ratio. |
#15 |
![]() Drives: 2010 2LT RS Auto IBM Black Int Join Date: Mar 2009
regular, if you wanted to put in premium you should get the ss
#16 | |
Camaro fan since birth
When exposed the to the high temperatures and pressures of the inside of a cylinder, an air/fuel mixture is prone to explode. The amount of energy it takes to cause this to happens is called the activation energy. The octane rating of fuel is basically a rating of the activation energy of the fuel. The higher the number, the harder it is to get the fuel to combust. I could go into more detail about how it is actually a comparison of the activation energy of pure iso-octane and that higher octane fuel actually contains less potential energy then lower octane fuel, but I'll save that discussion for another day. Now back to activation energies and octane ratings. Higher octane fuel has a higher activation energy, meaning it is harder to get 93 octane fuel to combust then 87 octane fuel. How does this apply to your engine? In ideal conditions, you want the fuel to combust only when the spark plug sparks. If it sparks prematurely, you aren't able to extract all of the potential energy from the fuel, you will get "engine knock" and you could actually damage the engine because the air/fuel mixture could be igniting while the piston is still on the up stroke and you have the the piston pushing into the expanding gasses rather then the expanding gasses pushing into the piston. Now onto compression ratios. Because of reasons far more advanced then I want to go into, the higher compression you can run, the more energy you can extract from the fuel. This means you get more power out of the same amount of fuel and the engine just overall runs more efficiently. The downside is that running higher compression also exposes the fuel to higher temps and pressure making the chance of premature detonation higher. This is why you need higher octane fuel. The fuel is able to withstand these more extreme conditions and not detonate until the spark plug sparks. There are other factors such as timing which is when the spark plug sparks. If a lower octane fuel is used, the spark plug is going to have to spark earlier to prevent the engine knock, and this sacrifices efficiency and power. Now onto turbos, even though turbo engines actually run at a lower compression ratio, the engine, by nature of it having forced induction, is going to run at higher pressures. This means that a higher octane fuel is needed for the engine to run at it's best. Where does the DI V6, LS3, and Turbo Ecotec fall into this discussion. Because of the direct injection on the V6, the fuel can be injected into the cylinder after the air. This means that the engine can run at a higher pressure and not risk detonating the fuel that isn't present in the cylinder. This helps it run on lower octane fuel while maintaining a higher compression ratio. This is how GM designed it to run, and you will get little to no benefit from running higher octane. In the LS3, there is no direct injection. This means the fuel enters the cylinder with the air. This is also a high compression engine because of the performance nature of the engine. This means that a higher octane fuel is recommended, but a lower octane fuel can be used at the expense of less timing and lower power and efficiency. The Ecotec engine, being a turbo engine runs at higher pressures, and a higher octane fuel is highly recommended. I hope I haven't bored/confused you with this post and that you do learn something from it. On another note, running too high of an octane for your engine can damage it as well. If an engine is designed for 87 octane fuel, running 93 might not give you an benefit. What could happen is an incomplete burn because of the fuel having a higher activation energy then what the engine was designed for. This results in more emmissions, lower efficiency, and less power. Last edited by knowitman; 07-31-2009 at 10:29 AM. |
#17 |
Thank you Oshawa/St.Cats!
Drives: 2010 2LT RS 2G1FC1EV4A9103434 Join Date: May 2009
First tanks were 87 then I switched to 89 Sunoco and I feel and hear a difference. Now at 1,900 miles and 5 tanks on 89 - the start is smoother, idle as well and sounds better, and merging is without hesitation (whereas on 87 it felt a bit sluggish ).
So I'm A-OK using 89 and do not intend to go lower or higher.
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD24.html
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5 |
#18 |
![]() Drives: 2010 1SS/RS Inferno Orange Join Date: Jun 2009
I've tried this in my 06 chevy truck 87 octane vs 91 octane. You get a little better gas mileage with the 91 vs the 87 but you pay more for it. Basically it evens out, spend more get a few more miles on a tank. As far as mileage goes in the end it evens out, but for your engine the 91/93 w/e you have in your area is better for it.
Not to mention the good gas is only .20 cents more per gallon. The car holds 19, if you coast in the station and on empty it will cost $3.80 more (on the total price) of that of the cheap gas. Say its 2.30 for reg. and 2.50 for supreme Reg fill up = 43.70 Supreme = 47.50 total of $3.80 difference. In the long run I think it pays off, better running engine, and a bit better gas mileage/performance. Just my .02 |
#19 | |
![]() Drives: 2010 2SS M6 IBM Join Date: Jun 2009
#20 |
![]() Drives: 2010 2SS RS Join Date: Jul 2009
I use 91 (highest in California) at Chevron because I have a company gas card. I would probably still use it even if I had to pay for it.
IOM w/ White Stripes 2SS RS M6 #17772
Now - Stainless Works 2" Headers, Intake, Cam, tune, ect And shepherds we shall be, For thee my lord for thee. Power has descended forth from thy hand, that our feet may swiftly carry out thy commands. So we shall flow a river forth to thee, and teeming with souls shall it ever be.In nomine Patri, Et Fili, Spiritus Sancti |
#21 |
Turn it up to 11.
I'm running 91 octane in my 2SS/RS, and will continue to get the highest octane. Better to have the engine operate at optimum perfomance.
#22 |
![]() Drives: toyota Avalon Join Date: Jul 2009
I want to buy the v6 LT just so I can use 87 octane. It will be an everyday driver.
I figure the v8 burns more fuel, AND it requires hi test which is $.20 more per gallon |
#23 |
My baby is here
So if you have a 2LT and it recommends 87 but your using 91 or 94 is it going to be a proble ?
I dont mind paying an extra $4.00 for better gas mileage and a better performance. can it hurt the engine ?
#24 | |
If you get your car tuned then use whatever gas the tuner tuned it to.
#25 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
91 in my SS
| Thread Tools | |
| New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Exterior Parts & Accessories | 30 | 02-20-2013 03:23 PM |
| Ultimate Camaro Playlist | chevyridinghigh | 5th Gen Camaro SS LS LT General Discussions | 90 | 04-20-2010 11:00 PM |
| 10 Camaros that should be built | SSOOCH | 5th Gen Camaro SS LS LT General Discussions | 47 | 11-03-2009 05:46 PM |
| 2010 Camaro, Decisions Decisions… (Winding Road Review) | Xmicro_SS | 5th Gen Camaro SS LS LT General Discussions | 19 | 05-09-2009 11:40 AM |
| Detroit News panel wants GM to build Camaro concept | Tran | 5th Gen Camaro SS LS LT General Discussions | 12 | 03-15-2009 04:38 PM |
