Old 04-06-2014, 09:13 AM   #1
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
1in drop? can i just cut the springs?
If i were to only want a 1in drop on a SS, can i cut my springs without any rubbing or unusual wear on any parts?
Explit Player is offline   Reply With Quote
Old 04-06-2014, 09:23 AM   #2
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Springs dont cost that much, if you can afford an SS then you can spend 300 bucks on some springs lol
JantzenOKC is offline   Reply With Quote
Old 04-06-2014, 09:41 AM   #3
Explit Player
IG @Brian_ _Self
Yea, i know what you're saying, but just because i splurged on a car, doesn't mean a s*** out money...
but is it possible just to cut them without any issues? Yea i know i may scrape a bump or 2, but I'm talking about wear on the car just from driving like previously stated.
Old 04-06-2014, 09:52 AM   #4
shadycamaro
Imperial Stunner
shadycamaro's Avatar
Drives: 2012 2LT/RS (IBM)
I personally wouldn't run a cut set just for integrity issues from small fractures that could occur. If you don't wanna splurge on new cost... wait for someone to throw a good used set up on local market place/CL... just my opinion
Sent from my VS980 4G using Tapatalk
Performance: VMAX Ported TB / Custom Magnaflow Exhaust / K&N Filter Interior: Llumar ceramic tint (20%) / Chevrolet All Weather Trunk Mat System: JL HD 750.1 / JL 300.4 / (2) JL 13tw5's / Focal Polyglass 165 V30 6.5" 2-Way Components (Front) / Focal IC 690 (Rear) / Audiocontrol DQL-8 / Stinger Wire & RCA's / Custom rear facing sealed box with chevy bowtie lit logo / Custom amp rack in rear seat opening
shadycamaro is offline   Reply With Quote
Old 04-06-2014, 09:53 AM   #5
shadycamaro
Imperial Stunner
But a 1" drop is perfect & really awakens the responsiveness!
Old 04-06-2014, 10:11 AM   #6
Explit Player
IG @Brian_ _Self
what does it do in terms of responsiveness? I'm just looking for a style, but performance is a good by product. also what did you get? springs cut or kit
Old 04-06-2014, 11:50 AM   #7
rocketrider807
rocketrider807's Avatar
I think the biggest risk with cutting springs is digging in to the spring mounts. Coils have closed (flat) ends and if you cut them you will then have a point. You could grind it flat to some degree but you still wouldnt have the nice large area to distribute force.
I want to say lowering springs also have a higher spring rate which can help compensate for reduced travel...but check with manufacturers on that one.
Lowering brings the CG of the car down (and changes suspension geometry which is a whole-'nother mess). Ive got hotchkis lowering springs and they feel more firm than stock....but all i have to compare against is test drives. The springs were installed before i bought my car.
I recommend saving for springs if you can, but either way get an alignment afterwords! Lowering will change camber at least and you dont want to put odd wear on your tires. Tire$>spring/alignment$
PIN IT TO WIN IT!
rocketrider807 is offline   Reply With Quote
Old 04-06-2014, 12:11 PM   #8
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
NEVER cut your springs, that is a very bad idea and you should just wait until you can afford the drop springs. As mentioned above, if you can afford an SS you should be able to swing $300 for springs.....eventually anyway.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-06-2014, 02:01 PM   #9
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
No! Don't cut your springs.
Your car will ride like crap.
Your car will handle like crap.
I also believe the stock springs are progressive, so you can't cut them.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 04-06-2014, 02:07 PM   #10
Explit Player
IG @Brian_ _Self
Alright guys, yea I saw they were progressive. I will just get those soon then. I got a birthday comin up soon so I guess it wont be too hard
Old 04-06-2014, 09:33 PM   #11
Camarodriver2
Camarodriver2's Avatar
Drives: Bumblebee 1 of 1
Ditto to what Rocketrider807 said. Don't forget to index the new springs and suspension after installing the new ones - before you tighten the suspension bolts. Start saving for the alignment you'll need to get after lowering the car. If you don't want to pay for the alignment, start saving for the new tires you'll need sooner than normal.
Doing things right costs $$. Doing things wrong cost $$$$$
Camarodriver2 is offline   Reply With Quote
Old 04-06-2014, 10:01 PM   #12
Explit Player
IG @Brian_ _Self
Yea, I will end up going with the kit. The cutting was just an idea.
Now, I got me a good deal on alignments, my buddy has a alignment machine. Like brand new. Maybe like 10 cars have been put on it. So im good on that for free
Old 04-07-2014, 04:49 AM   #13
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Remember to have your bushings timed when you do your alignment after the spring install. And yes, the progressive spring rates provide properly engineered ride quality and fitment on the mounts. You can get a set of Hotchkis 1" lowering springs from JDP Motorsports for $229. http://www.jdpmotorsports.com/hotchk...amaro-ss-19110 It will cost you around $3-400 for a proper install, timing and alignment.
SS PANTHER is offline   Reply With Quote
Old 04-07-2014, 09:43 AM   #14
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Player with no $......
Cut springs is just flat out incorrect, wrong, dangerous and should not be done.
If you can't afford them...leave the car stock.
cut, drop, springs, ss suspension
