Flowmaster Exhaust
Old 04-14-2014, 03:57 PM   #29
Cully77
FOUR T 5
Cully77's Avatar
Drives: 2012 Camaro 45th
awesome thread!
http://i85.photobucket.com/albums/k79/Cully77/sig2camaro.jpg
Cully77 is offline   Reply With Quote
Old 04-14-2014, 10:08 PM   #30
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Originally Posted by Cully77 View Post
awesome thread!
I just added another post on the first page about my Gingerman track weekend.
Matt
Old 04-14-2014, 10:35 PM   #31
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Was that your car in the dirt Matt??!! If it was at least it looks like the car escaped any real damage other than some "Mud in the tires".
Also I see you are now using Stop Tech 660 brake fluid? I'm curious as to why you switched from the Motul 600? Or was it just a matter of what you had on hand when you did the CTS-V brake swap?
Nick S is offline   Reply With Quote
Old 04-15-2014, 08:44 AM   #32
Dropspeed
Dropspeed's Avatar
Yes...that was me. If you watch the incar video link in the post you can see the light spin and I backed it into the mud
The Stoptech was readily available and the 660 has very similar temp range as the Motul 600.
Matt
Old 05-13-2014, 05:47 PM   #33
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
How is your alignment working out? Both street and track? -1.6 fronts and -.6 rears right? This is also what I'm running but don't have the miles to see how the tires will wear. I'd like more camber if I could get away with it on the street without destroying the inside of the tires.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 05-15-2014, 08:40 AM   #34
Dropspeed
Dropspeed's Avatar
Good question! For the front I wore the outside edges off at a tire abusive track (Gingerman) but never rolled them past the triangle indicator on the side. Temps across the tire were pretty even, but I will have two new front installed on Monday and then I will have it aligned to -1.9/2.0 and try that.
I will run the car at two different tracks Memorial Day weekend and will post my results.
I put 305s on the rear so that is why I stood up the tire (less camber) to try to help the car rotate. I am happy with the outer edge wear patter at this point so I am going to leave that where it is.
I am still trying to find the sweet spot.
Matt
Old 05-15-2014, 08:43 AM   #35
Dropspeed
Dropspeed's Avatar
Forgot to mention. My 1LE is not a daily driver so I can't speak about tire wear on the street as I am on my second set of rears and going on the 3rd set of front in 9000 miles. I don't wear the center treadout, only the outer and inner edges at the track.
Old 05-15-2014, 11:57 AM   #36
White_SS/RS
Drives: 14 1LE
How did the car like the 305's?
LMS Engineering
Old 05-19-2014, 08:03 AM   #37
Dropspeed
Dropspeed's Avatar
It was OK/fine......I will be going with 285 in the rear if I keep the 285 on the front. I would prefer to go with a 305/305 so I may make some changes over the summer.
-Matt
Old 05-23-2014, 03:59 PM   #38
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Man that car is amazing. It is a very beautiful 1LE
Current Car(s)
2015 Camaro 2SS 1LE 6.2L V8- Dream Car
2015 Equinox 2.4L I4- (Married Man with a kid ^__^)
Previous Cars
2013 Camaro 1LS 3.6L V6 - Traded
1995 Toyota Pickup 2.4L I4- Sold
1985 Mazda Rx-7 1.8L (Red) - Total Loss
1985 Mazda Rx-7 Turbo 1.8L Rotary ( White)- Sold
1996 Honda Accord 2.7L V6 - Wrecked
1998 Dodge Intrepid POS Engine- Lemon
rgrmoreira13 is offline   Reply With Quote
Old 05-27-2014, 09:10 PM   #39
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Enjoyed reading your build thread Matt.
One question, so how much did you lower your car front and back, and did you level it out?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-28-2014, 08:10 AM   #40
Dropspeed
Dropspeed's Avatar
Thanks John,
About 15mm in the front and 30/35mm in the rear. Yes it is level now. The most recent picture is below. that is a 285/305 combo so the rear tires are taller.
Ride heights: Measured in mm from the bottom wheel lip (not the ground) to the fender....If you want inches divide the number by 25.4 (25.4mm = 1")
Front Stock
LF: 672 RF: 668
Front Pedders
LF: 657 RF: 654
Front Diff:
LF: 15mm RF: 14mm
Rear Stock
LR: 690 RR:690
Rear Pedders:
LR: 660 RR:655
Rear Diff:
LR: 30mm RR:35mm
Matt
Old 05-28-2014, 12:50 PM   #41
Behic2320
SoCal HT5 COTW 4/21/13
Behic2320's Avatar
very cool start you have made some great headway on your build. Keep it up
Old 06-03-2014, 04:04 PM   #42
markgws6
markgws6's Avatar
Drives: 2013 Camaro 1SS/1LE
Originally Posted by Dropspeed View Post
The first thing I did when I got my car was to remove the engine cover.
The primary purpose of the cover is to reduce intake and valve noise. But it also traps heat as well as adds weight while making the engine compartment more visually appealing to the masses.
For me, weight on top of the engine and it acting as a heat trap were enough to get rid of it for about a year......But I have been focused on the ugly coil packs and the though of what (minimal) protection it offers to the wiring, injectors, coil packs ect......
Below is my best of both worlds modification/compromise I made over the weekend. I removed the sound deadening material underneath, cut the center section out, fabed a quick bracket on drivers side and painted them flat black. I got the look I wanted, reduced the weight, removed the heat trap and got a little protection for the wires.
-Matt
How does it handle without the strut tower brace?
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
CAI intake, Apex cold air scoop and washer bottle, Hypertech 91 tune, ZR1 diff fluid, Motul RBF-600, Russell SS brake lines, SLP skip-shift override, SRP Pedals, Forza 3 way exhaust controller, octane fuse reset
markgws6 is offline   Reply With Quote
