JUICEDMOTORSPORTS
Old 04-02-2014, 10:53 PM   #1
JT20
JT20's Avatar
Drives: 2013 Black 2SS/RS
LCA + Welds
Does Anyone Know who make LCAS for the 2012+ suspension that works welds 17" wheels
JT20 is offline   Reply With Quote
Old 04-02-2014, 10:56 PM   #2
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
Bmr has a new FE4 compatible lca to work w welds
Or ya can do the bmr drag pack for even an even better option (love it)
I'm sure Keth will chime in!!
ddck24 is offline   Reply With Quote
Old 04-03-2014, 08:38 AM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, we are installing our first set of the newly revised lower control arms this morning. Want to make sure everything fits good. We should start making them for production in less than 2 weeks.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 04-29-2014, 05:43 PM   #4
JT20
JT20's Avatar
so when will u have them out for sale?
Old 04-29-2014, 07:07 PM   #5
Blk_SS
Drives: black on black 2SS/RS
A new LCA?? The old style wasn't working???
Blk_SS is offline   Reply With Quote
Old 04-29-2014, 08:15 PM   #6
Fallout
Mid Florida Camaro Club
Fallout's Avatar
Drives: 2012 Camaro SS Ashen Gray
any word on these arms yet???
ECS 1500 supercharger blacked out, Alkycontrol, Livernois Duel Pumps, PRC 255cc aftermarket heads, FSP cam, DSS 9" with 3.55, ARH headers, magnaflow exhaust, Century Level 5 4l80
741 RWHP and 602ft-Lbs
Built By Florida Speed and Power
Coming soon YSI and to the moon
Fallout is offline   Reply With Quote
Old 04-29-2014, 09:49 PM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yeah, the new arms are now available for ordering! They are compatible with both FE3 and FE4 style suspensions. Same price as before.
T.C. Davis
813-986-9302
Old 04-29-2014, 09:50 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The older style only worked with FE3 Suspension, not FE4. Now, they work with both!
T.C. Davis
813-986-9302
Old 04-30-2014, 12:46 PM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Just be advised.....the TCA028's are for lowered vehicles only who want to be able to maintain factory alignment specs! They are slightly shorter than the factory arms and were purposely built that way in order to still be able to obtain factory alignment specs with lowering springs. Some folks have issues trying to get the increased negative camber they want with a true "performance" alignment with the TCA028's, they won't go much over -0.5. Some see a little more or less. If you want true camber adjustability for "Street Performance" or "Pro Performance" alignment specs, you need to get the TCA029's. The TCA028's do work great for drag racing because you don't want the increased negative camber in that situation. But for those folks wanting to do roadcourse or autocross events, the TCA029's are the only way to get that increased negative camber.
T.C. Davis
813-986-9302
Old 04-30-2014, 02:45 PM   #10
JT20
JT20's Avatar
so which do i order for stock height with the FE4 to work with the welds on my 2013 SS no auto cross only drag!
Old 04-30-2014, 03:06 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Because your car is not lowered....you need TCA029's.
T.C. Davis
813-986-9302
Old 04-30-2014, 03:15 PM   #12
JT20
JT20's Avatar
ok but on ur website the note says: When using on 2012 and 2013 models it is necessary to use a 2010/2011 style rear sway bar and end links... IS this still true or are these also compatible with the FE4 and i should disregard the note
Old 04-30-2014, 03:26 PM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yeah, disregard that note, it is no longer valid since we did the revision.....I'll get that removed!!! Thanks for the tip!!!
T.C. Davis
813-986-9302
Old 04-30-2014, 03:46 PM   #14
JT20
JT20's Avatar
no problem and thanks for the help
