Cold Air Inductions
Old 07-31-2009, 04:12 PM   #1
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
Harmonic balancer removal w/o impact wrench
Anyone remove the harmonic balancer without impact tools? I thought it would be fairly easy; shift into reverse, pull e-brake, use 3/4" drive 3' breaker bar and pull like mad. Bolt won't break loose. Problem is how do you deal with the recoil caused by the engine compression? (that is, after pulling breaker bar cc by 90 degrees, the hb wants to go back to the original position). If there's a way around it, I'd prefer to not remove the plugs.
MJ is offline   Reply With Quote
Old 07-31-2009, 04:15 PM   #2
JoshJ81
JoshJ81's Avatar
Drives: '10 Camaro 2SS/RS Black
umm why are you doing this? lol
JoshJ81 is offline   Reply With Quote
Old 07-31-2009, 04:53 PM   #3
DanD
DanD's Avatar
Drives: 6 camaros
you are just talkin about the bolt? correct?
I pinned a big ass pry bar through a hole in the balancer and toward the a/c compressor, on the engine.. (forget exactly what it layed against) and then used the breaker bar and a 4 ft. pipe.. lol.. I thought something was breaking... lol.. I don't remember my 02's being that hard.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 07-31-2009, 06:26 PM   #4
MJ
MJ's Avatar
I'm trying to visualize that... thanks for the idea. Earlier I was thinking of using a large pipe wrench to grip the inner & outer edge of the pulley, then have the handle press against the concrete floor.... but that would burr up the pulley... and don't know if the wrench jaw would be able to handle the sideways stress. Did you find breaking the bolt loose to be the bigest pain in the arsh?
Old 07-31-2009, 07:15 PM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
put the car in 5th.
also remember to replace the bolt when you put everything back together. I imagine you are doing an underdrive pulley swap.
use the stock bolt to torque the pulley on initially. Once it is threaded, tighten it to 240 ft. lbs. or until it is completely seated on the crank snout. Afterwards, remove the stock bolt and replace it with the new crank bolt. You will tighten the new bolt to 37 ft. lbs. and then turn it an additonal 220 degrees
I piss excellence
and fart awesomeness
Old 07-31-2009, 07:19 PM   #6
Howzit
Howzit's Avatar
Drives: 77 RS, 10 SS
I normally have someone lock the flywheel in place with a screwdriver. I'm not sure if newer cars have that flywheel opening anymore.
Howzit is offline   Reply With Quote
Old 07-31-2009, 07:21 PM   #7
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
Impact wrench with some balls=IR244 BAD ASS 1/2 IMPACT
I sell and service them
silverfox is offline   Reply With Quote
Old 07-31-2009, 07:39 PM   #8
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the correct way is to drop the starter and bolt on the tool to hold the flywheel, check e-bay i have seen them there cheap,, i have my own gm gen 3 engine tool kit and it is part of the whole kit
make sure to use a new bolt every time to loosen it and do not use the bolt to pull the balancer back on, you will strip the crank threads
torque for re-install:
Crankshaft Balancer Bolt - First Pass
110 lb ft
Crankshaft Balancer Bolt - Second Pass
Loosen 360 degrees
Crankshaft Balancer Bolt - Third Pass
37 lb ft
Crankshaft Balancer Bolt - Final Pass
230 degrees (not lb ft)
Old 08-01-2009, 02:21 PM   #9
MJ
MJ's Avatar
Source of 1st pass and 2nd pass torque specs?
What's the source of your 1st pass and 2nd pass torque specs? Vendor quoted me 1st pass 37 ft / lbs. Final pass 140 degrees. New tty bolt is to be used as well.
Anyone with insider access to online shop manual care to look it up? I tried to order shop manual but Helm tells me it isn't available yet.
Old 08-01-2009, 02:30 PM   #10
camaro1
camaro1's Avatar
Originally Posted by MJ View Post
What's the source of your 1st pass and 2nd pass torque specs? Texas Speed quoted me 1st pass 37 ft / lbs. Final pass 140 degrees. New tty bolt is to be used as well.
my numbers are copy and paste from the gm online service manual (SI),, the spec they gave you is for the older ls engines and truck 4.8,5.3,6.0 engines
2009 and newer ls3/l99 engines use the 230* final torque
Old 08-02-2009, 12:03 AM   #11
firestone_ss
firestone_ss's Avatar
theres always the place the breaker bar tightly against the floor and tap the ignition method but im partial to impacts myself
firestone_ss is offline   Reply With Quote
Old 08-02-2009, 08:40 AM   #12
DanD
DanD's Avatar
Drives: 6 camaros
no way an impact would of taken mine off... I am 240lbs, not a *****, and used a 4 ft pipe on my breaker bar to loosen it... a guess would be WAY more than 700ft lbs of torque to loosen it..
2002 Z28 427
1968 383 Camaro
1967 RS 327
Old 08-02-2009, 09:48 AM   #13
MJ
MJ's Avatar
camaro1,
Compared to the torque specs for the older engines, looks like there's a bolt pre-stretching procedure (110 ft/lb, then relax) for the LS3 prior to the 37 ft/lb, then 230* final specs. Do I have that right?
Regarding hb install...
Vendor advised me to use original bolt to pull on hb.... torque to 240 ft/lb to be sure it's seated. Heard that heating hb in oven for 1/2 hr at ~300 degrees would expand the id enough so it would press on easier. Since I don't want any chance of F'ing up the threads, I probably should get an installer, right? (btw - thanks for spending the time to straighten me out!)
Old 08-02-2009, 11:43 AM   #14
DanD
DanD's Avatar
Drives: 6 camaros
the threads are so deep in the crank my installer wouldn't work. So I gently tapped it on with my plastic dad blow around in a circle until I could catch 3-4 threads of the bolt an slowly tightened it. Went on smooth an safe
2002 Z28 427
1968 383 Camaro
1967 RS 327
