Rick@Livernois
Old 04-06-2014, 07:20 PM   #1
Ayala2SS
Drives: 2010 camaro 2ss silver ice metallic
CAM for my setup????
i currently have a 2010 camaro 2ss whipple, full exhaust shorties,102mm TB, CAI. I currently bought some MAST heads and want to add the heads along with a CAM to unleash my blowers power i have looked at the JRE rough idle blower cam but so many decisions i dont want to buy something i might not like so if anyone can help or point me in the right direction thank you im looking for good drivability as long as not too choppy < not annoying but i want most power texas speed claims 60rwhp with their B-Cam.
Ayala2SS is offline   Reply With Quote
Old 04-06-2014, 07:24 PM   #2
SSeniorMoment
Drives: 2010 2SS RS L99 IOM
Get spec'd for a custom grind for your complete components, driving style and altitude.
SSeniorMoment is offline   Reply With Quote
Old 04-06-2014, 07:25 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
LS3 or L99?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-06-2014, 07:26 PM   #4
Ayala2SS
Originally Posted by axis View Post
LS3 or L99?
Its an Ls3 and i contacted jre-ted he wants to give me a jre rough idle cam.
Old 04-06-2014, 07:27 PM   #5
Jared91
Jared91's Avatar
Drives: 2011 Camaro SS/M6
Bingo ^^^^^^
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
Jared91 is offline   Reply With Quote
Old 04-06-2014, 07:35 PM   #6
Ayala2SS
What company should i go through for the custom grind cam??
Old 04-06-2014, 07:35 PM   #7
axis
Search Ninja
axis's Avatar
I agree with the others, in that you need to talk to a shop to have them spec a cam for your needs. If you just want a off the shelf cam, then get the one that looks best to you. If you want a cam made specifically for your setup, go elsewhere. You do know that rough idle means choppy.
There are many shops that can tailor a cam to your needs. The ones that come to mind are GPI and Slowhawk. There are some very nice cars coming out of both shops.
Halltech CF 102 fed
Old 04-07-2014, 05:27 AM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You need to get long tubes and call Brian Tooley racing aka BTR or Martin at Tick for a specd cam and a set of his tried and true valve springs.
Those are your options, you'll regret the rest.
Old 04-08-2014, 09:50 AM   #9
Camarozilla76
Camarozilla76's Avatar
Drives: 2011 Camaro 2SS
I highly recommend you check out my friends video clips on YouTube. Search Lethal Racing "Night Fury" cam.
Sent from my iPad using Tapatalk
Camarozilla76 is offline   Reply With Quote
Old 04-16-2014, 07:10 PM   #10
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
What actually makes them "his tried and true valve springs"? I don't think BTR manufactures valve springs. More like he buy's and sell's products. This is a common misconception for those who think he actually has something figured out over the biggest spring manufacturing companies.
I'm sure this will start some discussion......
BFASTNOTLAST is offline   Reply With Quote
Old 04-16-2014, 09:46 PM   #11
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I would contact Pat G. and have him spec you a cam for your application and specific mods. He uses Comp Cams ground cores and will direct you in the right direction. Any valve train components go with all BTR (Brian Tooley Racing)
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 04-17-2014, 07:58 AM   #12
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
+1...thats the best advice I have heard yet!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-18-2014, 12:25 AM   #13
Ivan @ Southwest Speed
Most all of our cams are custom ground by BTR....I'd challenge that our 231FI cam would make as much or more than any other PD Blower Cam on the market.
Check it out and let us know if we can meet your needs when it comes to what you're after!
http://www.camaro5.com/forums/showth...ighlight=231FI
Old 04-18-2014, 06:41 AM   #14
jman17
jman17's Avatar
Drives: 2011 SS-2/1969 SS
I had Pat G spec me out a cam and EPS grind it for me. Started the car this week with the new cam in it and it sounds badazz...
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: 470 rwhp/437tq; Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Cold Air Induction CAI system, RX Performance Catch-Can, Skip Shift Eliminator
jman17 is offline   Reply With Quote
best cam, cam, camaro, horespower, whipple
