Rick@Livernois
Old 08-01-2009, 10:07 AM   #1
Bryan @ Speed Inc.
Drives: 2002z28
SPEED INC TVS 2300 2010 CAMARO TRACK RESULTS!!!
so... bad day to go to the track and try and get a feel for the new setup. The ride was over 2 hrs in traffic and then over 1 hr in tech. We gave the car about a 15 minute cool down and went for it.
car just turned 1000 miles on the trip up to the track
1/2 tank of 93 BP
race weight..I would say 4K
tires were M&H 345/35/18 : http://www.mandhtires.com/store.php?...on=show_detail
2 runs is what I got...Jim got one off and Dan had a clutch pedal on the floor issue.
#1 tried a 3800ish launch with a smooth, but quick clutch release which resulted in a little spin and hop which I quickly pedaled through. I power shifted at approx 6500 ( stock tach ), but it did not seem to like the power shift at times...slight hesitation since I think the flare would hit the limiter. I tried to run out 3rd gear, but just short of the stripe the car nosed over from the limiter.
2.1 60ft
91 1/8
12.38
119.5
#2 was about 1 hr after the above mentioned clutch pedal stuck on the floor for Dan I decided to try it again. The hood stayed shut for the time it was sitting and the clutch still had a horrible smell. I worked the car through staging for about an hr and then finally got the second run. I came out at approx 3200 ( worried about clutch ) with a quick, but smooth clutch release again and had just a touch of spin/hop and stayed in it. The run felt good here...did not power shift 1-2 and shifted about 6200 on all gears + pulled 4th this time.
1.84 60ft
93 1/8
11.87
118.4
We really feel a gear or shorter tire would really help the car work well both on the front and back of the track
so we are very happy with the car considering lack of time last night to get a feel for the car. We will get back out and work the ET some very soon.
Bryan @ Speed Inc. is offline   Reply With Quote
Old 08-01-2009, 02:13 PM   #2
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
Can you please list the mods on this car and has it been run on the dyno as well?
Oh, and can you post some pics of your wheel and tire combo mounted on the car? I'm curious to see how it looks. Thanks.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 08-01-2009, 02:34 PM   #3
383ss
Drives: 1985 IROC, 2011 Camaro
2nd on the pics of the wheels/tires!
decent runs for shakedowns, can't wait to see more.
the smartest person on Camaro5! Thanks for enlightening us!
Originally Posted by hsdguru View Post
31000 for ss1 no options and who in the hell would buy a SS1 V6 for kids SS1 for girls LS3 the only way to go G8 Gxp 200lbs more my bad so lets think here 200lb more 27 less hp so 5 tenths slower now 373 gear now mabe 3tenths slower 4 door car sad so so sad
383ss is offline   Reply With Quote
Old 08-01-2009, 11:50 PM   #4
gtwss
Time To Hammer Down
gtwss's Avatar
Drives: 2010 Camaro SS, 02 Monte Carlo SS
All that plus, what mode we're you set at?
2SS, CGM, M6, Polished Wheels
6000 8/13/09
gtwss is offline   Reply With Quote
Old 08-06-2009, 01:14 PM   #5
Bryan @ Speed Inc.
Drives: 2002z28
updates on the project :
-3.6 6 rib upper ( was 3.8 )
-Innovators 10% overdrive 8 rib truck crank pulley
( we will be going 8 rib at some point )
We also took and modified an 03/04 Cobra HE reservoir for some added cooling capacity. We think it looks good and should help out some.
We are waiting on some LS9 injectors to get us by for now.
Old 08-06-2009, 01:16 PM   #6
Bryan @ Speed Inc.
Drives: 2002z28
mods on the car are the TVS2300 blower, and the intake. that's IT! the car is stock otherwise.
the wheels we used were 18" C6 Z06 replica's with M&H 28" tall drag radials.
the car actually looks pretty decent in my opinion with those wheels on it.
Old 08-06-2009, 01:18 PM   #7
Bryan @ Speed Inc.
Drives: 2002z28
this is the dyno graph from the previous install.
note: The car is stock other then Magnuson blower.
stock induction :
484 rwhp
471 rwhp
added Roto CAI combined with Magnuson tube
518 rwhp
486 rwtq
IATs 95 at the start of the run and 120 at the end
Old 08-06-2009, 06:42 PM   #8
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
what are you getting (or are you logging it?) for the duty cycle on the current injectors? Fuel rail pressure? Injector pressure? Pulse width? Anything about the pump?
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 08-06-2009, 07:36 PM   #9
LPFSTheFett
Drives: 2010 2SS Camaro
I would love to see a picture of this car with the wheels on it? Do the tires stick out or do they fit inside the wells ok?
LPFSTheFett is offline   Reply With Quote
Old 08-06-2009, 09:28 PM   #10
Amwellls1
Old School
Drives: 2002 WS6 440 m6
Congrats on the shake down passes, pics of the wheels and tire set up please!
2002 White WS6 440LSX M6
2010 GMC Sierra All terrain 6.2
2012 Corvette GS M6
Amwellls1 is offline   Reply With Quote
Old 08-15-2009, 12:28 AM   #11
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
I ran my car at the local drag strip tonight. LPE 570 package. Stock tires. Borla exhaust. Pedders lowering 1".
First pass I obliterated the tires - spun in 1st, 2nd & 3rd. Ran like a 15 something. I was playing around with the launches and finally got it to a 12.6 This was my last run of about 8 runs and I tried to hold it through redline in 3rd but it cut out right before I crossed. The shift into 4th is a must!! It was alot of fun though!! DA was 3354. This was at Thunder Valley in Marion SD. Temp in car said 82 degrees. Im sure I can get it lower with a better launch and cooler temps. Not bad on stock tires that just want to spin... most of my trap speeds were 113-114mph. The last one was 111.9 because it hit the limiter at the end of the run.
Name:  Drag Run #1.jpg
Speed74SS is offline   Reply With Quote
Detroit Speed & Engineering's 2010 Camaro project car Tran Camaro Photos | Spyshots | Video | Media Gallery 72 04-12-2011 02:34 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
MTI Racing's 2010 Camaro @ the track! (pics & video) MTI Racing Camaro Photos | Spyshots | Video | Media Gallery 16 06-02-2009 10:35 AM
