Old 04-19-2014, 04:46 PM   #29
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Lio Martinez View Post
What about the ZL spec sway bars?
Those will be the next product we bring back.
Old 04-19-2014, 04:49 PM   #30
Top Off
Drives: 2012 LS3 1SS/RS Vert
WooHoo. To the sways
Top Off is offline   Reply With Quote
Old 04-19-2014, 04:59 PM   #31
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Better verify they clear the 1LE outer CV boot. I installed 1LE/ZL1 hubs with the 1LE axles on my SS. I cannot use the inner hole because the bar ends will contact the boots. I called Pfadt about it but this was right when they introduced them. Only suggestion they had was play the shim game on the sway bar straps. You should have no problem on any SS that doesn't have the 1LE axles. The CVs are smaller.
This picture is with the end link extended up by use of a spacer where it attaches to the LCA. Otherwise it was even worse on clearance.
bannonm is offline   Reply With Quote
Old 04-19-2014, 05:33 PM   #32
Lio Martinez
SoCal HT5!!!!
Lio Martinez's Avatar
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
Thanks for the heads up dude. How much hp do you think this axles can handle?
2013 CAMARO 2SSRS 1LE Metallic Inferno Orange. Turbonetics T76 Kit, Granatellis Spark Plug Wires and Performance MAF Sensor, Wilwood Big Brake 6 Piston Kit. Eibach 1 1/2 drop lowering springs. ZL1 conversion of rear diffuser with heat shields, Side skirts and rear spoiler matter black. Original GM Transformers edition AuTobot fender logo and autobot wheel caps and autobot stiched ARM rest . Inferno Orange interior seats and dash trim panels, red billet racing pedals , Black CAMARO fuel door with lock. Chevy logo speaker covers, and Camaro logo chromed door kick panels . GM MTX subwoofer box.
Lio Martinez is offline   Reply With Quote
Old 04-20-2014, 01:11 AM   #33
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Just ordered a set, cant wait to post before and after pics.
Thanks Chase!
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 686rwhp/590rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 04-20-2014, 08:12 PM   #34
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Shocks?
jeremywes is offline   Reply With Quote
Old 04-20-2014, 08:31 PM   #35
Apex Motorsports
Thanks Chase!
Thank you for your order. Look forward to seeing your posts.
Originally Posted by jeremywes View Post
Shocks?
These springs are designed to compliment your factory dampers. No need to change them.
Old 04-20-2014, 10:17 PM   #36
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
My earlier question seemed to have been missed. You bringing back the trailing arms?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-21-2014, 02:46 AM   #37
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Put me First on the list for the ZL-Spec kit as soon as its available! lol.
But for real tho.. Ill be waiting for that PM!
Nighthawk89 is offline   Reply With Quote
Old 04-21-2014, 07:37 AM   #38
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
I knew I would be rewarded for not jumping straight on the next thing. Waiting for the post showing the zl1 sway bars are in
RolltideSS is offline   Reply With Quote
Old 04-21-2014, 10:55 AM   #39
SkunkJunk420
SkunkJunk420's Avatar
Drives: "The Skunkmobiles" 13ss 17zl1
we NEED them!!!
SkunkJunk420 is offline   Reply With Quote
Old 04-21-2014, 11:53 AM   #40
Apex Motorsports
Originally Posted by SkunkJunk420 View Post
we NEED them!!!
Time will tell.
Old 04-21-2014, 12:08 PM   #41
WndWarrior
WndWarrior's Avatar
Drives: 2013 1LT/RS
The cars look great lowered, how's the ride though? Is there still enough wheel travel? Finally, using the OEM shocks/struts ok?
Thanks
WndWarrior is offline   Reply With Quote
Old 04-21-2014, 01:06 PM   #42
Denis
Denis's Avatar
Drives: 2010 SS
Thanks
ride is good, stiffer than stock obviously but not bad at all. drove mine from Cali to NY with a buddy of mine and he was surprised at how comfortable the car was.
apex motorsports, lowering springs, pfadt
