Old 08-01-2009, 09:46 AM   #1
Germann
Germann's Avatar
Drives: 2010 V6 Black Camaro
Removal of tail lights
Hey folks. I bought a black 2010 and wanted the look of Camaro Black, for those of you that saw those SEMA pics. Anyway, to test the look, I used window tint to tint the windows and the tail lights, left on the black steel wheels but painted the beauty rings black. Perhaps I can post photos later. Anyway, I determined I liekd the look and decided to make it permanent, so I set about removing the tint from the rear tail lights so I can remove them and "smoke" them black. Previous advice on removing the tail lights over-simplifies it.
First you remove the black plastic molding to get access to the tail light assembly. This is held in place by three plastic pop-rivet looking things. They are two-piece. Using a screwdriver, pry up the center piece (its ok if you pull the center piece out completely) then you can remove the whole "rivet".
Second, you can work on removing the bezel. Work slowly. There are clips on the bezel which you need to push toward the hole with your finger and at the same time pry the bezel outward. Some are hard to reach, but if you go slow, they come out easy and WITHOUT breaking. I wanted to leave the Bezels off as it gives a deeper set look to the tail light assembly. However, I can see gaps around it which would most assuredly let water in. Some will argue its only plastic, who cares, but I dont want water inside or around any wiring, so Im going to paint the bezels while I have them out and re-instal them satime black.
Third, you will need needle nose pliars to likely get the tail light assembly initially loosened. Mine were loose anyway, but needed a quarter turn to get finger-loose and needle nose worked great for ones hard to reach. Hope this helps some folks make their car their own. You can easily do this yourself without breaking pieces in about an hour.
Germann is offline   Reply With Quote
Old 08-01-2009, 12:11 PM   #2
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Water gets back behind the tail lights anyways due to the trunk drip rails. Put some water in the rails and watch where it goes.
Hylton is offline   Reply With Quote
Old 08-01-2009, 12:48 PM   #3
Germann
Germann's Avatar
Indeed it does. Watched it run. But after checking out the deep well look of the lights without and with, I opted to re-install the bezels, after painting them black.
Old 08-03-2009, 09:42 AM   #4
Germann
Germann's Avatar
http://www.facebook.com/home.php?#/p...1305074&ref=nf
Old 08-03-2009, 12:53 PM   #5
srevoal
Like the Batmobile Honey
srevoal's Avatar
Drives: Black 2SS/RS M6
That looks really great. Are you going to black out the bowties? your car looks a lot like what I am planning. I even like the black steelies.
6/29/09 Preliminary Order - 1100
9/2/09 2000!
9/15/09 3000 10/05/2009
9/22/09 3300 10/05/2009
10/1/09 3400 10/5/2009
10/9/09 3800 2G1FT1EW1A9153975 ETA 10/23
10/24/09 IN MY GARAGE!!!
Big thanks to Viz for satisfying my obsession. It was more than worth the wait. Black on black 2SS/RS M6
srevoal is offline   Reply With Quote
Old 08-04-2009, 09:10 AM   #6
Germann
Germann's Avatar
Thanks. Im out of money for now, so I had to keep the steelies for now, but did keep em in the theme. Im thinking of painting the bowtie black as well. Thanks for the appreciation. Its not much but at least making an attempt to make her unique.
Old 08-04-2009, 09:11 AM   #7
Hylton
Hylton's Avatar
Looks great man! Definitely looks like it menas business all black out in the back. Good job!
Old 01-17-2010, 02:55 PM   #8
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
I removed the chrome bezels and replaced them marine rubber gasket. Just to fill in the gap around the tail lights.
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 12-14-2010, 10:43 PM   #9
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Hijacking
Stop hijacking peoples threads, and it doesn't look good!
FL1CK is offline   Reply With Quote
Dissapointed in the Tail Lights Logan-69-Camaro 5th Gen Camaro SS LS LT General Discussions 150 08-17-2013 01:58 PM
Clear Lens Tail Lights - smoked kdoske Cosmetics and Lighting Modification Discussions 13 04-24-2011 02:55 AM
LED Tail lights 69er Cosmetics and Lighting Modification Discussions 16 12-17-2009 02:31 PM
RS Tail Lights? Rahn 5th Gen Camaro SS LS LT General Discussions 9 03-12-2009 01:03 PM
RS tail lights? MLL67RSSS 5th Gen Camaro SS LS LT General Discussions 16 09-23-2008 12:59 PM
